    MMM-Remote-Control Not working well after upgrade to 2.29
    19 Posts 3 Posters 6.2k Views 4 Watching
      sdetweil @kent79
      @kent79 so, are there any messages in the MagicMirror startup?
      • K Offline
        kent79 @sdetweil
        There is no any error log on startup. I have clean install MM, but still no luck. It seems MMM-Remote-Control can’t recognize modules after upgrade
          sdetweil @kent79
          @kent79 can you show the output of npm start
          if using pm2 do
          pm2 stop all
          nom start
          • K Offline
            kent79 @sdetweil
            I am not using pm2
              sdetweil @kent79
              @kent79 ok show the output of npm start
              • K Offline
                kent79 @sdetweil
                I got the error message when running on pm2
                0|mm | [2024-10-02 08:59:41.255] [ERROR] Whoops! There was an uncaught exception…
                0|mm | [2024-10-02 08:59:41.262] [ERROR] TypeError: Cannot read properties of undefined (reading ‘modules’)
                0|mm | at /home/user/MagicMirror/modules/MMM-Remote-Control/node_helper.js:224:60
                0|mm | at FSReqCallback.readFileAfterClose [as oncomplete] (node:internal/fs/read/context:68:3)
                  sdetweil @kent79
                  @kent79 ok, there is the answer why its not working at the remote
                  • K Offline
                    kent79 @sdetweil
                    is it a bug of 2.29 or remote module? how do fix it ? Thanks
                    S K 2 Replies Last reply Reply Quote 0
                      sdetweil @kent79
                      @kent79 i do not know at this time. im not aware of any change to config.js
                      • K Offline
                        kent79 @sdetweil
                        Many thanks for your quick reply always. It is not a urgent matter. You may investigate later. Thanks.
                        • K Offline
                          kent79 @kent79
                          @kent79 said in MMM-Remote-Control Not working well after upgrade to 2.29:
                          I am still using default config
                              			module: "MMM-Remote-Control",
                              			// position: 'bottom_left',
                                 				customCommand: {},  // Optional, See "Using Custom Commands" below
                                  			showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                                  			secureEndpoints: true, // Optional, See API/README.md
                                 			 	// uncomment any of the lines below if you're gonna use it
                                  			// customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                                  			// apiKey: "", // Optional, See API/README.md for details
                                  			// classes: {} // Optional, See "Custom Classes" below
                            sdetweil @kent79
                            @kent79 yeh, code is broken
                            it is hard coded to the old MichMich repo and one particular page in the wiki, which has moved and changed
                            I have been unable to open an issue as the issue template is too strict
                            @Jopyth can you see this?
                            • karsten13K Offline
                              karsten13 @sdetweil
                              I submitted a PR
                              K 1 Reply Last reply Reply Quote 1
                              • K Offline
                                kent79 @karsten13
                                @karsten13 said in MMM-Remote-Control Not working well after upgrade to 2.29:
                                I submitted a PR
                                Thank you very much
