    MMM-OpenWeatherForecast
    92 Posts 14 Posters 64.2k Views 14 Watching
      megagprime @MarcLandis
      @MarcLandis yes we need 3.0
        MarcLandis Module Developer @MarcLandis
        @sdetweil https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast/blob/master/MMM-OpenWeatherForecast.js#L53
          sdetweil @MarcLandis
          @MarcLandis shocking, Tom is usually not behind like that
          i haven’t checked, is the url unchanged except for the version number?
          M M 2 Replies Last reply Reply Quote 0
            megagprime @sdetweil
            @sdetweil tom has new url in readme apiBaseURL for opencall3
              MarcLandis Module Developer @sdetweil
              @sdetweil yes - all that is needed is …/2.5/… -> …/3.0/…
                @MarcLandis ok. i have seen some other users post that it had taken some time before the new key worked.
                without debugging hard to tell. i expect the fetch would fail 401. authentication failed
                • O Offline
                  OldGuyBerlin @sdetweil
                  It seems the default API was changed from 2.5 to 3.0 with the recent update. Even it is (not yet) in the documentation.
                  Here is what I did:
                  I inserted in the config.js
                  apiVersion: "2.5",
                  Since the problem occurred after the recent MM2 Update (and worked fine until then) it was clear, that the update has some doing in that.
                  Even if the 2.5 API should be down, it is working just fine.
                  After this change, it works (again) like charm.
                  S H 2 Replies Last reply Reply Quote 1
                    sdetweil @OldGuyBerlin
                    @OldGuyBerlin the doc for 2.29 today
                    • O Offline
                      Didn’t see this until now.
                      That is why the workaround with the API Version works. ;-)
                        Ray
                        So let me add one more thing here if I can
                        if I give these guys my credit card just in case I go over
                        where in MMM-OpenWeatherForecast will it tell me how many calls it made
                        M S 2 Replies Last reply Reply Quote 0
                          MarcLandis Module Developer @Ray
                          @Ray the number of calls depend on the update intervall you set in your config. For example if you have it update every 10 minutes it will be 144 calls a day.
                            Ray @MarcLandis
                            @MarcLandis 000 I did not know that thanks for the update that makes a big difference
                              sdetweil @Ray
                              @Ray they do have an activity page
                                Ray @sdetweil
                                @sdetweil okay that’s good to know to
                                  megagprime
                                  we still dont have a fix here, ive tried all this and still wont load
                                    Ray @MarcLandis
                                    @MarcLandis okay so forgive me for being ignorant here
                                    I’m having problem with the math here
                                    if I sit for 15 minutes that would be 96 calls is that correct
                                      sdetweil @Ray
                                      @Ray 24x4, yes
                                        Ray @sdetweil
                                        @sdetweil thank you
                                        I actually did the long way
                                        144÷15 gave me 96
                                        • wishmaster270W Offline
                                          wishmaster270 Module Developer @megagprime
                                          @megagprime
                                          Hi and sorry for the late reply.
                                          I am pretty busy with my kids and do not have much time to code at the moments.
                                          I changed the default url of the module to version 3.0 as 2.5 has been shut down in June.
                                          I also updated the Readme to respect the latest changes.
                                          Are you sure you use my fork of the module and not the original one?
                                          The url of my fork is https://github.com/Tom-Hirschberger/MMM-OpenWeatherForecast/blob/master/README.md
                                            Ray @wishmaster270
                                            @wishmaster270 I am definitely using the original one version 2.5
                                            I am looking into signing up for the 3.0 app key
                                            it just caught me off guard just all of a sudden stopped two days ago with no warning or anything that would’ve been nice and I’m talking about the website not you
                                            • 2 / 5
