    Problem Adding Buttons & required Remote-Control Modules
    26 Posts 4 Posters 5.4k Views 4 Watching
      sdetweil @awwbaker
      @awwbaker
      that is a garbage message from electron we can’t suppress
      @awwbaker said in Problem Adding Buttons & required Remote-Control Modules:
      this is all from MMM-RemoteControl loading the modules JS file in a different context than was intended… its not fatal
      > [2024-09-16 15:04:00.407] [ERROR] ERROR! Could not validate main module js file.
      > [2024-09-16 15:04:00.408] [ERROR] ReferenceError: Log is not defined
      > at Object. (/home/awwbaker/MagicMirror/modules/MMM-Jast/MMM-Jast.js:14:6243)
      > at Module._compile (node:internal/modules/cjs/loader:1373:14)
      > at Module._extensions…js (node:internal/modules/cjs/loader:1432:10)
      > at Module.load (node:internal/modules/cjs/loader:1215:32)
      > at Module._load (node:internal/modules/cjs/loader:1031:12)
      > at c._load (node:electron/js2c/node_init:2:17025)
      > at Module.require (node:internal/modules/cjs/loader:1240:19)
      > at require (node:internal/modules/helpers:179:18)
      > at Class.loadModuleDefaultConfig (/home/awwbaker/MagicMirror/modules/MMM-Remote-Control/node_helper.js:314:30)
      > at /home/awwbaker/MagicMirror/modules/MMM-Remote-Control/node_helper.js:268:26
      > at FSReqCallback.oncomplete (node:fs:198:5)
      > [2024-09-16 15:04:00.465] [ERROR] ERROR! Could not validate main module js file.
      > [2024-09-16 15:04:00.466] [ERROR] ReferenceError: Log is not defined
      > at Object. (/home/awwbaker/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:28:158622)
        awwbaker
        Thank you so much for the info…I am a running a RPI-5.
          sdetweil @awwbaker
          [2024-09-16 15:04:01.418] [LOG] Initialize button monitor_control on PIN 25
          [2024-09-16 15:04:01.419] [LOG] MMM-Buttons: RPi model Raspberry Pi 5 Model B Rev 1.0
          [2024-09-16 15:04:01.419] [LOG] MMM-Buttons: RPi5 detected
          [2024-09-16 15:04:01.433] [LOG] Initialize button power on PIN 24
          [2024-09-16 15:04:01.434] [LOG] MMM-Buttons: RPi model Raspberry Pi 5 Model B Rev 1.0
          [2024-09-16 15:04:01.434] [LOG] MMM-Buttons: RPi5 detected
          did you test to make sure the buttons work outside MM?
            MarcLandis Module Developer @sdetweil
            @awwbaker
            it seems that the MMM-Jast module is throwing the error:
              sdetweil @MarcLandis
              @MarcLandis its because MagicMirror-remote-control is doing a require() on the module js
              A 2 Replies Last reply Reply Quote 0
                awwbaker @sdetweil
                Mr @sdetweil
                I tested my button press using:
                import RPi.GPIO as GPIO
                import time
                GPIO.setmode(GPIO.BCM)
                GPIO.setup(6, GPIO.IN, pull_up_down=GPIO.PUD_UP)
                while True:
                input_state = GPIO.input(6)
                if input_state == False:
                print(‘Button Pressed’)
                time.sleep(0.2)
                That worked fine. I found the module MMM-ModuleToggleButton which seemed a bit simpler and directly what wanted to do. The demo script used GPIO 6 so used default. Do i need to use a pull_down resister? Thank Thank you again! VR Anthony
                PS: Sam I looked for a link to buy you a cup of coffee, not found, but if you have one, please forward?
                  awwbaker @sdetweil
                  Mr @sdetweil, I also noted the below error ? Thank you!
                  [2024-09-20 16:36:07.413] [LOG] Sockets connected & modules started …
                  [2024-09-20 16:36:10.523] [LOG] Launching application.
                  [2024-09-20 16:36:15.920] [INFO] System information:
                  SYSTEM: manufacturer: ; model: ; raspberry: undefined; virtual: false
                  OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.47+rpt-rpi-v8
                  VERSIONS: electron: 31.1.0; used node: 20.14.0; installed node: 22.9.0; npm: 10.8.3; pm2: 5.4.1
                  OTHER: timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
                  [2024-09-20 16:36:20.989] [ERROR] Whoops! There was an uncaught exception…
                  [2024-09-20 16:36:21.019] [ERROR] Error: EINVAL: invalid argument, write
                  at Object.writeFileSync (node:fs:2346:20)
                  at exportGpio (/home/awwbaker/MagicMirror/modules/MMM-ModuleToggleButton/node_modules/onoff/onoff.js:18:8)
                  at new Gpio (/home/awwbaker/MagicMirror/modules/MMM-ModuleToggleButton/node_modules/onoff/onoff.js:172:36)
                  at Class.socketNotificationReceived (/home/awwbaker/MagicMirror/modules/MMM-ModuleToggleButton/node_helper.js:20:22)
                  at Socket. (/home/awwbaker/MagicMirror/js/node_helper.js:98:11)
                  at Socket.emit (node:events:519:28)
                  at Socket.emitUntyped (/home/awwbaker/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22)
                  at /home/awwbaker/MagicMirror/node_modules/socket.io/dist/socket.js:704:39
                  at process.processTicksAndRejections (node:internal/process/task_queues:77:11) {
                  errno: -22,
                  code: ‘EINVAL’,
                  syscall: ‘write’
                  [2024-09-20 16:36:21.022] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [2024-09-20 16:36:21.027] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                  [2024-09-20 16:36:21.066] [LOG] Create new calendarfetcher for url: http://p134-caldav.icloud.com/published/2/ODY3MDc3ODQxODY3MDc3OIsPCPqyTd7gfFTuhUgnU3E8veSROaMD9lC0bXMqbeTrcdUcRFgL2q0GROkcc6XtdbepSRYxUGbDtoDb3se2UkE - Interval: 604800000
                  [2024-09-20 16:36:21.372] [LOG] Create new calendarfetcher for url: http://p134-caldav.icloud.com/published/2/ODY3MDc3ODQxODY3MDc3OIsPCPqyTd7gfFTuhUgnU3HnE0ZEnCaHErJrwvkzJ3o- -
                    sdetweil @awwbaker
                    @awwbaker ps: i don’t accept coffee etc. i do this because i truly enjoy it.
                    i love the challenge, the great people here, and the fascinatingly huge amount of differences among all your designs.
                      sdetweil @awwbaker
                      @awwbaker on the write
                      see second post here
                      https://forums.raspberrypi.com/viewtopic.php?t=367431
                        awwbaker @sdetweil
                        Dear Mr @sdetweil
                        I think you are teaching me to fish…Did you see the error message below? Beyond the below, I booted the RPI 3B+, ran the “pinctrl set 6 op dl” command. Started MM and as previously the expected modules were hidden on start up. Pressing pushbutton did not have any affect on the display. I ran the button.py script and the button was sensed as previous. As your time permits I could use another push. Your efforts are VERY appreciated. VR Anthony Baker
                        2024-09-21 13:33:31.232] [LOG] Connecting socket for: MMM-MktIndex
                        [2024-09-21 13:33:31.234] [LOG] Sockets connected & modules started …
                        [1856:0921/133334.081312:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.DBus.StartServiceByName: object_path= /org/freedesktop/DBus: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
                        [2024-09-21 13:33:35.622] [LOG] Launching application.
                        [2024-09-21 13:33:55.076] [INFO] System information:
                        [2024-09-21 13:33:58.321] [ERROR] Whoops! There was an uncaught exception…
                        [2024-09-21 13:33:58.343] [ERROR] Error: EINVAL: invalid argument, write
                        errno: -22,
                        code: ‘EINVAL’,
                        syscall: ‘write’
                        [2024-09-21 13:33:58.345] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                        [2024-09-21 13:33:58.347] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                        [1976:0921/133401.533219:ERROR:gl_utils.cc(424)] [.WebGL-0x34004b5b00]GL Driver Message (OpenGL, Performance, GL_CLOSE_PATH_NV, High): GPU stall due to ReadPixels
                        [2024-09-21 13:34:01.636] [LOG] Create new calendarfetcher for url: http://p134-caldav.icloud.com/published/2/ODY3MDc3ODQxODY3MDc3OIsPCPqyTd7gfFTuhUgnU3E8veSROaMD9lC0bXMqbeTrcdUcRFgL2q0GROkcc6XtdbepSRYxUGbDtoDb3se2UkE - Interval: 604800000
                          sdetweil @awwbaker
                          @awwbaker i am on my phone, i can’t edit, and it wants to quote whole thing .
                          the os has changed the rules
                          i posted a response the other day to a topic that had some workarounds without coding changes
                            awwbaker @sdetweil
                            Dear Mr @sdetweil
                            Please see above, it seems “on-off” is throwing errors. It seems it is used by Remote-Control-Modules as well as Buttons. I wnet back and tried buttons. The error is below: Thank you very much. Anthony
                            [2024-09-22 11:34:50.557] [LOG] Launching application.
                            [2024-09-22 11:35:05.029] [ERROR] ERROR! Could not validate main module js file.
                            [2024-09-22 11:35:05.037] [ERROR] ReferenceError: Log is not defined
                            [2024-09-22 11:35:05.689] [INFO] System information:
                            [2024-09-22 11:35:13.286] [LOG] Initialize button monitor_control on PIN 6
                            [2024-09-22 11:35:13.293] [ERROR] Whoops! There was an uncaught exception…
                            [2024-09-22 11:35:13.318] [ERROR] Error: EINVAL: invalid argument, write
                            at exportGpio (/home/awwbaker/MagicMirror/modules/MMM-Buttons/node_modules/onoff/onoff.js:18:8)
                            at new Gpio (/home/awwbaker/MagicMirror/modules/MMM-Buttons/node_modules/onoff/onoff.js:172:36)
                            at Class.intializeButton (/home/awwbaker/MagicMirror/modules/MMM-Buttons/node_helper.js:74:19)
                            at Class.intializeButtons (/home/awwbaker/MagicMirror/modules/MMM-Buttons/node_helper.js:90:18)
                            at Class.socketNotificationReceived (/home/awwbaker/MagicMirror/modules/MMM-Buttons/node_helper.js:26:18)
                            errno: -22,
                            code: ‘EINVAL’,
                            syscall: ‘write’
                            [2024-09-22 11:35:13.335]
                              sdetweil @awwbaker
                              @awwbaker yes as i posted before
                              errno: -22,
                              code: ‘EINVAL’,
                              syscall: ‘write’
                              the os has changed how this needs to be done
                              i posted a link to suggestions on how to resolve it without code changes
                              the Log not found is caused by the remotecontrol module
                                awwbaker @sdetweil
                                Thank you, I tried the pinctrl to no avail. Thank you though! Anthony
                                  sdetweil @awwbaker
                                  @awwbaker did you solve this?
                                    awwbaker @sdetweil
                                    @sdetweil Sorry have been on travel last several weeks. No I never did. I have the remote control module in and working just never could not get the button push. I have mmm-GroveGesture installed and working with sensor. Still working towards getting modules to hide and show. Could I ask another question???
                                    What can/should I do on this?:
                                    [2024-10-28 10:10:15.299] [ERROR] ERROR! Could not validate main module js file.
                                    [2024-10-28 10:10:15.528] [ERROR] ReferenceError: Log is not defined
                                        at Object.<anonymous> (/home/awwbaker/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:28:158622)
                                        at Module._compile (node:internal/modules/cjs/loader:1484:14)
                                        at Module._extensions..js (node:internal/modules/cjs/loader:1564:10)
                                        at Module.load (node:internal/modules/cjs/loader:1295:32)
                                        at Module._load (node:internal/modules/cjs/loader:1111:12)
                                        at Module.require (node:internal/modules/cjs/loader:1318:19)
                                        at Class.loadModuleDefaultConfig (/home/awwbaker/MagicMirror/modules/MMM-Remote-Control/node_helper.js:318:30)
                                        at /home/awwbaker/MagicMirror/modules/MMM-Remote-Control/node_helper.js:272:26
                                      sdetweil @awwbaker
                                      @awwbaker remote control is loading the main js from other modules, but in the wrong runtime context.
                                      i don’t know why it is doing that
                                        awwbaker @sdetweil
                                        @sdetweil ,
                                        Hmmm…thanks Sam!!!
                                          ChrisLeduex
                                          Hi guys, I’ve been trying to figure this out too. I think I’m close with these two files using ‘pinctrl’ instead of ‘/sys/class/gpio/’ but I can’t figure out what I’m missing.
                                          Based on the console log it looks like there’s an issue in my node_helper file, possible with the socketNotification functions because I’m not seeing any of my test messages.
                                          And based on the log files there may be something missing from the package.json file because sometimes I get this error “Error: Cannot find module ‘node helper’ MODULE_NOT_FOUND” but other times I don’t. And I tried running this fix but couldn’t get it to work.
                                          [https://forum.magicmirror.builders/user/jorickjuh](link url)
                                          Other than that I’m not seeing any other errors and module does appear to be working but it’s just not processing any button presses. I’ll keep trying but I’ll post my progress so far on here in case someone can see what I’m missing.
                                          test file:
                                          Module.register("MMM-PinToggleTest", {
                                            defaults: {
                                              pin: 19,
                                              modulesToToggle: ["clock", "calendar"],
                                              interval: 1000
                                          //consol.log("MMM-PinToggleTest is starting...");
                                            start: function() {
                                              Log.info("MMM-PinToggleTest is starting, sending CONFIG...");
                                              consol.log("MMM-PinToggleTest is starting, sending CONFIG...");
                                              this.sendSocketNotification("CONFIG", {
                                                interval: this.config.interval,
                                                pin: this.config.pin
                                            start: function() {
                                              console.log("MMM-PinToggleTest started");
                                              this.previousPinState = null;
                                              // Request initial pin check from the helper
                                              this.sendSocketNotification("CONFIG", this.config);
                                              if (notification === "PIN_STATE") {
                                                const pinState = payload;
                                                console.log(`Received pin state: ${pinState}`);  // Log received state
                                                // Toggle modules based on pin state
                                                if (pinState !== this.previousPinState) {
                                                  this.previousPinState = pinState;
                                                  this.toggleModules(pinState === 1);
                                            toggleModules: function(show) {
                                              console.log(`Toggling modules to ${show ? "show" : "hide"}`);
                                              this.config.modulesToToggle.forEach(moduleName => {
                                                const modules = MM.getModules().withClass(moduleName);
                                                modules.forEach(module => {
                                                  if (show) {
                                                    module.show(1000);  // Show module with fade-in effect
                                                  } else {
                                                    module.hide(1000);  // Hide module with fade-out effect
                                            getDom: function() {
                                              const wrapper = document.createElement("div");
                                              wrapper.innerHTML = "<small>MMM-PinToggleTest</small>";
                                              return wrapper;
                                          node_helper:
                                          const NodeHelper = require("node_helper");
                                          const exec = require("child_process").exec;
                                          //const rpio = require("rpio");
                                          //const Gpio = require("onoff").Gpio;
                                            start: function() {
                                              console.log("node_helper for MMM-PinToggleTest has started.");  // Confirm helper initialization
                                              this.lastChangeTime = 0;
                                              this.debounceDelay = 200;
                                              if (notification === "CONFIG") {
                                                console.log("Received CONFIG in node_helper:", payload);  // Log receipt of configuration
                                                this.config = payload;
                                                this.schedulePinCheck();
                                            schedulePinCheck: function() {
                                              console.log(`Setting up pin check every ${this.config.interval} ms`); // Confirmation log
                                              setInterval(() => {
                                                this.checkPinState();
                                              }, this.config.interval);
                                            checkPinState: function() {
                                              const pinNumber = this.config.pin;
                                              exec(`pinctrl ${pinNumber}`, (error, stdout, stderr) => {
                                                if (error) {
                                                  console.error(`Error reading GPIO pin ${pinNumber}: ${stderr}`);
                                                  return;
                                                const pinState = parseInt(stdout.trim(), 10);
                                                const now = Date.now();
                                                console.log(`Current pin state for GPIO ${pinNumber}: ${pinState}`);
                                                if (pinState !== this.previousPinState && (now - this.lastChangeTime > this.debounceDelay)) {
                                                  this.lastChangeTime = now;
                                                  console.log(`Pin state changed to ${pinState} at ${new Date(now).toISOString()}`);
                                                  this.sendSocketNotification("PIN_STATE", pinState);
                                                  // Small delay to avoid multiple triggers
                                                  //setTimeout(() => {}, 100);
                                            sdetweil @ChrisLeduex
                                            @ChrisLeduex well, you don’t have any source errors. altho you have 2 start: functions in the modulename.js
                                            I see this as output of the pinctrl command on my pi 4
                                             pinctrl
                                             0: ip    pu | hi // ID_SDA/GPIO0 = input
                                             1: ip    pu | hi // ID_SCL/GPIO1 = input
                                             2: ip    pu | hi // GPIO2 = input
                                             3: ip    pu | hi // GPIO3 = input
                                             4: ip    pu | hi // GPIO4 = input
                                             5: ip    pu | hi // GPIO5 = input
                                             6: ip    pu | hi // GPIO6 = input
                                             7: ip    pu | hi // GPIO7 = input
                                             8: ip    pu | hi // GPIO8 = input
                                             9: ip    pd | lo // GPIO9 = input
                                            10: ip    pd | lo // GPIO10 = input
                                            11: ip    pd | lo // GPIO11 = input
                                            12: ip    pd | lo // GPIO12 = input
                                            13: ip    pd | lo // GPIO13 = input
                                            14: ip    pn | hi // GPIO14 = input
                                            15: ip    pu | hi // GPIO15 = input
                                            16: ip    pd | lo // GPIO16 = input
                                            17: ip    pd | lo // GPIO17 = input
                                            18: ip    pd | lo // GPIO18 = input
                                            19: ip    pd | lo // GPIO19 = input
                                            20: ip    pd | lo // GPIO20 = input
                                            21: ip    pd | lo // GPIO21 = input
                                            22: ip    pd | lo // GPIO22 = input
                                            23: ip    pd | lo // GPIO23 = input
                                            24: ip    pd | lo // GPIO24 = input
                                            25: ip    pd | lo // GPIO25 = input
                                            26: ip    pd | lo // GPIO26 = input
                                            27: ip    pd | lo // GPIO27 = input
                                            28: a5    pu | hi // RGMII_MDIO/GPIO28 = RGMII_MDIO
                                            29: a5    pd | lo // RGMIO_MDC/GPIO29 = RGMII_MDC
                                            30: a3    pu | lo // CTS0/GPIO30 = CTS0
                                            31: a3    pn | lo // RTS0/GPIO31 = RTS0
                                            32: a3    pn | hi // TXD0/GPIO32 = TXD0
                                            33: a3    pu | hi // RXD0/GPIO33 = RXD0
                                            34: a3    pn | hi // SD1_CLK/GPIO34 = SD1_CLK
                                            35: a3    pu | hi // SD1_CMD/GPIO35 = SD1_CMD
                                            36: a3    pu | hi // SD1_DATA0/GPIO36 = SD1_DAT0
                                            37: a3    pu | hi // SD1_DATA1/GPIO37 = SD1_DAT1
                                            38: a3    pu | hi // SD1_DATA2/GPIO38 = SD1_DAT2
                                            39: a3    pu | hi // SD1_DATA3/GPIO39 = SD1_DAT3
                                            40: a0    pn | lo // PWM0_MISO/GPIO40 = PWM1_0
                                            41: a0    pn | lo // PWM1_MOSI/GPIO41 = PWM1_1
                                            42: op -- pu | lo // STATUS_LED_G_CLK/GPIO42 = output
                                            43: ip    pu | hi // SPIFLASH_CE_N/GPIO43 = input
                                            44: ip    pu | hi // SDA0/GPIO44 = input
                                            45: ip    pu | hi // SCL0/GPIO45 = input
                                            46: ip    pu | lo // RGMII_RXCLK/GPIO46 = input
                                            47: ip    pu | lo // RGMII_RXCTL/GPIO47 = input
                                            48: ip    pd | lo // RGMII_RXD0/GPIO48 = input
                                            49: ip    pd | lo // RGMII_RXD1/GPIO49 = input
                                            50: ip    pd | lo // RGMII_RXD2/GPIO50 = input
                                            51: ip    pd | lo // RGMII_RXD3/GPIO51 = input
                                            52: ip    pd | lo // RGMII_TXCLK/GPIO52 = input
                                            53and : ip    pd | lo // RGMII_TXCTL/GPIO53 = input
                                            and this for output of pinctrl 19
                                            so the “pinctrl 19” command and parseInt(“19: ip pd | lo // GPIO19 = input”, 10);
                                            will return 19
                                            I think you meant pinctrl get 19, after sometime prior doing pinctrl set
                                            pinctrl help
                                            shows all it can do
