    MMM-OpenWeatherForecast
    92 Posts 14 Posters 66.6k Views 14 Watching
      sdetweil @Ray
      @Ray to be fair, it costs money to provide the api. especially as the amount of traffic increases.
      we were notified by calendarlabs (holiday calendar used as default), that a lot of MagicMirror systems were requesting the calendar every 5 minutes. we changed our rate to once a week, maybe still too fast.
        Ray @sdetweil
        @sdetweil I am always want to pay for really good service I’ve even been known to donate to the cause which in something like this I think would be more beneficial
          Rakutsi
          I had the same problem . Solved it by adding
          apiVersion: “2.5”,
          Since the default changed from 2.5 to 3.0
          S R 2 Replies Last reply Reply Quote 2
            sdetweil @Rakutsi
            @Rakutsi the 2.5 api is dead, for a couple months now
              Rakutsi @Rakutsi
              @sdetweil just wanted to say that it worked for me to do that.
              I am new with posting here.
                megagprime
                I am also struggling with the new api call. I have set the apiBaseURL string and tried a new api key, but still not loading. The openweather site is a bit confusing, how do i make an V3 api key? i only see option for new key. Thanks
                  sdetweil @megagprime
                  @megagprime you have to
                  provide a credit card in case you go over the 1000 requests per day limit
                    megagprime @sdetweil
                    @sdetweil i did that and have it subscribed, my old key doesnt work and neither does my new key
                        @megagprime comment out the apibase, let the module set it
                          MarcLandis Module Developer @sdetweil
                          @sdetweil MMM-OpenWeatherForecast has V2.5 as default.
                          M M 2 Replies Last reply Reply Quote 0
                            megagprime @MarcLandis
                            @MarcLandis yes we need 3.0
                              MarcLandis Module Developer @MarcLandis
                              @sdetweil https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast/blob/master/MMM-OpenWeatherForecast.js#L53
                                sdetweil @MarcLandis
                                @MarcLandis shocking, Tom is usually not behind like that
                                i haven’t checked, is the url unchanged except for the version number?
                                  @sdetweil tom has new url in readme apiBaseURL for opencall3
                                    @sdetweil yes - all that is needed is …/2.5/… -> …/3.0/…
                                      @MarcLandis ok. i have seen some other users post that it had taken some time before the new key worked.
                                      without debugging hard to tell. i expect the fetch would fail 401. authentication failed
                                      • O
                                        OldGuyBerlin @sdetweil
                                        It seems the default API was changed from 2.5 to 3.0 with the recent update. Even it is (not yet) in the documentation.
                                        Here is what I did:
                                        I inserted in the config.js
                                        apiVersion: "2.5",
                                        Since the problem occurred after the recent MM2 Update (and worked fine until then) it was clear, that the update has some doing in that.
                                        Even if the 2.5 API should be down, it is working just fine.
                                        After this change, it works (again) like charm.
                                        S H 2 Replies Last reply Reply Quote 1
                                          sdetweil @OldGuyBerlin
                                          @OldGuyBerlin the doc for 2.29 today
                                          • O
                                            Didn’t see this until now.
                                            That is why the workaround with the API Version works. ;-)
                                            • 2 / 5
