    MMM-Remote-Control Not working well after upgrade to 2.29
    19 Posts 3 Posters 6.2k Views 4 Watching
      sdetweil @kent79
      @kent79 i am not a remotecontrol user.
      i don’t know what updates means.
      • K Offline
        kent79 @sdetweil
        The “updates” & “Modules Controls” is missing after upgrated to 2.29. It seems the modules can’t not load
          sdetweil @kent79
          @kent79 so, are there any messages in the MagicMirror startup?
          • K Offline
            kent79 @sdetweil
            There is no any error log on startup. I have clean install MM, but still no luck. It seems MMM-Remote-Control can’t recognize modules after upgrade
              sdetweil @kent79
              @kent79 can you show the output of npm start
              if using pm2 do
              pm2 stop all
              nom start
              • K Offline
                kent79 @sdetweil
                I am not using pm2
                  sdetweil @kent79
                  @kent79 ok show the output of npm start
                  • K Offline
                    kent79 @sdetweil
                    I got the error message when running on pm2
                    0|mm | [2024-10-02 08:59:41.255] [ERROR] Whoops! There was an uncaught exception…
                    0|mm | [2024-10-02 08:59:41.262] [ERROR] TypeError: Cannot read properties of undefined (reading ‘modules’)
                    0|mm | at /home/user/MagicMirror/modules/MMM-Remote-Control/node_helper.js:224:60
                    0|mm | at FSReqCallback.readFileAfterClose [as oncomplete] (node:internal/fs/read/context:68:3)
                      sdetweil @kent79
                      @kent79 ok, there is the answer why its not working at the remote
                      • K Offline
                        kent79 @sdetweil
                        is it a bug of 2.29 or remote module? how do fix it ? Thanks
                        S K 2 Replies Last reply Reply Quote 0
                          sdetweil @kent79
                          @kent79 i do not know at this time. im not aware of any change to config.js
                          • K Offline
                            kent79 @sdetweil
                            Many thanks for your quick reply always. It is not a urgent matter. You may investigate later. Thanks.
                            • K Offline
                              kent79 @kent79
                              @kent79 said in MMM-Remote-Control Not working well after upgrade to 2.29:
                              I am still using default config
                                  			module: "MMM-Remote-Control",
                                  			// position: 'bottom_left',
                                     				customCommand: {},  // Optional, See "Using Custom Commands" below
                                      			showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                                      			secureEndpoints: true, // Optional, See API/README.md
                                     			 	// uncomment any of the lines below if you're gonna use it
                                      			// customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                                      			// apiKey: "", // Optional, See API/README.md for details
                                      			// classes: {} // Optional, See "Custom Classes" below
                                sdetweil @kent79
                                @kent79 yeh, code is broken
                                it is hard coded to the old MichMich repo and one particular page in the wiki, which has moved and changed
                                I have been unable to open an issue as the issue template is too strict
                                @Jopyth can you see this?
                                • karsten13K Offline
                                  karsten13 @sdetweil
                                  I submitted a PR
                                  K 1 Reply Last reply Reply Quote 1
                                  • K Offline
                                    kent79 @karsten13
                                    @karsten13 said in MMM-Remote-Control Not working well after upgrade to 2.29:
                                    I submitted a PR
                                    Thank you very much
