    MMM-OpenWeatherForecast
    92 Posts 14 Posters 68.3k Views 14 Watching
      Ray @sdetweil
      @sdetweil I also updated the configuration to version 3.0
      and then got a new app key when I got the new app key it didn’t work
      I only have two apt keys and I created a new one
        sdetweil @Ray
        @Ray yes, many of the apis we use have gone to pay for models. i would plan for more doing the same
        there are still some free. Piratesky has a clone of the older Darksky api. check the module list, shown in the header above for the modules using that
        R 1 Reply Last reply
          Ray @sdetweil
          @sdetweil that’s sad everybody wants money these days
          thank you for your help I will certainly try Piratesky
            sdetweil @Ray
            @Ray to be fair, it costs money to provide the api. especially as the amount of traffic increases.
            we were notified by calendarlabs (holiday calendar used as default), that a lot of MagicMirror systems were requesting the calendar every 5 minutes. we changed our rate to once a week, maybe still too fast.
              Ray @sdetweil
              @sdetweil I am always want to pay for really good service I’ve even been known to donate to the cause which in something like this I think would be more beneficial
                Rakutsi
                I had the same problem . Solved it by adding
                apiVersion: “2.5”,
                Since the default changed from 2.5 to 3.0
                S R 2 Replies Last reply
                Reply Quote 2
                  sdetweil @Rakutsi
                  @Rakutsi the 2.5 api is dead, for a couple months now
                    Rakutsi @Rakutsi
                    @sdetweil just wanted to say that it worked for me to do that.
                    I am new with posting here.
                    Reply Quote 2
                      megagprime
                      I am also struggling with the new api call. I have set the apiBaseURL string and tried a new api key, but still not loading. The openweather site is a bit confusing, how do i make an V3 api key? i only see option for new key. Thanks
                        sdetweil @megagprime
                        @megagprime you have to
                        provide a credit card in case you go over the 1000 requests per day limit
                        M 2 Replies Last reply
                          megagprime @sdetweil
                          @sdetweil i did that and have it subscribed, my old key doesnt work and neither does my new key
                              @megagprime comment out the apibase, let the module set it
                              M 1 Reply Last reply
                                MarcLandis Module Developer @sdetweil
                                @sdetweil MMM-OpenWeatherForecast has V2.5 as default.
                                M M 2 Replies Last reply
                                  megagprime @MarcLandis
                                  @MarcLandis yes we need 3.0
                                    MarcLandis Module Developer @MarcLandis
                                    @sdetweil https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast/blob/master/MMM-OpenWeatherForecast.js#L53
                                      sdetweil @MarcLandis
                                      @MarcLandis shocking, Tom is usually not behind like that
                                      i haven’t checked, is the url unchanged except for the version number?
                                        @sdetweil tom has new url in readme apiBaseURL for opencall3
                                          @sdetweil yes - all that is needed is …/2.5/… -> …/3.0/…
                                            @MarcLandis ok. i have seen some other users post that it had taken some time before the new key worked.
                                            without debugging hard to tell. i expect the fetch would fail 401. authentication failed
                                            O 1 Reply Last reply
                                            • 1 / 5
