    After update 2.29.0 PM2 does not work
    20 Posts 4 Posters 5.4k Views 4 Watching
      sdetweil @butchkemper
      @butchkemper can you do to show the nodejs version
      node -v
      • butchkemperB Offline
        butchkemper
        pi@MagicMirror:~ $ node -v
        v20.17.0
        pi@MagicMirror:~ $
        Resistance is not Futile!
        It is voltage divided by current.
          MarcLandis Module Developer @htilburgs
          @htilburgs said in After update 2.29.0 PM2 does not work:
          VERSIONS: electron: undefined; used node: 20.9.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.2
          for whatever reason MM doesn’t recognises your electron version
            sdetweil @MarcLandis
            @MarcLandis yeh weird.
            @htilburgs can you do
            grep version node_modules/electron/package.json
              butchkemper
              @sdetweil said in After update 2.29.0 PM2 does not work:
              This is what I get:
              pi@MagicMirror:~/MagicMirror $ sudo grep version node_modules/electron/package.json
                "version": "31.1.0"
                @butchkemper which is the correct value
                  butchkemper
                  @butchkemper said in After update 2.29.0 PM2 does not work:
                  Sam, did you see where I mention the problem continues even after I deleted the 2.29.0 MM directory and restored the 2.28.0 directory?
                  Also, I am in the DFW area and available by phone if you would like.
                  Butch
                    @butchkemper i did, but only other thing is nodejs version.
                    can you post the upgrade.log to a new issue for my scripts
                    i have grandchildren duty til tomorrow morning
                    htilburgsH butchkemperB 2 Replies Last reply Reply Quote 0
                    • htilburgsH Offline
                      htilburgs @sdetweil
                      pi@mm:~ $ pm2 delete 0
                      [PM2] Applying action deleteProcessId on app [0](ids: [ '0' ])
                      [PM2] [MagicMirror](0) ✓
                      │ id │ name      │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                      [PM2][WARN] Current process list is not synchronized with saved list. App MagicMirror differs. Type 'pm2 save' to synchronize.
                      pi@mm:~ $ pm2 save -f
                      [PM2] Saving current process list...
                      [PM2] Successfully saved in /home/pi/.pm2/dump.pm2
                      pi@mm:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                      the log will be saved in /home/pi/MagicMirror/installers/pm2_setup.log
                      [PM2][WARN] Applications MagicMirror not running, starting...
                      [PM2][ERROR] Error: Script not found: /home/pi/MagicMirror/installers/mm.sh
                      [PM2][WARN] PM2 is not managing any process, skipping save...
                      [PM2][WARN] To force saving use: pm2 save --force
                      pi@mm:~ $ node -v
                      v20.9.0
                      pi@mm:~ $ grep version node_modules/electron/package.json
                        "version": "31.6.0"
                      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
                        sdetweil @htilburgs
                        @htilburgs arrrrrg
                        we deleted installers folder from the repository
                        didn’t fix the fixup script
                        be a couple hours
                        edit: fixed 17:50 Oct 1
                        htilburgsH 2 Replies Last reply Reply Quote 0
