    MagicMirror With Face Recognition
    22 Posts 9 Posters 10.1k Views 9 Watching
      mchan
      This is my first Magic Mirror project. Here’s a video of how it looks when it’s running:
      https://youtube.com/shorts/tneDVz6mku8
      It utilizes the following existing modules with slight modifications and styling
      Clock
      Used as is with some CSS styling
      Weather
      Adjusted the layout and styling of the module and added the hourly forecast section
      Calendar
      Adjusted the layout and styling of the module to highlight the first item in the calendar.
      MMM-Videoplayer
      Used this module to display a new ASL video each day from a library of videos stored locally. The playing of the video is controlled through the gesture sensor.
      MMM-GroveGestures
      Uses the GroveGesture Sensor(PAJ7620u2) to register a swipe which activates the ASL sign of the day module. Currently this is the only swipe gesture being used.
      MMM-Face-Recognition-SMAI
      Uses a Camera Module 3 and Open CV to recognize faces and then sends an HDMI CEC command to turn the screen on or off.
      The face recognition was one of the most difficult parts because, while the module is fairly simply, it assumes that you’ve installed OpenCV and trained a face recognition model which took me a bit of research and few tries to figure out and get right. Overall I’m pretty happy with the outcome.
      Hardware
      (updated since I forgot to post it originally)
      • Raspberry Pi 4
      • Raspberry Pi Camera Module 3 (used for face recognition)
      • GroveGesture Sensor (Used for swipe commands)
      • I think the mirror was originally from IKEA. I swapped out the mirror with a piece of MirrorView glass
      S 1 Reply Last reply Reply Quote 12
        sdetweil @mchan
        @mchan Do you use reco-SMAI to provide different modules to different users like reco-dnn?
          mchan @sdetweil
          @sdetweil Not currently. Right now it is just used to turn the screen on when it detects a recognized user and then turn the screen off when no recognized users are present. It can definitely be used to display different modules per user but I’ve not had the time to put additional modules in place.
            sdetweil @mchan
            @mchan cool.
            • mariosgourosM Offline
              mariosgouros
              Really great and unique idea!
              • O Offline
                OliWer @sdetweil
                This looks pretty cool. Nice work with the styling.
                Can you let me know which hardware you are using? Like the sensors and where is MM running on?
                • SnilleS Offline
                  Snille Module Developer
                  Nicely done!
                  What computer hardware are you using? RPi5?
                    mchan @Snille
                    @Snille @OliWer Here is the hardware for the project:
                    • Raspberry Pi 4
                    M 1 Reply Last reply Reply Quote 3
                      monark @mchan
                      @mchan hi man, is awesome mirror.
                      Can you explain how you did it with opencv?
                      i get to the point of installing that and then i stop and it messes up the system and i have to do it all over again every time. i use an rpi4 and now i have a v3 camera, before i had a v2 camera.
                      thank you for answer me
                        cyberphox
                        Get a GitHub and share that config! Wow!
                          sdetweil @monark
                          @monark MMM-FaceReco-DNN has the whole setup to use CV and face database
                            monark @sdetweil
                            @sdetweil my cmd error
                            pip install face-recognition numpy dlib picamera2 opencv-python
                            Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                            Collecting face-recognition
                              Downloading https://www.piwheels.org/simple/face-recognition/face_recognition-1.3.0-py2.py3-none-any.whl (15 kB)
                            Requirement already satisfied: numpy in /usr/lib/python3/dist-packages (1.19.5)
                            Collecting dlib
                              Downloading https://www.piwheels.org/simple/dlib/dlib-19.24.6-cp39-cp39-linux_armv7l.whl (3.4 MB)
                                 |################################| 3.4 MB 1.3 MB/s
                            Requirement already satisfied: picamera2 in /usr/lib/python3/dist-packages (0.3.12)
                            Collecting opencv-python
                              Downloading opencv-python-4.10.0.84.tar.gz (95.1 MB)
                                 |################################| 95.1 MB 59 kB/s
                              Installing build dependencies ... done
                              Getting requirements to build wheel ... done
                                Preparing wheel metadata ... done
                            Requirement already satisfied: Pillow in /usr/lib/python3/dist-packages (from face-recognition) (8.1.2)
                            Collecting face-recognition-models>=0.3.0
                              Downloading https://www.piwheels.org/simple/face-recognition-models/face_recognition_models-0.3.0-py2.py3-none-any.whl (100.6 MB)
                                 |################################| 100.6 MB 83 kB/s
                            Requirement already satisfied: Click>=6.0 in /usr/lib/python3/dist-packages (from face-recognition) (7.1.2)
                            Requirement already satisfied: v4l2-python3 in /usr/lib/python3/dist-packages (from picamera2) (0.3.2)
                            Building wheels for collected packages: opencv-python
                              Building wheel for opencv-python (PEP 517) ... error
                              ERROR: Command errored out with exit status 1:
                               command: /usr/bin/python3 /tmp/tmpxl4fq1u5_in_process.py build_wheel /tmp/tmpdgg843yi
                                   cwd: /tmp/pip-install-681jn0xe/opencv-python_e610009f30624d9ea2b1e3ef82a9824f
                              Complete output (11 lines):
                              patching file opencv/3rdparty/openexr/IlmImf/ImfSystemSpecific.cpp
                              /tmp/pip-build-env-im9uh8sr/overlay/lib/python3.9/site-packages/cmake/data/bin/cmake: error while loading shared libraries: libssl.so.3: cannot open shared object file: No such file or directory
                                File "/tmp/pip-build-env-im9uh8sr/overlay/lib/python3.9/site-packages/skbuild/setuptools_wrap.py", line 639, in setup
                                  cmkr = cmaker.CMaker(cmake_executable)
                                File "/tmp/pip-build-env-im9uh8sr/overlay/lib/python3.9/site-packages/skbuild/cmaker.py", line 145, in __init__
                                  self.cmake_version = get_cmake_version(self.cmake_executable)
                                File "/tmp/pip-build-env-im9uh8sr/overlay/lib/python3.9/site-packages/skbuild/cmaker.py", line 102, in get_cmake_version
                                  raise SKBuildError(msg) from err
                              Problem with the CMake installation, aborting build. CMake executable is /tmp/pip-build-env-im9uh8sr/overlay/lib/python3.9/site-packages/cmake/data/bin/cmake
                              ERROR: Failed building wheel for opencv-python
                            Failed to build opencv-python
                            ERROR: Could not build wheels for opencv-python which use PEP 517 and cannot be installed directly
                              monark @sdetweil
                              @sdetweil maybe the problem is i have libcamera-still (rpi4, bulleye, 32bit, camera v3)
                                sdetweil @monark
                                  monark @sdetweil
                                  @sdetweil it’s strange because I’ve updated everything
                                    monark @sdetweil
                                    @sdetweil i try with sudo apt install libssl.so.3 but not working “impossible find the packet”
                                      sdetweil @monark
                                      @monark google search
                                        sdetweil @monark
                                        @monark the collection of dependencies is not complete, don’t know where it got dropped
                                          monark @sdetweil
                                          @sdetweil change to opencv-python from opencv-python-headless…
                                          I’m try to find with google but it seems they are talking about something else (SSL). anyway you recommended me to use this form because it explained how to install and it was easier…
                                            sdetweil @monark
                                            @monark said in MagicMirror With Face Recognition:
                                            and it was easier
                                            I didn’t say perfect… opencv setup is a pain in the rear
