    Problem Adding Buttons & required Remote-Control Modules
    26 Posts 4 Posters 5.7k Views 4 Watching
    • A
      awwbaker @sdetweil
      Mr @sdetweil
      I tested my button press using:
      import RPi.GPIO as GPIO
      import time
      GPIO.setmode(GPIO.BCM)
      GPIO.setup(6, GPIO.IN, pull_up_down=GPIO.PUD_UP)
      while True:
      input_state = GPIO.input(6)
      if input_state == False:
      print(‘Button Pressed’)
      time.sleep(0.2)
      That worked fine. I found the module MMM-ModuleToggleButton which seemed a bit simpler and directly what wanted to do. The demo script used GPIO 6 so used default. Do i need to use a pull_down resister? Thank Thank you again! VR Anthony
      PS: Sam I looked for a link to buy you a cup of coffee, not found, but if you have one, please forward?
      • A
        awwbaker @sdetweil
        Mr @sdetweil, I also noted the below error ? Thank you!
        [2024-09-20 16:36:07.413] [LOG] Sockets connected & modules started …
        [2024-09-20 16:36:10.523] [LOG] Launching application.
        [2024-09-20 16:36:15.920] [INFO] System information:
        SYSTEM: manufacturer: ; model: ; raspberry: undefined; virtual: false
        OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.47+rpt-rpi-v8
        VERSIONS: electron: 31.1.0; used node: 20.14.0; installed node: 22.9.0; npm: 10.8.3; pm2: 5.4.1
        OTHER: timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
        [2024-09-20 16:36:20.989] [ERROR] Whoops! There was an uncaught exception…
        [2024-09-20 16:36:21.019] [ERROR] Error: EINVAL: invalid argument, write
        at Object.writeFileSync (node:fs:2346:20)
        at exportGpio (/home/awwbaker/MagicMirror/modules/MMM-ModuleToggleButton/node_modules/onoff/onoff.js:18:8)
        at new Gpio (/home/awwbaker/MagicMirror/modules/MMM-ModuleToggleButton/node_modules/onoff/onoff.js:172:36)
        at Class.socketNotificationReceived (/home/awwbaker/MagicMirror/modules/MMM-ModuleToggleButton/node_helper.js:20:22)
        at Socket. (/home/awwbaker/MagicMirror/js/node_helper.js:98:11)
        at Socket.emit (node:events:519:28)
        at Socket.emitUntyped (/home/awwbaker/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22)
        at /home/awwbaker/MagicMirror/node_modules/socket.io/dist/socket.js:704:39
        at process.processTicksAndRejections (node:internal/process/task_queues:77:11) {
        errno: -22,
        code: ‘EINVAL’,
        syscall: ‘write’
        [2024-09-20 16:36:21.022] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [2024-09-20 16:36:21.027] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
        [2024-09-20 16:36:21.066] [LOG] Create new calendarfetcher for url: http://p134-caldav.icloud.com/published/2/ODY3MDc3ODQxODY3MDc3OIsPCPqyTd7gfFTuhUgnU3E8veSROaMD9lC0bXMqbeTrcdUcRFgL2q0GROkcc6XtdbepSRYxUGbDtoDb3se2UkE - Interval: 604800000
        [2024-09-20 16:36:21.372] [LOG] Create new calendarfetcher for url: http://p134-caldav.icloud.com/published/2/ODY3MDc3ODQxODY3MDc3OIsPCPqyTd7gfFTuhUgnU3HnE0ZEnCaHErJrwvkzJ3o- -
          sdetweil @awwbaker
          @awwbaker ps: i don’t accept coffee etc. i do this because i truly enjoy it.
          i love the challenge, the great people here, and the fascinatingly huge amount of differences among all your designs.
            sdetweil @awwbaker
            @awwbaker on the write
            see second post here
            https://forums.raspberrypi.com/viewtopic.php?t=367431
            • A
              awwbaker @sdetweil
              Dear Mr @sdetweil
              I think you are teaching me to fish…Did you see the error message below? Beyond the below, I booted the RPI 3B+, ran the “pinctrl set 6 op dl” command. Started MM and as previously the expected modules were hidden on start up. Pressing pushbutton did not have any affect on the display. I ran the button.py script and the button was sensed as previous. As your time permits I could use another push. Your efforts are VERY appreciated. VR Anthony Baker
              2024-09-21 13:33:31.232] [LOG] Connecting socket for: MMM-MktIndex
              [2024-09-21 13:33:31.234] [LOG] Sockets connected & modules started …
              [1856:0921/133334.081312:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.DBus.StartServiceByName: object_path= /org/freedesktop/DBus: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
              [2024-09-21 13:33:35.622] [LOG] Launching application.
              [2024-09-21 13:33:55.076] [INFO] System information:
              [2024-09-21 13:33:58.321] [ERROR] Whoops! There was an uncaught exception…
              [2024-09-21 13:33:58.343] [ERROR] Error: EINVAL: invalid argument, write
              errno: -22,
              code: ‘EINVAL’,
              syscall: ‘write’
              [2024-09-21 13:33:58.345] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              [2024-09-21 13:33:58.347] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
              [1976:0921/133401.533219:ERROR:gl_utils.cc(424)] [.WebGL-0x34004b5b00]GL Driver Message (OpenGL, Performance, GL_CLOSE_PATH_NV, High): GPU stall due to ReadPixels
              [2024-09-21 13:34:01.636] [LOG] Create new calendarfetcher for url: http://p134-caldav.icloud.com/published/2/ODY3MDc3ODQxODY3MDc3OIsPCPqyTd7gfFTuhUgnU3E8veSROaMD9lC0bXMqbeTrcdUcRFgL2q0GROkcc6XtdbepSRYxUGbDtoDb3se2UkE - Interval: 604800000
                sdetweil @awwbaker
                @awwbaker i am on my phone, i can’t edit, and it wants to quote whole thing .
                the os has changed the rules
                i posted a response the other day to a topic that had some workarounds without coding changes
                • A
                  awwbaker @sdetweil
                  Dear Mr @sdetweil
                  Please see above, it seems “on-off” is throwing errors. It seems it is used by Remote-Control-Modules as well as Buttons. I wnet back and tried buttons. The error is below: Thank you very much. Anthony
                  [2024-09-22 11:34:50.557] [LOG] Launching application.
                  [2024-09-22 11:35:05.029] [ERROR] ERROR! Could not validate main module js file.
                  [2024-09-22 11:35:05.037] [ERROR] ReferenceError: Log is not defined
                  at Object. (/home/awwbaker/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:28:158622)
                  at Module._compile (node:internal/modules/cjs/loader:1373:14)
                  at Module._extensions…js (node:internal/modules/cjs/loader:1432:10)
                  at Module.load (node:internal/modules/cjs/loader:1215:32)
                  at Module._load (node:internal/modules/cjs/loader:1031:12)
                  at c._load (node:electron/js2c/node_init:2:17025)
                  at Module.require (node:internal/modules/cjs/loader:1240:19)
                  at require (node:internal/modules/helpers:179:18)
                  at Class.loadModuleDefaultConfig (/home/awwbaker/MagicMirror/modules/MMM-Remote-Control/node_helper.js:314:30)
                  at /home/awwbaker/MagicMirror/modules/MMM-Remote-Control/node_helper.js:268:26
                  at FSReqCallback.oncomplete (node:fs:198:5)
                  [2024-09-22 11:35:05.689] [INFO] System information:
                  [2024-09-22 11:35:13.286] [LOG] Initialize button monitor_control on PIN 6
                  [2024-09-22 11:35:13.293] [ERROR] Whoops! There was an uncaught exception…
                  [2024-09-22 11:35:13.318] [ERROR] Error: EINVAL: invalid argument, write
                  at exportGpio (/home/awwbaker/MagicMirror/modules/MMM-Buttons/node_modules/onoff/onoff.js:18:8)
                  at new Gpio (/home/awwbaker/MagicMirror/modules/MMM-Buttons/node_modules/onoff/onoff.js:172:36)
                  at Class.intializeButton (/home/awwbaker/MagicMirror/modules/MMM-Buttons/node_helper.js:74:19)
                  at Class.intializeButtons (/home/awwbaker/MagicMirror/modules/MMM-Buttons/node_helper.js:90:18)
                  at Class.socketNotificationReceived (/home/awwbaker/MagicMirror/modules/MMM-Buttons/node_helper.js:26:18)
                  errno: -22,
                  code: ‘EINVAL’,
                  syscall: ‘write’
                  [2024-09-22 11:35:13.335]
                    sdetweil @awwbaker
                    @awwbaker yes as i posted before
                    errno: -22,
                    code: ‘EINVAL’,
                    syscall: ‘write’
                    the os has changed how this needs to be done
                    i posted a link to suggestions on how to resolve it without code changes
                    the Log not found is caused by the remotecontrol module
                    • A
                      awwbaker @sdetweil
                      Thank you, I tried the pinctrl to no avail. Thank you though! Anthony
                        sdetweil @awwbaker
                        @awwbaker did you solve this?
                        • A
                          awwbaker @sdetweil
                          @sdetweil Sorry have been on travel last several weeks. No I never did. I have the remote control module in and working just never could not get the button push. I have mmm-GroveGesture installed and working with sensor. Still working towards getting modules to hide and show. Could I ask another question???
                          What can/should I do on this?:
                          [2024-10-28 10:10:15.299] [ERROR] ERROR! Could not validate main module js file.
                          [2024-10-28 10:10:15.528] [ERROR] ReferenceError: Log is not defined
                              at Object.<anonymous> (/home/awwbaker/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:28:158622)
                              at Module._compile (node:internal/modules/cjs/loader:1484:14)
                              at Module._extensions..js (node:internal/modules/cjs/loader:1564:10)
                              at Module.load (node:internal/modules/cjs/loader:1295:32)
                              at Module._load (node:internal/modules/cjs/loader:1111:12)
                              at Module.require (node:internal/modules/cjs/loader:1318:19)
                              at Class.loadModuleDefaultConfig (/home/awwbaker/MagicMirror/modules/MMM-Remote-Control/node_helper.js:318:30)
                              at /home/awwbaker/MagicMirror/modules/MMM-Remote-Control/node_helper.js:272:26
                            sdetweil @awwbaker
                            @awwbaker remote control is loading the main js from other modules, but in the wrong runtime context.
                            i don’t know why it is doing that
                            • A
                              awwbaker @sdetweil
                              @sdetweil ,
                              Hmmm…thanks Sam!!!
                                ChrisLeduex
                                Hi guys, I’ve been trying to figure this out too. I think I’m close with these two files using ‘pinctrl’ instead of ‘/sys/class/gpio/’ but I can’t figure out what I’m missing.
                                Based on the console log it looks like there’s an issue in my node_helper file, possible with the socketNotification functions because I’m not seeing any of my test messages.
                                And based on the log files there may be something missing from the package.json file because sometimes I get this error “Error: Cannot find module ‘node helper’ MODULE_NOT_FOUND” but other times I don’t. And I tried running this fix but couldn’t get it to work.
                                [https://forum.magicmirror.builders/user/jorickjuh](link url)
                                Other than that I’m not seeing any other errors and module does appear to be working but it’s just not processing any button presses. I’ll keep trying but I’ll post my progress so far on here in case someone can see what I’m missing.
                                test file:
                                Module.register("MMM-PinToggleTest", {
                                  defaults: {
                                    pin: 19,
                                    modulesToToggle: ["clock", "calendar"],
                                    interval: 1000
                                //consol.log("MMM-PinToggleTest is starting...");
                                  start: function() {
                                    Log.info("MMM-PinToggleTest is starting, sending CONFIG...");
                                    consol.log("MMM-PinToggleTest is starting, sending CONFIG...");
                                    this.sendSocketNotification("CONFIG", {
                                      interval: this.config.interval,
                                      pin: this.config.pin
                                  start: function() {
                                    console.log("MMM-PinToggleTest started");
                                    this.previousPinState = null;
                                    // Request initial pin check from the helper
                                    this.sendSocketNotification("CONFIG", this.config);
                                    if (notification === "PIN_STATE") {
                                      const pinState = payload;
                                      console.log(`Received pin state: ${pinState}`);  // Log received state
                                      // Toggle modules based on pin state
                                      if (pinState !== this.previousPinState) {
                                        this.previousPinState = pinState;
                                        this.toggleModules(pinState === 1);
                                  toggleModules: function(show) {
                                    console.log(`Toggling modules to ${show ? "show" : "hide"}`);
                                    this.config.modulesToToggle.forEach(moduleName => {
                                      const modules = MM.getModules().withClass(moduleName);
                                      modules.forEach(module => {
                                        if (show) {
                                          module.show(1000);  // Show module with fade-in effect
                                        } else {
                                          module.hide(1000);  // Hide module with fade-out effect
                                  getDom: function() {
                                    const wrapper = document.createElement("div");
                                    wrapper.innerHTML = "<small>MMM-PinToggleTest</small>";
                                    return wrapper;
                                node_helper:
                                const NodeHelper = require("node_helper");
                                const exec = require("child_process").exec;
                                //const rpio = require("rpio");
                                //const Gpio = require("onoff").Gpio;
                                  start: function() {
                                    console.log("node_helper for MMM-PinToggleTest has started.");  // Confirm helper initialization
                                    this.lastChangeTime = 0;
                                    this.debounceDelay = 200;
                                    if (notification === "CONFIG") {
                                      console.log("Received CONFIG in node_helper:", payload);  // Log receipt of configuration
                                      this.config = payload;
                                      this.schedulePinCheck();
                                  schedulePinCheck: function() {
                                    console.log(`Setting up pin check every ${this.config.interval} ms`); // Confirmation log
                                    setInterval(() => {
                                      this.checkPinState();
                                    }, this.config.interval);
                                  checkPinState: function() {
                                    const pinNumber = this.config.pin;
                                    exec(`pinctrl ${pinNumber}`, (error, stdout, stderr) => {
                                      if (error) {
                                        console.error(`Error reading GPIO pin ${pinNumber}: ${stderr}`);
                                        return;
                                      const pinState = parseInt(stdout.trim(), 10);
                                      const now = Date.now();
                                      console.log(`Current pin state for GPIO ${pinNumber}: ${pinState}`);
                                      if (pinState !== this.previousPinState && (now - this.lastChangeTime > this.debounceDelay)) {
                                        this.lastChangeTime = now;
                                        console.log(`Pin state changed to ${pinState} at ${new Date(now).toISOString()}`);
                                        this.sendSocketNotification("PIN_STATE", pinState);
                                        // Small delay to avoid multiple triggers
                                        //setTimeout(() => {}, 100);
                                  sdetweil @ChrisLeduex
                                  @ChrisLeduex well, you don’t have any source errors. altho you have 2 start: functions in the modulename.js
                                  I see this as output of the pinctrl command on my pi 4
                                   pinctrl
                                   0: ip    pu | hi // ID_SDA/GPIO0 = input
                                   1: ip    pu | hi // ID_SCL/GPIO1 = input
                                   2: ip    pu | hi // GPIO2 = input
                                   3: ip    pu | hi // GPIO3 = input
                                   4: ip    pu | hi // GPIO4 = input
                                   5: ip    pu | hi // GPIO5 = input
                                   6: ip    pu | hi // GPIO6 = input
                                   7: ip    pu | hi // GPIO7 = input
                                   8: ip    pu | hi // GPIO8 = input
                                   9: ip    pd | lo // GPIO9 = input
                                  10: ip    pd | lo // GPIO10 = input
                                  11: ip    pd | lo // GPIO11 = input
                                  12: ip    pd | lo // GPIO12 = input
                                  13: ip    pd | lo // GPIO13 = input
                                  14: ip    pn | hi // GPIO14 = input
                                  15: ip    pu | hi // GPIO15 = input
                                  16: ip    pd | lo // GPIO16 = input
                                  17: ip    pd | lo // GPIO17 = input
                                  18: ip    pd | lo // GPIO18 = input
                                  19: ip    pd | lo // GPIO19 = input
                                  20: ip    pd | lo // GPIO20 = input
                                  21: ip    pd | lo // GPIO21 = input
                                  22: ip    pd | lo // GPIO22 = input
                                  23: ip    pd | lo // GPIO23 = input
                                  24: ip    pd | lo // GPIO24 = input
                                  25: ip    pd | lo // GPIO25 = input
                                  26: ip    pd | lo // GPIO26 = input
                                  27: ip    pd | lo // GPIO27 = input
                                  28: a5    pu | hi // RGMII_MDIO/GPIO28 = RGMII_MDIO
                                  29: a5    pd | lo // RGMIO_MDC/GPIO29 = RGMII_MDC
                                  30: a3    pu | lo // CTS0/GPIO30 = CTS0
                                  31: a3    pn | lo // RTS0/GPIO31 = RTS0
                                  32: a3    pn | hi // TXD0/GPIO32 = TXD0
                                  33: a3    pu | hi // RXD0/GPIO33 = RXD0
                                  34: a3    pn | hi // SD1_CLK/GPIO34 = SD1_CLK
                                  35: a3    pu | hi // SD1_CMD/GPIO35 = SD1_CMD
                                  36: a3    pu | hi // SD1_DATA0/GPIO36 = SD1_DAT0
                                  37: a3    pu | hi // SD1_DATA1/GPIO37 = SD1_DAT1
                                  38: a3    pu | hi // SD1_DATA2/GPIO38 = SD1_DAT2
                                  39: a3    pu | hi // SD1_DATA3/GPIO39 = SD1_DAT3
                                  40: a0    pn | lo // PWM0_MISO/GPIO40 = PWM1_0
                                  41: a0    pn | lo // PWM1_MOSI/GPIO41 = PWM1_1
                                  42: op -- pu | lo // STATUS_LED_G_CLK/GPIO42 = output
                                  43: ip    pu | hi // SPIFLASH_CE_N/GPIO43 = input
                                  44: ip    pu | hi // SDA0/GPIO44 = input
                                  45: ip    pu | hi // SCL0/GPIO45 = input
                                  46: ip    pu | lo // RGMII_RXCLK/GPIO46 = input
                                  47: ip    pu | lo // RGMII_RXCTL/GPIO47 = input
                                  48: ip    pd | lo // RGMII_RXD0/GPIO48 = input
                                  49: ip    pd | lo // RGMII_RXD1/GPIO49 = input
                                  50: ip    pd | lo // RGMII_RXD2/GPIO50 = input
                                  51: ip    pd | lo // RGMII_RXD3/GPIO51 = input
                                  52: ip    pd | lo // RGMII_TXCLK/GPIO52 = input
                                  53and : ip    pd | lo // RGMII_TXCTL/GPIO53 = input
                                  and this for output of pinctrl 19
                                  so the “pinctrl 19” command and parseInt(“19: ip pd | lo // GPIO19 = input”, 10);
                                  will return 19
                                  I think you meant pinctrl get 19, after sometime prior doing pinctrl set
                                  pinctrl help
                                  shows all it can do
                                    ChrisLeduex @sdetweil
                                    @sdetweil Thank you for catching those, too much copying and pasting.
                                    Removed one of the start functions from the module.js file and also updated this line in the node_helper.js file so now it is returning the pin state instead of the pin number.
                                    //const pinState = parseInt(stdout.trim(), 10);
                                    const pinState = stdout.includes(“hi”) ? 1 : 0;
                                    There still seems to be an issue somewhere in my node_helper.js file though because I’m still not seeing anything from that file in the console. Looking through the forum it seems node_helper file issues are common and I’ve tried implementing a few of the solutions I found there but still haven’t found the problem but I will keep trying. I suspect maybe I’m not nesting my socket notifications correctly.
                                    PinToggleTest.js
                                      defaults: {
                                        pin: 19,
                                        interval: 1000
                                      start: function() {
                                    		if (notification === 'STARTED') {
                                        console.log("STARTED notification received from node_helper");
                                        this.config.text = 'Started';
                                        this.updateDom();
                                            if (show) {
                                            } else {
                                        return wrapper;
                                    node_helper.js
                                    //module.exports = NodeHelper.create({
                                    //  start: function() {
                                    //    console.log("Starting node_helper for MMM-PinToggleTest");
                                    //    this.previousPinState = null;
                                    //    this.config = null;
                                      start() {
                                        this.started = false;
                                        if (notification === "CONFIG" && !this.started) {
                                          const self = this;
                                          console.log("CONFIG notification received");
                                          this.sendSocketNotification('STARTED', {message: 'test'});
                                          console.log("STARTED notification sent back to front end");
                                        setInterval(() => {
                                        // Execute pinctrl command
                                        exec(`pinctrl get ${pinNumber}`, (error, stdout, stderr) => {
                                          if (error) {
                                            return;
                                          const pinState = stdout.includes("hi") ? 1 : 0;
                                          console.log(`Detected pin state for pin ${pinNumber}: ${pinState}`);  // Log the detected state
                                          // Only send if state has changed
                                            console.log(`Pin state changed to ${pinState}`);
                                      @ChrisLeduex I see this from the output of npm start
                                      [2024-11-05 12:32:28.225] [LOG]   Current pin state for GPIO 19: 1
                                      [2024-11-05 12:32:28.225] [LOG]   Pin state changed to 1 at 2024-11-05T18:32:28.224Z
                                      [2024-11-05 12:32:28.244] [INFO]  [MMM-MealieMenu] Week starts: 2024-11-04, next week starts: 2024-11-11
                                      [2024-11-05 12:32:28.375] [INFO]  Mealie error={}
                                      [2024-11-05 12:32:28.400] [INFO]  Newsfeed-Fetcher: Broadcasting 15 items.
                                      [2024-11-05 12:32:28.413] [INFO]  Newsfeed-Fetcher: Broadcasting 22 items.
                                      [2024-11-05 12:32:28.819] [INFO]  Newsfeed-Fetcher: reloadInterval set to ttl=5400000 for url http://www.tagesschau.de/xml/rss2
                                      [2024-11-05 12:32:28.847] [INFO]  Newsfeed-Fetcher: Broadcasting 40 items.
                                      [2024-11-05 12:32:29.225] [LOG]   Current pin state for GPIO 19: 1
                                      [2024-11-05 12:32:30.225] [LOG]   Current pin state for GPIO 19: 1
                                      [2024-11-05 12:32:31.225] [LOG]   Current pin state for GPIO 19: 1
                                      [2024-11-05 12:32:32.225] [LOG]   Current pin state for GPIO 19: 1
                                      [2024-11-05 12:32:33.224] [LOG]   Current pin state for GPIO 19: 1
                                      [2024-11-05 12:32:34.225] [LOG]   Current pin state for GPIO 19: 1
                                      [2024-11-05 12:32:35.226] [LOG]   Current pin state for GPIO 19: 1
                                      [2024-11-05 12:32:36.227] [LOG]   Current pin state for GPIO 19: 1
                                      [2024-11-05 12:32:37.229] [LOG]   Current pin state for GPIO 19: 1
                                      [2024-11-05 12:32:38.227] [LOG]   Current pin state for GPIO 19: 1
                                      I wrote a little pinctrl script that just outputs 1
                                      #!/bin/bash
                                      echo 1
                                      as pinctrl is not on my linux desktop
                                        @sdetweil Ah yes, I forgot I have a python script I was kicking off manually that I forgot to run before testing those fixes. It is working now and both files are communicating with each other, thank you.
                                        My next step is to see if I can get this working with the MMM-Buttons/MMM-ModuleToggleButton modules.
                                          @ChrisLeduex buttons is interrupt driven, but can be changed to polling like you are doing
                                            @sdetweil Yeah you’re right, that one might be more difficult. But I do have MMM-ModuleToggleButton working with pinctrl. Here’s the updated node_helper.js file just in case anyone’s interested.
                                            node_helper.js
                                            const NodeHelper = require('node_helper'); // eslint-disable-line import/no-extraneous-dependencies
                                            //const Gpio = require('onoff').Gpio;
                                            const { exec } = require("child_process");
                                              start() {
                                              socketNotificationReceived(notification, payload) {
                                                if (notification === 'TOGGLE_BUTTON_CONFIG' && !this.started) {
                                                  const self = this;
                                                  //const button = new Gpio(this.config.buttonGpioPin, 'in', 'both', { persistentWatch: true, debounceTimeout: this.config.debounceTimeoutInMilliseconds });
                                                  //button.watch((err, state) => {
                                                  //  if (state === 1) {
                                                  //    self.sendSocketNotification(self.config.notificationName, true);
                                                  //this.started = true;
                                                  // Set up GPIO as input using pinctrl command
                                                  const pin = this.config.buttonGpioPin;
                                                  const debounceTimeout = this.config.debounceTimeoutInMilliseconds;
                                                  const notificationName = this.config.notificationName;
                                                  let lastState = null;
                                                  // Function to read the pin state using pinctrl
                                                  const checkPinState = () => {
                                                  exec(`pinctrl get ${pin}`, (err, stdout, stderr) => {
                                                    if (err) {
                                                      console.error(`Error reading GPIO state: ${err.message}`);
                                                      return;
                                                    // Parse the pin state from stdout
                                                    const state = stdout.includes("hi") ? 1 : 0;
                                                    // Handle state change with debounce
                                                    if (state !== lastState && state === 1) {
                                                      this.sendSocketNotification(notificationName, true);
                                                    // Update last state
                                                    lastState = state;
                                                // Set up an interval to check the pin state with debounce
                                                setInterval(checkPinState, debounceTimeout || 100); // Defaults to 100ms if debounce is not defined
