    After update 2.29.0 PM2 does not work
    20 Posts 4 Posters 6.7k Views 4 Watching
      sdetweil @butchkemper
      @butchkemper which is the correct value
      • butchkemperB Offline
        butchkemper
        @butchkemper said in After update 2.29.0 PM2 does not work:
        Sam, did you see where I mention the problem continues even after I deleted the 2.29.0 MM directory and restored the 2.28.0 directory?
        Also, I am in the DFW area and available by phone if you would like.
        Butch
        Resistance is not Futile!
        It is voltage divided by current.
          @butchkemper i did, but only other thing is nodejs version.
          can you post the upgrade.log to a new issue for my scripts
          i have grandchildren duty til tomorrow morning
          htilburgsH butchkemperB 2 Replies Last reply Reply Quote 0
          • htilburgsH Offline
            htilburgs @sdetweil
            pi@mm:~ $ pm2 delete 0
            [PM2] Applying action deleteProcessId on app [0](ids: [ '0' ])
            [PM2] [MagicMirror](0) ✓
            │ id │ name      │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
            [PM2][WARN] Current process list is not synchronized with saved list. App MagicMirror differs. Type 'pm2 save' to synchronize.
            pi@mm:~ $ pm2 save -f
            [PM2] Saving current process list...
            [PM2] Successfully saved in /home/pi/.pm2/dump.pm2
            pi@mm:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
            the log will be saved in /home/pi/MagicMirror/installers/pm2_setup.log
            [PM2][WARN] Applications MagicMirror not running, starting...
            [PM2][ERROR] Error: Script not found: /home/pi/MagicMirror/installers/mm.sh
            [PM2][WARN] PM2 is not managing any process, skipping save...
            [PM2][WARN] To force saving use: pm2 save --force
            pi@mm:~ $ node -v
            v20.9.0
            pi@mm:~ $ grep version node_modules/electron/package.json
              "version": "31.6.0"
            (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
              sdetweil @htilburgs
              @htilburgs arrrrrg
              we deleted installers folder from the repository
              didn’t fix the fixup script
              be a couple hours
              edit: fixed 17:50 Oct 1
              htilburgsH 2 Replies Last reply Reply Quote 0
                htilburgs @sdetweil
                Oke, no problem.
                It’s 22:55 in the Netherlands and have to get up at 05:30, so I go to sleep and check in the morning.
                Enjoy your grandchildren ;-) These are more important than a MagicMirror!
                  htilburgs @sdetweil
                  I created the mm.sh script in the /MagicMirror/installers folder (copied from your site) and run the fixuppm2 script again.
                  Now it started MagicMirror as normal.
                  I tried a reboot and it works now.
                  Now only the same on the other MagicMirror screen and I’m happy again.
                  If i have to do anything more or reinstall, let me know.
                  But it seems I’ve a working installation of MagicMirror again.
                  Thanks!!
                  S 2 Replies Last reply Reply Quote 1
                    butchkemper @sdetweil
                    @sdetweil I have posted a new topic in trouble shooting with the error message and the install log.
                    The system would not let me send the file as only graphic files are accepted.
                    Thank you.
                    Butch
                      sdetweil @htilburgs
                      @htilburgs awesome, thx
                        sdetweil @htilburgs
                        @htilburgs I have added the mm.sh to fixuppm2.sh
