    After update 2.29.0 PM2 does not work
    20 Posts 4 Posters 7.1k Views 4 Watching
    • htilburgsH
      htilburgs
      I updated my mirror to latest version 2.29.0 using script SdetWeil
      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
      After reboot, no startup.
      npm start works
      pm2 does not work
      reinstall using script
      bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
      Still no luck. Manual
      pm2 start MagicMirror
      pi@mm:~ $ pm2 start MagicMirror
      [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
      [PM2] [MagicMirror](0) ✓
      [PM2] Process successfully started
      │ id │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
      │ 0  │ MagicMirror    │ default     │ 2.29.0  │ fork    │ 17189    │ 0s     │ 122  │ online    │ 0%       │ 23.1mb   │ pi       │ disabled │
      pi@mm:~ $
      but MagicMirror does not appear on my mirror.
      I have this problem on 2 MagicMirror installations.
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
      htilburgsH 1 Reply Last reply
      • htilburgsH
        htilburgs @sdetweil
        I created the mm.sh script in the /MagicMirror/installers folder (copied from your site) and run the fixuppm2 script again.
        Now it started MagicMirror as normal.
        I tried a reboot and it works now.
        Now only the same on the other MagicMirror screen and I’m happy again.
        If i have to do anything more or reinstall, let me know.
        But it seems I’ve a working installation of MagicMirror again.
        Thanks!!
        S 2 Replies Last reply
        • htilburgsH
          htilburgs @htilburgs
          pm2 logs MagicMirror --lines 100 shows
          0|MagicMirror  | [2024-10-01 21:49:35.228] [LOG]   Starting MagicMirror: v2.29.0
          0|MagicMirror  | [2024-10-01 21:49:35.259] [ERROR] TypeError: Cannot read properties of undefined (reading 'disableHardwareAcceleration')
          0|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:18:6)
          0|MagicMirror  |     at Module._compile (node:internal/modules/cjs/loader:1241:14)
          0|MagicMirror  |     at Module._extensions..js (node:internal/modules/cjs/loader:1295:10)
          0|MagicMirror  |     at Module.load (node:internal/modules/cjs/loader:1091:32)
          0|MagicMirror  |     at Module._load (node:internal/modules/cjs/loader:938:12)
          0|MagicMirror  |     at Object.<anonymous> (/usr/local/lib/node_modules/pm2/lib/ProcessContainerFork.js:33:23)
          0|MagicMirror  |     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:83:12)
          0|MagicMirror  |     at node:internal/main/run_main_module:23:47
          0|MagicMirror  | [2024-10-01 21:49:35.264] [ERROR] Whoops! There was an uncaught exception...
          0|MagicMirror  | [2024-10-01 21:49:35.266] [ERROR] TypeError: Cannot read properties of undefined (reading 'disableHardwareAcceleration')
          0|MagicMirror  | [2024-10-01 21:49:35.267] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          0|MagicMirror  | [2024-10-01 21:49:35.268] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
          0|MagicMirror  | [2024-10-01 21:49:37.131] [INFO]  System information:
          0|MagicMirror  | ### SYSTEM:   manufacturer: ; model: ; virtual: false
          0|MagicMirror  | ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.51-v8+
          0|MagicMirror  | ### VERSIONS: electron: undefined; used node: 20.9.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.2
          0|MagicMirror  | ### OTHER:    timeZone: Europe/Amsterdam; ELECTRON_ENABLE_GPU: undefined
          S M 2 Replies Last reply
            sdetweil @htilburgs
            @htilburgs can you do
            pm2 delete 0
            pm2 save -f
            and then run the fixuppm2 script again
            • butchkemperB
              butchkemper
              I am in the same boat with you. After update to 2.29.0, the ~/.pm2/logs/MagicMirror-error.log has this block of messages continually repeating:
                  at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:15:6)
                  at Module._compile (node:internal/modules/cjs/loader:1469:14)
                  at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
                  at Module.load (node:internal/modules/cjs/loader:1288:32)
                  at Module._load (node:internal/modules/cjs/loader:1104:12)
                  at Object.<anonymous> (/usr/lib/node_modules/pm2/lib/ProcessContainerFork.js:33:23)
                  at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
                  at node:internal/main/run_main_module:28:49
              I made a backup of the MagicMirror directory before updating to the new version. To return to the old version, I deleted the updated MagicMirror directory and restored the backup MM directory but the error persists with V2.28.0. Something outside of the MM directory must have been updated.
              I tried restarting the system but the error continues.
              Butch
              Resistance is not Futile!
              It is voltage divided by current.
                also try
                sudo npm i pm2 -g
                  sdetweil @butchkemper
                  @butchkemper can you do to show the nodejs version
                  node -v
                  • butchkemperB
                    butchkemper
                    pi@MagicMirror:~ $ node -v
                    v20.17.0
                    pi@MagicMirror:~ $
                      MarcLandis Module Developer @htilburgs
                      @htilburgs said in After update 2.29.0 PM2 does not work:
                      for whatever reason MM doesn’t recognises your electron version
                        sdetweil @MarcLandis
                        @MarcLandis yeh weird.
                        grep version node_modules/electron/package.json
                        • butchkemperB
                          butchkemper
                          @sdetweil said in After update 2.29.0 PM2 does not work:
                          This is what I get:
                          pi@MagicMirror:~/MagicMirror $ sudo grep version node_modules/electron/package.json
                            "version": "31.1.0"
                            @butchkemper which is the correct value
                            • butchkemperB
                              butchkemper
                              @butchkemper said in After update 2.29.0 PM2 does not work:
                              Sam, did you see where I mention the problem continues even after I deleted the 2.29.0 MM directory and restored the 2.28.0 directory?
                              Also, I am in the DFW area and available by phone if you would like.
                              Butch
                                @butchkemper i did, but only other thing is nodejs version.
                                can you post the upgrade.log to a new issue for my scripts
                                i have grandchildren duty til tomorrow morning
                                htilburgsH butchkemperB 2 Replies Last reply
                                • htilburgsH
                                  htilburgs @sdetweil
                                  pi@mm:~ $ pm2 delete 0
                                  [PM2] Applying action deleteProcessId on app [0](ids: [ '0' ])
                                  [PM2][WARN] Current process list is not synchronized with saved list. App MagicMirror differs. Type 'pm2 save' to synchronize.
                                  pi@mm:~ $ pm2 save -f
                                  [PM2] Saving current process list...
                                  [PM2] Successfully saved in /home/pi/.pm2/dump.pm2
                                  pi@mm:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                                  the log will be saved in /home/pi/MagicMirror/installers/pm2_setup.log
                                  [PM2][WARN] Applications MagicMirror not running, starting...
                                  [PM2][ERROR] Error: Script not found: /home/pi/MagicMirror/installers/mm.sh
                                  [PM2][WARN] PM2 is not managing any process, skipping save...
                                  [PM2][WARN] To force saving use: pm2 save --force
                                  pi@mm:~ $ node -v
                                  v20.9.0
                                  pi@mm:~ $ grep version node_modules/electron/package.json
                                    "version": "31.6.0"
                                    sdetweil @htilburgs
                                    @htilburgs arrrrrg
                                    we deleted installers folder from the repository
                                    didn’t fix the fixup script
                                    be a couple hours
                                    edit: fixed 17:50 Oct 1
                                    htilburgsH 2 Replies Last reply
                                    • htilburgsH
                                      htilburgs @sdetweil
                                      Oke, no problem.
                                      It’s 22:55 in the Netherlands and have to get up at 05:30, so I go to sleep and check in the morning.
                                      Enjoy your grandchildren ;-) These are more important than a MagicMirror!
                                      • htilburgsH
                                        htilburgs @sdetweil
                                        Thanks!!
                                        • butchkemperB
                                          butchkemper @sdetweil
                                          @sdetweil I have posted a new topic in trouble shooting with the error message and the install log.
                                          The system would not let me send the file as only graphic files are accepted.
                                          Thank you.
                                          Butch
                                            sdetweil @htilburgs
                                            @htilburgs awesome, thx
                                              sdetweil @htilburgs
                                              @htilburgs I have added the mm.sh to fixuppm2.sh
