    MMM-OpenWeatherForecast
    92 Posts 14 Posters 68.3k Views 14 Watching
      Ray @ForestQ
      @ForestQ so if I’m understanding this correctly
      it won’t work unless I pay for?
        sdetweil @Ray
        @Ray @ForestQ openweather has gone to a new model.
        they count the number of api requests. with a certain number not charged. today they allow 1000 calls per day before charging .
        BUT , you must supply the card they will charge against to make any calls.
        R 2 Replies Last reply
          Ray @sdetweil
          @sdetweil well how nice is that all these years it was free now you have to pay for
            Ray @sdetweil
            @sdetweil I also updated the configuration to version 3.0
            and then got a new app key when I got the new app key it didn’t work
            I only have two apt keys and I created a new one
              sdetweil @Ray
              @Ray yes, many of the apis we use have gone to pay for models. i would plan for more doing the same
              there are still some free. Piratesky has a clone of the older Darksky api. check the module list, shown in the header above for the modules using that
              R 1 Reply Last reply
                Ray @sdetweil
                @sdetweil that’s sad everybody wants money these days
                thank you for your help I will certainly try Piratesky
                  sdetweil @Ray
                  @Ray to be fair, it costs money to provide the api. especially as the amount of traffic increases.
                  we were notified by calendarlabs (holiday calendar used as default), that a lot of MagicMirror systems were requesting the calendar every 5 minutes. we changed our rate to once a week, maybe still too fast.
                    Ray @sdetweil
                    @sdetweil I am always want to pay for really good service I’ve even been known to donate to the cause which in something like this I think would be more beneficial
                      Rakutsi
                      I had the same problem . Solved it by adding
                      apiVersion: “2.5”,
                      Since the default changed from 2.5 to 3.0
                      S R 2 Replies Last reply
                      Reply Quote 2
                        sdetweil @Rakutsi
                        @Rakutsi the 2.5 api is dead, for a couple months now
                          Rakutsi @Rakutsi
                          @sdetweil just wanted to say that it worked for me to do that.
                          I am new with posting here.
                          Reply Quote 2
                            megagprime
                            I am also struggling with the new api call. I have set the apiBaseURL string and tried a new api key, but still not loading. The openweather site is a bit confusing, how do i make an V3 api key? i only see option for new key. Thanks
                              sdetweil @megagprime
                              @megagprime you have to
                              provide a credit card in case you go over the 1000 requests per day limit
                              M 2 Replies Last reply
                                megagprime @sdetweil
                                @sdetweil i did that and have it subscribed, my old key doesnt work and neither does my new key
                                    @megagprime comment out the apibase, let the module set it
                                    M 1 Reply Last reply
                                      MarcLandis Module Developer @sdetweil
                                      @sdetweil MMM-OpenWeatherForecast has V2.5 as default.
                                      M M 2 Replies Last reply
                                        megagprime @MarcLandis
                                        @MarcLandis yes we need 3.0
                                          MarcLandis Module Developer @MarcLandis
                                          @sdetweil https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast/blob/master/MMM-OpenWeatherForecast.js#L53
                                            sdetweil @MarcLandis
                                            @MarcLandis shocking, Tom is usually not behind like that
                                            i haven’t checked, is the url unchanged except for the version number?
                                            • 1 / 5
