    MagicMirror With Face Recognition
    22 Posts 9 Posters 8.0k Views 9 Watching
    • mariosgourosM Offline
      mariosgouros
      Really great and unique idea!
      • O Offline
        OliWer @sdetweil
        This looks pretty cool. Nice work with the styling.
        Can you let me know which hardware you are using? Like the sensors and where is MM running on?
        • SnilleS Offline
          Snille Module Developer
          Nicely done!
          What computer hardware are you using? RPi5?
          If you cant find it, make it and share it!
          Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
            mchan @Snille
            @Snille @OliWer Here is the hardware for the project:
            • Raspberry Pi 4
            • Raspberry Pi Camera Module 3 (used for face recognition)
            • GroveGesture Sensor (Used for swipe commands)
            • I think the mirror was originally from IKEA. I swapped out the mirror with a piece of MirrorView glass
            M 1 Reply Last reply Reply Quote 3
              monark @mchan
              @mchan hi man, is awesome mirror.
              Can you explain how you did it with opencv?
              i get to the point of installing that and then i stop and it messes up the system and i have to do it all over again every time. i use an rpi4 and now i have a v3 camera, before i had a v2 camera.
              thank you for answer me
                cyberphox
                Get a GitHub and share that config! Wow!
                  sdetweil @monark
                  @monark MMM-FaceReco-DNN has the whole setup to use CV and face database
                    monark @sdetweil
                    @sdetweil my cmd error
                    pip install face-recognition numpy dlib picamera2 opencv-python
                    Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                    Collecting face-recognition
                      Downloading https://www.piwheels.org/simple/face-recognition/face_recognition-1.3.0-py2.py3-none-any.whl (15 kB)
                    Requirement already satisfied: numpy in /usr/lib/python3/dist-packages (1.19.5)
                    Collecting dlib
                      Downloading https://www.piwheels.org/simple/dlib/dlib-19.24.6-cp39-cp39-linux_armv7l.whl (3.4 MB)
                         |################################| 3.4 MB 1.3 MB/s
                    Requirement already satisfied: picamera2 in /usr/lib/python3/dist-packages (0.3.12)
                    Collecting opencv-python
                      Downloading opencv-python-4.10.0.84.tar.gz (95.1 MB)
                         |################################| 95.1 MB 59 kB/s
                      Installing build dependencies ... done
                      Getting requirements to build wheel ... done
                        Preparing wheel metadata ... done
                    Requirement already satisfied: Pillow in /usr/lib/python3/dist-packages (from face-recognition) (8.1.2)
                    Collecting face-recognition-models>=0.3.0
                      Downloading https://www.piwheels.org/simple/face-recognition-models/face_recognition_models-0.3.0-py2.py3-none-any.whl (100.6 MB)
                         |################################| 100.6 MB 83 kB/s
                    Requirement already satisfied: Click>=6.0 in /usr/lib/python3/dist-packages (from face-recognition) (7.1.2)
                    Requirement already satisfied: v4l2-python3 in /usr/lib/python3/dist-packages (from picamera2) (0.3.2)
                    Building wheels for collected packages: opencv-python
                      Building wheel for opencv-python (PEP 517) ... error
                      ERROR: Command errored out with exit status 1:
                       command: /usr/bin/python3 /tmp/tmpxl4fq1u5_in_process.py build_wheel /tmp/tmpdgg843yi
                           cwd: /tmp/pip-install-681jn0xe/opencv-python_e610009f30624d9ea2b1e3ef82a9824f
                      Complete output (11 lines):
                      patching file opencv/3rdparty/openexr/IlmImf/ImfSystemSpecific.cpp
                      /tmp/pip-build-env-im9uh8sr/overlay/lib/python3.9/site-packages/cmake/data/bin/cmake: error while loading shared libraries: libssl.so.3: cannot open shared object file: No such file or directory
                        File "/tmp/pip-build-env-im9uh8sr/overlay/lib/python3.9/site-packages/skbuild/setuptools_wrap.py", line 639, in setup
                          cmkr = cmaker.CMaker(cmake_executable)
                        File "/tmp/pip-build-env-im9uh8sr/overlay/lib/python3.9/site-packages/skbuild/cmaker.py", line 145, in __init__
                          self.cmake_version = get_cmake_version(self.cmake_executable)
                        File "/tmp/pip-build-env-im9uh8sr/overlay/lib/python3.9/site-packages/skbuild/cmaker.py", line 102, in get_cmake_version
                          raise SKBuildError(msg) from err
                      Problem with the CMake installation, aborting build. CMake executable is /tmp/pip-build-env-im9uh8sr/overlay/lib/python3.9/site-packages/cmake/data/bin/cmake
                      ERROR: Failed building wheel for opencv-python
                    Failed to build opencv-python
                    ERROR: Could not build wheels for opencv-python which use PEP 517 and cannot be installed directly
                      monark @sdetweil
                      @sdetweil maybe the problem is i have libcamera-still (rpi4, bulleye, 32bit, camera v3)
                        sdetweil @monark
