    After update 2.29.0 PM2 does not work
    20 Posts 4 Posters 7.1k Views 4 Watching
      sdetweil @htilburgs
      @htilburgs can you do
      pm2 delete 0
      pm2 save -f
      and then run the fixuppm2 script again
      • butchkemperB
        butchkemper
        I am in the same boat with you. After update to 2.29.0, the ~/.pm2/logs/MagicMirror-error.log has this block of messages continually repeating:
        [ERROR] TypeError: Cannot read properties of undefined (reading 'disableHardwareAcceleration')
            at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:15:6)
            at Module._compile (node:internal/modules/cjs/loader:1469:14)
            at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
            at Module.load (node:internal/modules/cjs/loader:1288:32)
            at Module._load (node:internal/modules/cjs/loader:1104:12)
            at Object.<anonymous> (/usr/lib/node_modules/pm2/lib/ProcessContainerFork.js:33:23)
            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
            at node:internal/main/run_main_module:28:49
        I made a backup of the MagicMirror directory before updating to the new version. To return to the old version, I deleted the updated MagicMirror directory and restored the backup MM directory but the error persists with V2.28.0. Something outside of the MM directory must have been updated.
        I tried restarting the system but the error continues.
        Butch
        Resistance is not Futile!
        It is voltage divided by current.
          also try
          sudo npm i pm2 -g
            sdetweil @butchkemper
            @butchkemper can you do to show the nodejs version
            node -v
            • butchkemperB
              butchkemper
              pi@MagicMirror:~ $ node -v
              v20.17.0
              pi@MagicMirror:~ $
                MarcLandis Module Developer @htilburgs
                @htilburgs said in After update 2.29.0 PM2 does not work:
                VERSIONS: electron: undefined; used node: 20.9.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.2
                for whatever reason MM doesn’t recognises your electron version
                  sdetweil @MarcLandis
                  @MarcLandis yeh weird.
                  grep version node_modules/electron/package.json
                  • butchkemperB
                    butchkemper
                    @sdetweil said in After update 2.29.0 PM2 does not work:
                    This is what I get:
                    pi@MagicMirror:~/MagicMirror $ sudo grep version node_modules/electron/package.json
                      "version": "31.1.0"
                      @butchkemper which is the correct value
                      • butchkemperB
                        butchkemper
                        @butchkemper said in After update 2.29.0 PM2 does not work:
                        Sam, did you see where I mention the problem continues even after I deleted the 2.29.0 MM directory and restored the 2.28.0 directory?
                        Also, I am in the DFW area and available by phone if you would like.
                        Butch
                          @butchkemper i did, but only other thing is nodejs version.
                          can you post the upgrade.log to a new issue for my scripts
                          i have grandchildren duty til tomorrow morning
                          htilburgsH butchkemperB 2 Replies Last reply
                          • htilburgsH
                            htilburgs @sdetweil
                            pi@mm:~ $ pm2 delete 0
                            [PM2] Applying action deleteProcessId on app [0](ids: [ '0' ])
                            [PM2] [MagicMirror](0) ✓
                            │ id │ name      │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                            [PM2][WARN] Current process list is not synchronized with saved list. App MagicMirror differs. Type 'pm2 save' to synchronize.
                            pi@mm:~ $ pm2 save -f
                            [PM2] Saving current process list...
                            [PM2] Successfully saved in /home/pi/.pm2/dump.pm2
                            pi@mm:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                            the log will be saved in /home/pi/MagicMirror/installers/pm2_setup.log
                            [PM2][WARN] Applications MagicMirror not running, starting...
                            [PM2][ERROR] Error: Script not found: /home/pi/MagicMirror/installers/mm.sh
                            [PM2][WARN] PM2 is not managing any process, skipping save...
                            [PM2][WARN] To force saving use: pm2 save --force
                            pi@mm:~ $ node -v
                            v20.9.0
                            pi@mm:~ $ grep version node_modules/electron/package.json
                              "version": "31.6.0"
                            (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
                              sdetweil @htilburgs
                              @htilburgs arrrrrg
                              we deleted installers folder from the repository
                              didn’t fix the fixup script
                              be a couple hours
                              edit: fixed 17:50 Oct 1
                              htilburgsH 2 Replies Last reply
                              • htilburgsH
                                htilburgs @sdetweil
                                Oke, no problem.
                                It’s 22:55 in the Netherlands and have to get up at 05:30, so I go to sleep and check in the morning.
                                Enjoy your grandchildren ;-) These are more important than a MagicMirror!
                                • htilburgsH
                                  htilburgs @sdetweil
                                  I created the mm.sh script in the /MagicMirror/installers folder (copied from your site) and run the fixuppm2 script again.
                                  Now it started MagicMirror as normal.
                                  I tried a reboot and it works now.
                                  Now only the same on the other MagicMirror screen and I’m happy again.
                                  If i have to do anything more or reinstall, let me know.
                                  But it seems I’ve a working installation of MagicMirror again.
                                  Thanks!!
                                  S 2 Replies Last reply
                                  • butchkemperB
                                    butchkemper @sdetweil
                                    @sdetweil I have posted a new topic in trouble shooting with the error message and the install log.
                                    The system would not let me send the file as only graphic files are accepted.
                                    Thank you.
                                    Butch
                                      sdetweil @htilburgs
                                      @htilburgs awesome, thx
                                        sdetweil @htilburgs
                                        @htilburgs I have added the mm.sh to fixuppm2.sh
