    MMM-OpenWeatherForecast
    92 Posts 14 Posters 68.3k Views 14 Watching
      MarcLandis Module Developer @sdetweil
      @sdetweil MMM-OpenWeatherForecast has V2.5 as default.
      M M 2 Replies Last reply
        megagprime @MarcLandis
        @MarcLandis yes we need 3.0
          MarcLandis Module Developer @MarcLandis
          @sdetweil https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast/blob/master/MMM-OpenWeatherForecast.js#L53
            sdetweil @MarcLandis
            @MarcLandis shocking, Tom is usually not behind like that
            i haven’t checked, is the url unchanged except for the version number?
              megagprime @sdetweil
              @sdetweil tom has new url in readme apiBaseURL for opencall3
                @sdetweil yes - all that is needed is …/2.5/… -> …/3.0/…
                  @MarcLandis ok. i have seen some other users post that it had taken some time before the new key worked.
                  without debugging hard to tell. i expect the fetch would fail 401. authentication failed
                  O 1 Reply Last reply
                  • O
                    OldGuyBerlin @sdetweil
                    It seems the default API was changed from 2.5 to 3.0 with the recent update. Even it is (not yet) in the documentation.
                    Here is what I did:
                    I inserted in the config.js
                    apiVersion: "2.5",
                    Since the problem occurred after the recent MM2 Update (and worked fine until then) it was clear, that the update has some doing in that.
                    Even if the 2.5 API should be down, it is working just fine.
                    After this change, it works (again) like charm.
                    S H 2 Replies Last reply
                      sdetweil @OldGuyBerlin
                      @OldGuyBerlin the doc for 2.29 today
                      • O
                        Didn’t see this until now.
                        That is why the workaround with the API Version works. ;-)
                          Ray
                          So let me add one more thing here if I can
                          if I give these guys my credit card just in case I go over
                          where in MMM-OpenWeatherForecast will it tell me how many calls it made
                          M S 2 Replies Last reply
                            MarcLandis Module Developer @Ray
                            @Ray the number of calls depend on the update intervall you set in your config. For example if you have it update every 10 minutes it will be 144 calls a day.
                            R 2 Replies Last reply
                              Ray @MarcLandis
                              @MarcLandis 000 I did not know that thanks for the update that makes a big difference
                                sdetweil @Ray
                                @Ray they do have an activity page
                                R 1 Reply Last reply
                                  Ray @sdetweil
                                  @sdetweil okay that’s good to know to
                                    megagprime
                                    we still dont have a fix here, ive tried all this and still wont load
                                    wishmaster270W 1 Reply Last reply
                                      Ray @MarcLandis
                                      @MarcLandis okay so forgive me for being ignorant here
                                      I’m having problem with the math here
                                      if I sit for 15 minutes that would be 96 calls is that correct
                                        sdetweil @Ray
                                        @Ray 24x4, yes
                                          Ray @sdetweil
                                          @sdetweil thank you
                                          I actually did the long way
                                          144÷15 gave me 96
                                          • wishmaster270W
                                            wishmaster270 Module Developer @megagprime
                                            @megagprime
                                            Hi and sorry for the late reply.
                                            I am pretty busy with my kids and do not have much time to code at the moments.
                                            I changed the default url of the module to version 3.0 as 2.5 has been shut down in June.
                                            I also updated the Readme to respect the latest changes.
                                            Are you sure you use my fork of the module and not the original one?
                                            The url of my fork is https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast/blob/master/README.md
                                            • 2 / 5
