    Face Recognition with inferred light
    52 Posts 5 Posters 58.7k Views 4 Watching
    • K
      KirAsh4 Moderator
      Generally, I follow that with 'apt-get autoremove' as well. Often when you remove one package, there are other dependencies that aren’t needed anymore. The 'autoremove' takes care of that.
      • K
        KirAsh4 Moderator
        And yes, I suppose simply 'purge' would get the job done, but there are times I only want to remove the binaries, but leave my config files in place. I prefer forcing myself to actually add the '--purge' bit each time … sort of a mental check.
        • F
          feuerball
          Im just trying to reinstall things, hoping the shit works :D
          maybe i can upload my config here for some correctioN?
            paviro
            Sure thing :)
            – The Doctor
            • F
              feuerball
              @paviro
              Here it is
              0_1464191008459_config.js
                paviro @feuerball
                Can’t see any mistake there. Does it work this way? Any errors in the console or the web inspector?
                I just moved this into a new thread because it has nothing todo with the original training file problem, please open a separate thread for different problems in the future as well :)
                – The Doctor
                • F
                  feuerball
                  @paviro
                  It’s still the same error like above :(
                  Didn’t try so much in the last week, but i don’t know whats the problem in here anyway
                    paviro
                    I am really not sure what this error is about…
                    @MichMich what is module.data.classes supposed to be? Since it isn’t defined apparently in this case…
                    – The Doctor
                    MichMichM 1 Reply Last reply Reply Quote 0
                    • MichMichM
                      MichMich @paviro
                      module.data.classes should contain the classes set in your config file. (If I remember correctly.)
                        paviro
                        Strange I still have no clue how this error could be reproduced…
                        – The Doctor
                          POIMann
                          Had the same issue.
                          Removing the module “localtransport” solved it for me.
                            paviro @POIMann
                            @POIMann really? That’s interesting! So it works without problems now?
                            – The Doctor
                              POIMann
                              The use of this.data in localtransport.js conflicts with this.data-object from the module instance properties.
                              I patched it by replacing “this.data;” with “this.response;” in all its occurrences in localtransport.js.
                              #enjoy
                              • K
                                KirAsh4 Moderator
                                That … would make sense. It’s helpful for module writers to check the documentation on the wiki to see what method, classes, or other naming conventions are being used to avoid conflicts.
                                  paviro
                                  Thank you a lot for figuring that out! :)
                                  – The Doctor
                                  • F
                                    feuerball
                                    gonna try it later, thanks
                                    • 3 / 3
