    MMM-SoccerLiveScore not displayed since today
    15 Posts 4 Posters 4.4k Views 5 Watching
    • kusselinK
      kusselin
      push…
        sdetweil @kusselin
        @kusselin said in MMM-SoccerLiveScore not displayed since today:
        For last days the module works fine and have no change in the Config.
        always you should engage the author by opening an issue on the modules github page… they are the best person to help resolve the issue…
        modules are done by authors for themselves, sharing the results…
        there is NO commitment to maintain them as the world changes around them…
        those that can, do…
          JoeFranz @kusselin
          @kusselin
          The same here, always “Loading…” :-(
          Have you contacted the author yet?
          kusselinK 1 Reply Last reply
          • kusselinK
            kusselin @JoeFranz
            @JoeFranz no i haven‘t
            Will you do please?
            J 1 Reply Last reply
            Reply Quote -1
              JoeFranz @kusselin
              @kusselin
              I’m on vacation for two weeks starting tomorrow and won’t be able to test it then. So it doesn’t make much sense…
              • kusselinK
                kusselin @JoeFranz
                @JoeFranz
                I’ll have a look at the weekend and create an error message on Github
                  JoeFranz @kusselin
                  @kusselin
                  I don’t think it’s the module’s fault either. It looks like the data for the leagues comes from the site “https://toralarm.com”.
                  If you go to the page for the live results, you get an error message saying “WE’RE SORRY. Unfortunately, this page cannot be found.”
                  kusselinK S 2 Replies Last reply
                  • kusselinK
                    kusselin @JoeFranz
                    @JoeFranz
                    o.k. if this is the case, the creator of the module must also know because it links to it…do you know what I mean?
                      sdetweil @JoeFranz
                      @JoeFranz it IS SO nice that things change all the time…
                      when I worked for IBM, the rule was NEVER break customers systems…EVER
                      you make an api you are stick with it FOREVER… same data in produces same data out
                      you want to make a change, then add a version number and THAT requests with that changed VERSION can change the output
                        JoeFranz @sdetweil
                        Did I write that I want to change something?
                        I’m not a programmer, I just expressed a guess as to why the module is no longer displaying data.
                        Maybe it will work again this evening when the Bundesliga is playing… :-)
                          sdetweil @JoeFranz
                          @JoeFranz said in MMM-SoccerLiveScore not displayed since today:
                          no… you posted that the site was no longer there, so maybe it moved… (its a change!)
                          I was just lamenting how the world no longer cares about customers
                          • kusselinK
                            kusselin @sdetweil
                            @sdetweil here is the right way
                            https://github.com/0m4r/MMM-SoccerLiveScore/issues/13
                            0m4r0 1 Reply Last reply
                            • 0m4r0
                              0m4r Module Developer @kusselin
                              @kusselin please have a look here: https://github.com/0m4r/MMM-SoccerLiveScore/issues/13
                              • D dennisrosenbaum referenced this topic on
                              • 0m4r0
                                0m4r Module Developer @0m4r
                                Please find here the instruction to setup the beta version: https://forum.magicmirror.builders/topic/1169/mmm-soccerlivescore/186?_=1728826313050
