    MMM-Remote-Control Not working well after upgrade to 2.29
    19 Posts 3 Posters 6.3k Views 4 Watching
      sdetweil @kent79
      @kent79 can you show the output of npm start
      if using pm2 do
      pm2 stop all
      nom start
      • K
        kent79 @sdetweil
        I am not using pm2
          sdetweil @kent79
          @kent79 ok show the output of npm start
          • K
            kent79 @sdetweil
            I got the error message when running on pm2
            0|mm | [2024-10-02 08:59:41.255] [ERROR] Whoops! There was an uncaught exception…
            0|mm | [2024-10-02 08:59:41.262] [ERROR] TypeError: Cannot read properties of undefined (reading ‘modules’)
            0|mm | at /home/user/MagicMirror/modules/MMM-Remote-Control/node_helper.js:224:60
            0|mm | at FSReqCallback.readFileAfterClose [as oncomplete] (node:internal/fs/read/context:68:3)
              sdetweil @kent79
              @kent79 ok, there is the answer why its not working at the remote
              • K
                kent79 @sdetweil
                is it a bug of 2.29 or remote module? how do fix it ? Thanks
                S K 2 Replies Last reply Reply Quote 0
                  sdetweil @kent79
                  @kent79 i do not know at this time. im not aware of any change to config.js
                  • K
                    kent79 @sdetweil
                    Many thanks for your quick reply always. It is not a urgent matter. You may investigate later. Thanks.
                    • K
                      kent79 @kent79
                      @kent79 said in MMM-Remote-Control Not working well after upgrade to 2.29:
                      I am still using default config
                          			module: "MMM-Remote-Control",
                          			// position: 'bottom_left',
                             				customCommand: {},  // Optional, See "Using Custom Commands" below
                              			showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                              			secureEndpoints: true, // Optional, See API/README.md
                             			 	// uncomment any of the lines below if you're gonna use it
                              			// customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                              			// apiKey: "", // Optional, See API/README.md for details
                              			// classes: {} // Optional, See "Custom Classes" below
                        sdetweil @kent79
                        @kent79 yeh, code is broken
                        it is hard coded to the old MichMich repo and one particular page in the wiki, which has moved and changed
                        I have been unable to open an issue as the issue template is too strict
                        @Jopyth can you see this?
                        • karsten13K
                          karsten13 @sdetweil
                          I submitted a PR
                          K 1 Reply Last reply Reply Quote 1
                          • K
                            kent79 @karsten13
                            @karsten13 said in MMM-Remote-Control Not working well after upgrade to 2.29:
                            I submitted a PR
                            Thank you very much
