    After update 2.29.0 PM2 does not work
    20 Posts 4 Posters 5.2k Views 4 Watching
      sdetweil @htilburgs
      @htilburgs can you do
      pm2 delete 0
      pm2 save -f
      and then run the fixuppm2 script again
      • butchkemperB Offline
        butchkemper
        I am in the same boat with you. After update to 2.29.0, the ~/.pm2/logs/MagicMirror-error.log has this block of messages continually repeating:
        [ERROR] TypeError: Cannot read properties of undefined (reading 'disableHardwareAcceleration')
            at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:15:6)
            at Module._compile (node:internal/modules/cjs/loader:1469:14)
            at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
            at Module.load (node:internal/modules/cjs/loader:1288:32)
            at Module._load (node:internal/modules/cjs/loader:1104:12)
            at Object.<anonymous> (/usr/lib/node_modules/pm2/lib/ProcessContainerFork.js:33:23)
            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
            at node:internal/main/run_main_module:28:49
        I made a backup of the MagicMirror directory before updating to the new version. To return to the old version, I deleted the updated MagicMirror directory and restored the backup MM directory but the error persists with V2.28.0. Something outside of the MM directory must have been updated.
        I tried restarting the system but the error continues.
        Butch
        Resistance is not Futile!
        It is voltage divided by current.
          also try
          sudo npm i pm2 -g
            sdetweil @butchkemper
            @butchkemper can you do to show the nodejs version
            node -v
              butchkemper
              pi@MagicMirror:~ $ node -v
              v20.17.0
              pi@MagicMirror:~ $
                MarcLandis Module Developer @htilburgs
                @htilburgs said in After update 2.29.0 PM2 does not work:
                VERSIONS: electron: undefined; used node: 20.9.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.2
                for whatever reason MM doesn’t recognises your electron version
                  sdetweil @MarcLandis
                  @MarcLandis yeh weird.
                  grep version node_modules/electron/package.json
                    butchkemper
                    @sdetweil said in After update 2.29.0 PM2 does not work:
                    This is what I get:
                    pi@MagicMirror:~/MagicMirror $ sudo grep version node_modules/electron/package.json
                      "version": "31.1.0"
                      @butchkemper which is the correct value
                        butchkemper
                        @butchkemper said in After update 2.29.0 PM2 does not work:
                        Sam, did you see where I mention the problem continues even after I deleted the 2.29.0 MM directory and restored the 2.28.0 directory?
                        Also, I am in the DFW area and available by phone if you would like.
                        Butch
