    MMM-OpenWeatherForecast
    92 Posts 14 Posters 68.3k Views 14 Watching
      sdetweil @MarcLandis
      @MarcLandis ok. i have seen some other users post that it had taken some time before the new key worked.
      without debugging hard to tell. i expect the fetch would fail 401. authentication failed
      O 1 Reply Last reply
      • O
        OldGuyBerlin @sdetweil
        It seems the default API was changed from 2.5 to 3.0 with the recent update. Even it is (not yet) in the documentation.
        Here is what I did:
        I inserted in the config.js
        apiVersion: "2.5",
        Since the problem occurred after the recent MM2 Update (and worked fine until then) it was clear, that the update has some doing in that.
        Even if the 2.5 API should be down, it is working just fine.
        After this change, it works (again) like charm.
        S H 2 Replies Last reply
          sdetweil @OldGuyBerlin
          @OldGuyBerlin the doc for 2.29 today
          • O
            Didn’t see this until now.
            That is why the workaround with the API Version works. ;-)
              Ray
              So let me add one more thing here if I can
              if I give these guys my credit card just in case I go over
              where in MMM-OpenWeatherForecast will it tell me how many calls it made
              M S 2 Replies Last reply
                MarcLandis Module Developer @Ray
                @Ray the number of calls depend on the update intervall you set in your config. For example if you have it update every 10 minutes it will be 144 calls a day.
                R 2 Replies Last reply
                  Ray @MarcLandis
                  @MarcLandis 000 I did not know that thanks for the update that makes a big difference
                    sdetweil @Ray
                    @Ray they do have an activity page
                    R 1 Reply Last reply
                      Ray @sdetweil
                      @sdetweil okay that’s good to know to
                        megagprime
                        we still dont have a fix here, ive tried all this and still wont load
                        wishmaster270W 1 Reply Last reply
                          Ray @MarcLandis
                          @MarcLandis okay so forgive me for being ignorant here
                          I’m having problem with the math here
                          if I sit for 15 minutes that would be 96 calls is that correct
                            sdetweil @Ray
                            @Ray 24x4, yes
                              Ray @sdetweil
                              @sdetweil thank you
                              I actually did the long way
                              144÷15 gave me 96
                              • wishmaster270W
                                wishmaster270 Module Developer @megagprime
                                @megagprime
                                Hi and sorry for the late reply.
                                I am pretty busy with my kids and do not have much time to code at the moments.
                                I changed the default url of the module to version 3.0 as 2.5 has been shut down in June.
                                I also updated the Readme to respect the latest changes.
                                Are you sure you use my fork of the module and not the original one?
                                The url of my fork is https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast/blob/master/README.md
                                  Ray @wishmaster270
                                  @wishmaster270 I am definitely using the original one version 2.5
                                  I am looking into signing up for the 3.0 app key
                                  it just caught me off guard just all of a sudden stopped two days ago with no warning or anything that would’ve been nice and I’m talking about the website not you
                                    sdetweil @Ray
                                    @Ray the website warned 2.5 end of life was back in june
                                      Ray @sdetweil
                                      @sdetweil well that’s what everyone has been saying mines been working for several years until just two or three days ago when all of a sudden it just stopped I guess it took a while for them to find me LOL
                                        Ray
                                        So I went ahead and applied for the app 3.0
                                        and gave them my credit card
                                        and it was extremely easy to do
                                        I did not have to create a new app key I was able to use my original ones
                                        I also change the number of calls from 10 minutes to 15 minutes
                                        and I added “https://api.openweathermap.org/data/3.0/onecall?”
                                        In the node_helper.js
                                        thanks to everyone here I was successful
                                        my two systems are back online showing the current temperature
                                        S J 2 Replies Last reply
                                          sdetweil @Ray
                                          @Ray said in MMM-OpenWeatherForecast:
                                          if you change to the latest version/fork of the module you do not need to do that
                                            Ray @sdetweil
                                            I was under the impression that I had to do that in order for it to work
                                            so I don’t understand what you mean what other way is there
                                            • 2 / 5
