    MMM-OpenWeatherForecast
    92 Posts 14 Posters 50.6k Views 14 Watching
      Ray
      Does anyone know what’s going on with MMM-OpenWeatherForecast
      all I’m getting is its loading
      even on my virtual mirror it’s doing exactly the same thing
      I tried different coordinates and it is doing the seem thing
      I went to the website and everything checks out just fine my app key is still intact and I can see the current weather on their weather map
      so I am at a loss on what’s going on here
      			disabled: false,
      			module: "MMM-OpenWeatherForecast",
      			header: "Concord/Walnut Creek",
      				apikey: " ",     // only string here
      				latitude: 37.9780 ,                             // Concord's coordinates
      				longitude: -122.0311 ,
      			    units: "imperial",
      			    iconset: "3c",
      			    requestDelay: 250,                              // requestDelay In milliseconds
      			    useAnimatedIcons: true,                         // animation can only be on one
                      updateInterval: 10,                             // minutes
                      showFeelsLikeTemp: false,
                      showSummary: true,                              // false stop weather alerts from displaying
      		        forecastHeaderText: "Hourly Forecast",          // Text for the header
      				forecastLayout: "tiled",                        // Can be set to tiled or table
      				showHourlyForecast: true,                       // show hourly forecast information
      				hourlyForecastInterval: 3,                      // How many hours apart each listed hourly
      				maxHourliesToShow: 3,                           // How many hourly forecasts
      		        showDailyForecast: false                        // show daily forecast information
      • butchkemperB Offline
        butchkemper @JohnGalt
        @JohnGalt
        The api call daily threshold for billing is 1,000. The default setting is to update every 10 minutes and that equals to 144 daily calls.
        Butch
        Resistance is not Futile!
        It is voltage divided by current.
        • F Offline
          froboz @Ray
          @Ray I have the same issue right after I did the upgrade. I came here to check and the first post I see describes the exact issue I have.
            sdetweil @froboz
            @froboz @Ray and you both opened new 3.0 apikeys, right? its required
              MarcLandis Module Developer @sdetweil
              @froboz @Ray make sure you have the following parameter in your config:
              apiBaseURL: “https://api.openweathermap.org/data/3.0/onecall?”
              and get a V3 API key from https://openweathermap.org/
              R F 2 Replies Last reply Reply Quote 0
                Ray @MarcLandis
                @MarcLandis I haven’t done any updates on my two mirrors for several years now because they’ve been working just fine
                so I’m pretty sure I do not have version 3
                • F Offline
                  ForestQ @MarcLandis
                  Are V3 APIs paid-only?
                    Ray @ForestQ
                    @ForestQ so if I’m understanding this correctly
                    it won’t work unless I pay for?
                      sdetweil @Ray
                      @Ray @ForestQ openweather has gone to a new model.
                      they count the number of api requests. with a certain number not charged. today they allow 1000 calls per day before charging .
                      BUT , you must supply the card they will charge against to make any calls.
                        Ray @sdetweil
                        @sdetweil well how nice is that all these years it was free now you have to pay for
                          Ray @sdetweil
                          @sdetweil I also updated the configuration to version 3.0
                          and then got a new app key when I got the new app key it didn’t work
                          I only have two apt keys and I created a new one
                            sdetweil @Ray
                            @Ray yes, many of the apis we use have gone to pay for models. i would plan for more doing the same
                            there are still some free. Piratesky has a clone of the older Darksky api. check the module list, shown in the header above for the modules using that
                              Ray @sdetweil
                              @sdetweil that’s sad everybody wants money these days
                              thank you for your help I will certainly try Piratesky
                                sdetweil @Ray
                                @Ray to be fair, it costs money to provide the api. especially as the amount of traffic increases.
                                we were notified by calendarlabs (holiday calendar used as default), that a lot of MagicMirror systems were requesting the calendar every 5 minutes. we changed our rate to once a week, maybe still too fast.
                                  Ray @sdetweil
                                  @sdetweil I am always want to pay for really good service I’ve even been known to donate to the cause which in something like this I think would be more beneficial
                                    Rakutsi
                                    I had the same problem . Solved it by adding
                                    apiVersion: “2.5”,
                                    Since the default changed from 2.5 to 3.0
                                    S R 2 Replies Last reply Reply Quote 2
                                      sdetweil @Rakutsi
                                      @Rakutsi the 2.5 api is dead, for a couple months now
                                        Rakutsi @Rakutsi
                                        @sdetweil just wanted to say that it worked for me to do that.
                                        I am new with posting here.
                                          megagprime
                                          I am also struggling with the new api call. I have set the apiBaseURL string and tried a new api key, but still not loading. The openweather site is a bit confusing, how do i make an V3 api key? i only see option for new key. Thanks
                                            sdetweil @megagprime
                                            @megagprime you have to
                                            provide a credit card in case you go over the 1000 requests per day limit
                                              megagprime @sdetweil
                                              @sdetweil i did that and have it subscribed, my old key doesnt work and neither does my new key
                                              • 1 / 5
