    After update 2.29.0 PM2 does not work
    20 Posts 4 Posters 6.7k Views 4 Watching
      MarcLandis Module Developer @htilburgs
      @htilburgs said in After update 2.29.0 PM2 does not work:
      VERSIONS: electron: undefined; used node: 20.9.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.2
      for whatever reason MM doesn’t recognises your electron version
        sdetweil @MarcLandis
        @MarcLandis yeh weird.
        @htilburgs can you do
        grep version node_modules/electron/package.json
        • butchkemperB Offline
          butchkemper
          @sdetweil said in After update 2.29.0 PM2 does not work:
          This is what I get:
          pi@MagicMirror:~/MagicMirror $ sudo grep version node_modules/electron/package.json
            "version": "31.1.0"
          Resistance is not Futile!
          It is voltage divided by current.
            sdetweil @butchkemper
            @butchkemper which is the correct value
              butchkemper
              @butchkemper said in After update 2.29.0 PM2 does not work:
              Sam, did you see where I mention the problem continues even after I deleted the 2.29.0 MM directory and restored the 2.28.0 directory?
              Also, I am in the DFW area and available by phone if you would like.
              Butch
                @butchkemper i did, but only other thing is nodejs version.
                can you post the upgrade.log to a new issue for my scripts
                i have grandchildren duty til tomorrow morning
                htilburgsH butchkemperB 2 Replies Last reply Reply Quote 0
                • htilburgsH Offline
                  htilburgs @sdetweil
                  pi@mm:~ $ pm2 delete 0
                  [PM2] Applying action deleteProcessId on app [0](ids: [ '0' ])
                  [PM2] [MagicMirror](0) ✓
                  │ id │ name      │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                  [PM2][WARN] Current process list is not synchronized with saved list. App MagicMirror differs. Type 'pm2 save' to synchronize.
                  pi@mm:~ $ pm2 save -f
                  [PM2] Saving current process list...
                  [PM2] Successfully saved in /home/pi/.pm2/dump.pm2
                  pi@mm:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                  the log will be saved in /home/pi/MagicMirror/installers/pm2_setup.log
                  [PM2][WARN] Applications MagicMirror not running, starting...
                  [PM2][ERROR] Error: Script not found: /home/pi/MagicMirror/installers/mm.sh
                  [PM2][WARN] PM2 is not managing any process, skipping save...
                  [PM2][WARN] To force saving use: pm2 save --force
                  pi@mm:~ $ node -v
                  v20.9.0
                  pi@mm:~ $ grep version node_modules/electron/package.json
                    "version": "31.6.0"
                  (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
                    sdetweil @htilburgs
                    @htilburgs arrrrrg
                    we deleted installers folder from the repository
                    didn’t fix the fixup script
                    be a couple hours
                    edit: fixed 17:50 Oct 1
                    htilburgsH 2 Replies Last reply Reply Quote 0
                      htilburgs @sdetweil
                      Oke, no problem.
                      It’s 22:55 in the Netherlands and have to get up at 05:30, so I go to sleep and check in the morning.
                      Enjoy your grandchildren ;-) These are more important than a MagicMirror!
                        htilburgs @sdetweil
                        I created the mm.sh script in the /MagicMirror/installers folder (copied from your site) and run the fixuppm2 script again.
                        Now it started MagicMirror as normal.
                        I tried a reboot and it works now.
                        Now only the same on the other MagicMirror screen and I’m happy again.
                        If i have to do anything more or reinstall, let me know.
                        But it seems I’ve a working installation of MagicMirror again.
                        Thanks!!
                        S 2 Replies Last reply Reply Quote 1
                          butchkemper @sdetweil
                          @sdetweil I have posted a new topic in trouble shooting with the error message and the install log.
                          The system would not let me send the file as only graphic files are accepted.
                          Thank you.
                          Butch
                            sdetweil @htilburgs
                            @htilburgs awesome, thx
                              sdetweil @htilburgs
                              @htilburgs I have added the mm.sh to fixuppm2.sh
