    Face Recognition with inferred light
    52 Posts 5 Posters 57.7k Views 4 Watching
    • F Offline
      feuerball
      @paviro
      Here it is
      0_1464191008459_config.js
        paviro @feuerball
        Can’t see any mistake there. Does it work this way? Any errors in the console or the web inspector?
        I just moved this into a new thread because it has nothing todo with the original training file problem, please open a separate thread for different problems in the future as well :)
        – The Doctor
        • F Offline
          feuerball
          @paviro
          It’s still the same error like above :(
          Didn’t try so much in the last week, but i don’t know whats the problem in here anyway
            paviro
            I am really not sure what this error is about…
            @MichMich what is module.data.classes supposed to be? Since it isn’t defined apparently in this case…
            – The Doctor
            MichMichM 1 Reply Last reply Reply Quote 0
            • MichMichM Offline
              MichMich @paviro
              module.data.classes should contain the classes set in your config file. (If I remember correctly.)
                paviro
                Strange I still have no clue how this error could be reproduced…
                – The Doctor
                  POIMann
                  Had the same issue.
                  Removing the module “localtransport” solved it for me.
                    paviro @POIMann
                    @POIMann really? That’s interesting! So it works without problems now?
                    – The Doctor
                      POIMann
                      The use of this.data in localtransport.js conflicts with this.data-object from the module instance properties.
                      I patched it by replacing “this.data;” with “this.response;” in all its occurrences in localtransport.js.
                      #enjoy
                      • K Offline
                        KirAsh4 Moderator
                        That … would make sense. It’s helpful for module writers to check the documentation on the wiki to see what method, classes, or other naming conventions are being used to avoid conflicts.
                          paviro
                          Thank you a lot for figuring that out! :)
                          – The Doctor
                          • F Offline
                            feuerball
                            gonna try it later, thanks
                            • 3 / 3
