    Npm start...
    16 Posts 5 Posters 13.5k Views 4 Watching
    • cowboysdudeC
      cowboysdude Module Developer @morozgrafix
      @morozgrafix I manually installed it… because I got an error about not having a pi LOL
      I’m not using a pi for this… this is a mini-itx :)
      Looks like it’s loading it fine just not showing up…
      morozgrafixM 1 Reply Last reply
        broberg Project Sponsor
        this doesn’t really help you, but this guy has the same issue on a PI :
        https://forum.magicmirror.builders/topic/1464/launching-application-nothing-happens
        • morozgrafixM
          morozgrafix Moderator @cowboysdude
          @cowboysdude I will try to reproduce on my machine in a few hours when I get home and will report back.
          • cowboysdudeC
            @morozgrafix said in Npm start...:
            Thank you!
            • morozgrafixM
              @cowboysdude I managed to get it up and running locally on a super old system running Ubuntu 16.04.1 LTS. I had some trouble starting electron via SSH when running DISPLAY=:0 npm start, but npm start worked just fine
              Here is a list of steps that got it running (i’m running node v6.9.4 and npm v4.1.1):
              sudo apt-get install git
              git clone https://github.com/MichMich/MagicMirror.git
              curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
              sudo apt-get install -y nodejs
              node --version
              curl -sL https://www.npmjs.com/install.sh | sudo -E bash -
              npm --version
              cd MagicMirror/
              cp config/config.js.sample config/config.js
              npm install
              npm start
              Not sure if this will help. You can always try to run verbose mode npm start --verbose to see if there is any information that may lead you to finding a reason why it doesn’t start. It was very sluggish on my system, but this is a very old computer.
              P.S. Sorry it took me a while to get to try it out and get back to you. It has been a very long and exhausting day.
              Good luck.
              L cowboysdudeC C 3 Replies Last reply
              Reply Quote 2
              • L
                LincolnClay @morozgrafix
                @morozgrafix Thank you so much for this. I finally got it up and running following your method.
                I did it on a Raspberry pi 3 and after adding in a few more sudo’s it worked!
                sudo git clone https://github.com/MichMich/MagicMirror.git
                sudo curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
                node --version
                sudp curl -sL https://www.npmjs.com/install.sh | sudo -E bash -
                npm --version
                cd MagicMirror/
                sudo cp config/config.js.sample config/config.js
                sudo npm install
                npm start
                • cowboysdudeC
                  @morozgrafix Thank you!! Going to have one coffee then try it LOL
                  No need to apologize I know how you feel… Long days will do that :)
                  I appreciate the help!!!
                    cianoo45 @morozgrafix
                    node --version
                    npm --version
                    cd MagicMirror/
                    npm install
                    npm start
                    Good luck.
                    When i follow these steps it says i have node V4.0.0 installed
                    • cowboysdudeC
                      No go. It is loading and it opens a seperate tab on the side panel but does not display…
                      So I’m trying to figure it out… has to be something in the output of the mirror… it’s launching just not on the TV… which I have hooked up to HDMI…
                      • morozgrafixM
                        I’m replying from my phone at the moment and will post full reply to all later when I’m in front of my computer.
                        When I said “but npm start worked just fine” I meant I was running it from terminal on Ubuntu box and not through SSH from my MacBook.
                        • morozgrafixM
                          morozgrafix Moderator @LincolnClay
                          @LincolnClay I’m glad it all worked out for you. But I would be careful adding sudo command to everything. You may run into permissions issues. The reason why you need to use sudo when installing packages with apt-get is because you need to have elevated privileges as you are making system wide changes. Cloning MM repository in your home directory shouldn’t require sudo, if you use sudo to clone all files will belong to root user and your user (usually pi) will not have permissions to create or modify files in MagicMirror directory (which opens a whole different can of worms).
                          TL;DR version: try to use sudo only when necessary.
                          @cowboysdude Do you have only one monitor (your TV through HDMI) to your Ubuntu box? Also you may want to attempt to run https://github.com/electron/electron-quick-start just to see electron app running on your rig completely outside of MM codebase.
                          @cianoo45 are you still having problems starting the MM? That writeup was specifically for @cowboysdude who was trying to get MM setup on his Ubuntu system. You should be fine with npm v4.0.0 (on my RasPi I’m running node v6.9.2 and npm v3.10.9 if that matters)
                          cowboysdudeC L 2 Replies Last reply
                          Reply Quote 2
                          • cowboysdudeC
                            @morozgrafix Thanks for all the help!! I figured it out!!
                            Since I’m running on a mini-itx it has two display options… they were both running and the mirror was loading on option 1 that’s great but I’m using option 2.
                            SO I went into the settings and disabled option 1 in Unbuntu and BOOM… now it works ;)
                            Reply Quote 2
                            • morozgrafixM
                              @cowboysdude sweet I’m glad you got it working.
                              • cowboysdudeC
                                @morozgrafix Me too! :) BUT HUGE Thank you for the help!!!
                                NOW to install Strawberry’s voice module!!!
                                This thing runs so fast!! I can’t wait to get the touch panel! :)
