    MMM-OpenWeatherForecast
    92 Posts 14 Posters 48.2k Views 14 Watching
    • F Offline
      froboz @Ray
      @Ray I have the same issue right after I did the upgrade. I came here to check and the first post I see describes the exact issue I have.
        sdetweil @froboz
        @froboz @Ray and you both opened new 3.0 apikeys, right? its required
          MarcLandis Module Developer @sdetweil
          @froboz @Ray make sure you have the following parameter in your config:
          apiBaseURL: “https://api.openweathermap.org/data/3.0/onecall?”
          and get a V3 API key from https://openweathermap.org/
          R F 2 Replies Last reply Reply Quote 0
            Ray @MarcLandis
            @MarcLandis I haven’t done any updates on my two mirrors for several years now because they’ve been working just fine
            so I’m pretty sure I do not have version 3
            • F Offline
              ForestQ @MarcLandis
              Are V3 APIs paid-only?
                Ray @ForestQ
                @ForestQ so if I’m understanding this correctly
                it won’t work unless I pay for?
                  sdetweil @Ray
                  @Ray @ForestQ openweather has gone to a new model.
                  they count the number of api requests. with a certain number not charged. today they allow 1000 calls per day before charging .
                  BUT , you must supply the card they will charge against to make any calls.
                    Ray @sdetweil
                    @sdetweil well how nice is that all these years it was free now you have to pay for
                      Ray @sdetweil
                      @sdetweil I also updated the configuration to version 3.0
                      and then got a new app key when I got the new app key it didn’t work
                      I only have two apt keys and I created a new one
                        sdetweil @Ray
                        @Ray yes, many of the apis we use have gone to pay for models. i would plan for more doing the same
                        there are still some free. Piratesky has a clone of the older Darksky api. check the module list, shown in the header above for the modules using that
                        • 10
                        • 1 / 10
