    MagicMirror With Face Recognition
    22 Posts 9 Posters 12.2k Views 9 Watching
      sdetweil @mchan
      @mchan cool.
      • mariosgourosM
        mariosgouros
        Really great and unique idea!
        • O
          OliWer @sdetweil
          This looks pretty cool. Nice work with the styling.
          Can you let me know which hardware you are using? Like the sensors and where is MM running on?
          • SnilleS
            Snille Module Developer
            Nicely done!
            What computer hardware are you using? RPi5?
              mchan @Snille
              @Snille @OliWer Here is the hardware for the project:
              • Raspberry Pi 4
              • Raspberry Pi Camera Module 3 (used for face recognition)
              • GroveGesture Sensor (Used for swipe commands)
              • I think the mirror was originally from IKEA. I swapped out the mirror with a piece of MirrorView glass
              M 1 Reply Last reply Reply Quote 3
                monark @mchan
                @mchan hi man, is awesome mirror.
                Can you explain how you did it with opencv?
                i get to the point of installing that and then i stop and it messes up the system and i have to do it all over again every time. i use an rpi4 and now i have a v3 camera, before i had a v2 camera.
                thank you for answer me
                  cyberphox
                  Get a GitHub and share that config! Wow!
                    sdetweil @monark
                    @monark MMM-FaceReco-DNN has the whole setup to use CV and face database
                      monark @sdetweil
                      @sdetweil my cmd error
                      pip install face-recognition numpy dlib picamera2 opencv-python
                      Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                      Collecting face-recognition
                        Downloading https://www.piwheels.org/simple/face-recognition/face_recognition-1.3.0-py2.py3-none-any.whl (15 kB)
                      Requirement already satisfied: numpy in /usr/lib/python3/dist-packages (1.19.5)
                      Collecting dlib
                        Downloading https://www.piwheels.org/simple/dlib/dlib-19.24.6-cp39-cp39-linux_armv7l.whl (3.4 MB)
                           |################################| 3.4 MB 1.3 MB/s
                      Requirement already satisfied: picamera2 in /usr/lib/python3/dist-packages (0.3.12)
                      Collecting opencv-python
                        Downloading opencv-python-4.10.0.84.tar.gz (95.1 MB)
                           |################################| 95.1 MB 59 kB/s
                        Installing build dependencies ... done
                        Getting requirements to build wheel ... done
                          Preparing wheel metadata ... done
                      Requirement already satisfied: Pillow in /usr/lib/python3/dist-packages (from face-recognition) (8.1.2)
                      Collecting face-recognition-models>=0.3.0
                        Downloading https://www.piwheels.org/simple/face-recognition-models/face_recognition_models-0.3.0-py2.py3-none-any.whl (100.6 MB)
                           |################################| 100.6 MB 83 kB/s
                      Requirement already satisfied: Click>=6.0 in /usr/lib/python3/dist-packages (from face-recognition) (7.1.2)
                      Requirement already satisfied: v4l2-python3 in /usr/lib/python3/dist-packages (from picamera2) (0.3.2)
                      Building wheels for collected packages: opencv-python
                        Building wheel for opencv-python (PEP 517) ... error
                        ERROR: Command errored out with exit status 1:
                         command: /usr/bin/python3 /tmp/tmpxl4fq1u5_in_process.py build_wheel /tmp/tmpdgg843yi
                             cwd: /tmp/pip-install-681jn0xe/opencv-python_e610009f30624d9ea2b1e3ef82a9824f
                        Complete output (11 lines):
                        patching file opencv/3rdparty/openexr/IlmImf/ImfSystemSpecific.cpp
                        /tmp/pip-build-env-im9uh8sr/overlay/lib/python3.9/site-packages/cmake/data/bin/cmake: error while loading shared libraries: libssl.so.3: cannot open shared object file: No such file or directory
                          File "/tmp/pip-build-env-im9uh8sr/overlay/lib/python3.9/site-packages/skbuild/setuptools_wrap.py", line 639, in setup
                            cmkr = cmaker.CMaker(cmake_executable)
                          File "/tmp/pip-build-env-im9uh8sr/overlay/lib/python3.9/site-packages/skbuild/cmaker.py", line 145, in __init__
                            self.cmake_version = get_cmake_version(self.cmake_executable)
                          File "/tmp/pip-build-env-im9uh8sr/overlay/lib/python3.9/site-packages/skbuild/cmaker.py", line 102, in get_cmake_version
                            raise SKBuildError(msg) from err
                        Problem with the CMake installation, aborting build. CMake executable is /tmp/pip-build-env-im9uh8sr/overlay/lib/python3.9/site-packages/cmake/data/bin/cmake
                        ERROR: Failed building wheel for opencv-python
                      Failed to build opencv-python
                      ERROR: Could not build wheels for opencv-python which use PEP 517 and cannot be installed directly
                        monark @sdetweil
                        @sdetweil maybe the problem is i have libcamera-still (rpi4, bulleye, 32bit, camera v3)
                          sdetweil @monark
                            monark @sdetweil
                            @sdetweil it’s strange because I’ve updated everything
                              monark @sdetweil
                              @sdetweil i try with sudo apt install libssl.so.3 but not working “impossible find the packet”
                                sdetweil @monark
                                @monark google search
                                  sdetweil @monark
                                  @monark the collection of dependencies is not complete, don’t know where it got dropped
                                    monark @sdetweil
                                    @sdetweil change to opencv-python from opencv-python-headless…
                                    I’m try to find with google but it seems they are talking about something else (SSL). anyway you recommended me to use this form because it explained how to install and it was easier…
                                      sdetweil @monark
                                      @monark said in MagicMirror With Face Recognition:
                                      and it was easier
                                      I didn’t say perfect… opencv setup is a pain in the rear
                                      • T
                                        toxeek
                                        That mirror looks huge, what did you use as display to place behind the mirror? A huge monitor/tv?
                                          chris1971
                                          Which weather module do you use? Could it be used for Germany?
