    Problem Adding Buttons & required Remote-Control Modules
    26 Posts 4 Posters 5.4k Views 4 Watching
      awwbaker
      Thank you so much for the info…I am a running a RPI-5.
        sdetweil @awwbaker
        @awwbaker said in Problem Adding Buttons & required Remote-Control Modules:
        [2024-09-16 15:04:01.418] [LOG] Initialize button monitor_control on PIN 25
        [2024-09-16 15:04:01.419] [LOG] MMM-Buttons: RPi model Raspberry Pi 5 Model B Rev 1.0
        [2024-09-16 15:04:01.419] [LOG] MMM-Buttons: RPi5 detected
        [2024-09-16 15:04:01.433] [LOG] Initialize button power on PIN 24
        [2024-09-16 15:04:01.434] [LOG] MMM-Buttons: RPi model Raspberry Pi 5 Model B Rev 1.0
        [2024-09-16 15:04:01.434] [LOG] MMM-Buttons: RPi5 detected
        did you test to make sure the buttons work outside MM?
          MarcLandis Module Developer @sdetweil
          @awwbaker
          it seems that the MMM-Jast module is throwing the error:
          [2024-09-16 15:04:00.408] [ERROR] ReferenceError: Log is not defined
          at Object. (/home/awwbaker/MagicMirror/modules/MMM-Jast/MMM-Jast.js:14:6243)
            sdetweil @MarcLandis
            @MarcLandis its because MagicMirror-remote-control is doing a require() on the module js
            A 2 Replies Last reply Reply Quote 0
              awwbaker @sdetweil
              Mr @sdetweil
              I tested my button press using:
              import RPi.GPIO as GPIO
              import time
              GPIO.setmode(GPIO.BCM)
              GPIO.setup(6, GPIO.IN, pull_up_down=GPIO.PUD_UP)
              while True:
              input_state = GPIO.input(6)
              if input_state == False:
              print(‘Button Pressed’)
              time.sleep(0.2)
              That worked fine. I found the module MMM-ModuleToggleButton which seemed a bit simpler and directly what wanted to do. The demo script used GPIO 6 so used default. Do i need to use a pull_down resister? Thank Thank you again! VR Anthony
              PS: Sam I looked for a link to buy you a cup of coffee, not found, but if you have one, please forward?
                awwbaker @sdetweil
                Mr @sdetweil, I also noted the below error ? Thank you!
                [2024-09-20 16:36:07.413] [LOG] Sockets connected & modules started …
                [2024-09-20 16:36:10.523] [LOG] Launching application.
                [2024-09-20 16:36:15.920] [INFO] System information:
                SYSTEM: manufacturer: ; model: ; raspberry: undefined; virtual: false
                OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.47+rpt-rpi-v8
                VERSIONS: electron: 31.1.0; used node: 20.14.0; installed node: 22.9.0; npm: 10.8.3; pm2: 5.4.1
                OTHER: timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
                [2024-09-20 16:36:20.989] [ERROR] Whoops! There was an uncaught exception…
                [2024-09-20 16:36:21.019] [ERROR] Error: EINVAL: invalid argument, write
                at Object.writeFileSync (node:fs:2346:20)
                at exportGpio (/home/awwbaker/MagicMirror/modules/MMM-ModuleToggleButton/node_modules/onoff/onoff.js:18:8)
                at new Gpio (/home/awwbaker/MagicMirror/modules/MMM-ModuleToggleButton/node_modules/onoff/onoff.js:172:36)
                at Class.socketNotificationReceived (/home/awwbaker/MagicMirror/modules/MMM-ModuleToggleButton/node_helper.js:20:22)
                at Socket. (/home/awwbaker/MagicMirror/js/node_helper.js:98:11)
                at Socket.emit (node:events:519:28)
                at Socket.emitUntyped (/home/awwbaker/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22)
                at /home/awwbaker/MagicMirror/node_modules/socket.io/dist/socket.js:704:39
                at process.processTicksAndRejections (node:internal/process/task_queues:77:11) {
                errno: -22,
                code: ‘EINVAL’,
                syscall: ‘write’
                [2024-09-20 16:36:21.022] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                [2024-09-20 16:36:21.027] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                [2024-09-20 16:36:21.066] [LOG] Create new calendarfetcher for url: http://p134-caldav.icloud.com/published/2/ODY3MDc3ODQxODY3MDc3OIsPCPqyTd7gfFTuhUgnU3E8veSROaMD9lC0bXMqbeTrcdUcRFgL2q0GROkcc6XtdbepSRYxUGbDtoDb3se2UkE - Interval: 604800000
                [2024-09-20 16:36:21.372] [LOG] Create new calendarfetcher for url: http://p134-caldav.icloud.com/published/2/ODY3MDc3ODQxODY3MDc3OIsPCPqyTd7gfFTuhUgnU3HnE0ZEnCaHErJrwvkzJ3o- -
                  sdetweil @awwbaker
                  @awwbaker ps: i don’t accept coffee etc. i do this because i truly enjoy it.
                  i love the challenge, the great people here, and the fascinatingly huge amount of differences among all your designs.
                    sdetweil @awwbaker
                    @awwbaker on the write
                    see second post here
                    https://forums.raspberrypi.com/viewtopic.php?t=367431
                      awwbaker @sdetweil
                      Dear Mr @sdetweil
                      I think you are teaching me to fish…Did you see the error message below? Beyond the below, I booted the RPI 3B+, ran the “pinctrl set 6 op dl” command. Started MM and as previously the expected modules were hidden on start up. Pressing pushbutton did not have any affect on the display. I ran the button.py script and the button was sensed as previous. As your time permits I could use another push. Your efforts are VERY appreciated. VR Anthony Baker
                      2024-09-21 13:33:31.232] [LOG] Connecting socket for: MMM-MktIndex
                      [2024-09-21 13:33:31.234] [LOG] Sockets connected & modules started …
                      [1856:0921/133334.081312:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.DBus.StartServiceByName: object_path= /org/freedesktop/DBus: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
                      [2024-09-21 13:33:35.622] [LOG] Launching application.
                      [2024-09-21 13:33:55.076] [INFO] System information:
                      [2024-09-21 13:33:58.321] [ERROR] Whoops! There was an uncaught exception…
                      [2024-09-21 13:33:58.343] [ERROR] Error: EINVAL: invalid argument, write
                      errno: -22,
                      code: ‘EINVAL’,
                      syscall: ‘write’
                      [2024-09-21 13:33:58.345] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                      [2024-09-21 13:33:58.347] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                      [1976:0921/133401.533219:ERROR:gl_utils.cc(424)] [.WebGL-0x34004b5b00]GL Driver Message (OpenGL, Performance, GL_CLOSE_PATH_NV, High): GPU stall due to ReadPixels
                      [2024-09-21 13:34:01.636] [LOG] Create new calendarfetcher for url: http://p134-caldav.icloud.com/published/2/ODY3MDc3ODQxODY3MDc3OIsPCPqyTd7gfFTuhUgnU3E8veSROaMD9lC0bXMqbeTrcdUcRFgL2q0GROkcc6XtdbepSRYxUGbDtoDb3se2UkE - Interval: 604800000
                        sdetweil @awwbaker
                        @awwbaker i am on my phone, i can’t edit, and it wants to quote whole thing .
                        the os has changed the rules
                        i posted a response the other day to a topic that had some workarounds without coding changes
                          awwbaker @sdetweil
                          Dear Mr @sdetweil
                          Please see above, it seems “on-off” is throwing errors. It seems it is used by Remote-Control-Modules as well as Buttons. I wnet back and tried buttons. The error is below: Thank you very much. Anthony
                          [2024-09-22 11:34:50.557] [LOG] Launching application.
                          [2024-09-22 11:35:05.029] [ERROR] ERROR! Could not validate main module js file.
                          [2024-09-22 11:35:05.037] [ERROR] ReferenceError: Log is not defined
                          at Object. (/home/awwbaker/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:28:158622)
                          at Module._compile (node:internal/modules/cjs/loader:1373:14)
                          at Module._extensions…js (node:internal/modules/cjs/loader:1432:10)
                          at Module.load (node:internal/modules/cjs/loader:1215:32)
                          at Module._load (node:internal/modules/cjs/loader:1031:12)
                          at c._load (node:electron/js2c/node_init:2:17025)
                          at Module.require (node:internal/modules/cjs/loader:1240:19)
                          at require (node:internal/modules/helpers:179:18)
                          at Class.loadModuleDefaultConfig (/home/awwbaker/MagicMirror/modules/MMM-Remote-Control/node_helper.js:314:30)
                          at /home/awwbaker/MagicMirror/modules/MMM-Remote-Control/node_helper.js:268:26
                          at FSReqCallback.oncomplete (node:fs:198:5)
                          [2024-09-22 11:35:05.689] [INFO] System information:
                          [2024-09-22 11:35:13.286] [LOG] Initialize button monitor_control on PIN 6
                          [2024-09-22 11:35:13.293] [ERROR] Whoops! There was an uncaught exception…
                          [2024-09-22 11:35:13.318] [ERROR] Error: EINVAL: invalid argument, write
                          at exportGpio (/home/awwbaker/MagicMirror/modules/MMM-Buttons/node_modules/onoff/onoff.js:18:8)
                          at new Gpio (/home/awwbaker/MagicMirror/modules/MMM-Buttons/node_modules/onoff/onoff.js:172:36)
                          at Class.intializeButton (/home/awwbaker/MagicMirror/modules/MMM-Buttons/node_helper.js:74:19)
                          at Class.intializeButtons (/home/awwbaker/MagicMirror/modules/MMM-Buttons/node_helper.js:90:18)
                          at Class.socketNotificationReceived (/home/awwbaker/MagicMirror/modules/MMM-Buttons/node_helper.js:26:18)
                          errno: -22,
                          code: ‘EINVAL’,
                          syscall: ‘write’
                          [2024-09-22 11:35:13.335]
                            sdetweil @awwbaker
                            @awwbaker yes as i posted before
                            errno: -22,
                            code: ‘EINVAL’,
                            syscall: ‘write’
                            the os has changed how this needs to be done
                            i posted a link to suggestions on how to resolve it without code changes
                            the Log not found is caused by the remotecontrol module
                              awwbaker @sdetweil
                              Thank you, I tried the pinctrl to no avail. Thank you though! Anthony
                                sdetweil @awwbaker
                                @awwbaker did you solve this?
                                  awwbaker @sdetweil
                                  @sdetweil Sorry have been on travel last several weeks. No I never did. I have the remote control module in and working just never could not get the button push. I have mmm-GroveGesture installed and working with sensor. Still working towards getting modules to hide and show. Could I ask another question???
                                  What can/should I do on this?:
                                  [2024-10-28 10:10:15.299] [ERROR] ERROR! Could not validate main module js file.
                                  [2024-10-28 10:10:15.528] [ERROR] ReferenceError: Log is not defined
                                      at Object.<anonymous> (/home/awwbaker/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:28:158622)
                                      at Module._compile (node:internal/modules/cjs/loader:1484:14)
                                      at Module._extensions..js (node:internal/modules/cjs/loader:1564:10)
                                      at Module.load (node:internal/modules/cjs/loader:1295:32)
                                      at Module._load (node:internal/modules/cjs/loader:1111:12)
                                      at Module.require (node:internal/modules/cjs/loader:1318:19)
                                      at Class.loadModuleDefaultConfig (/home/awwbaker/MagicMirror/modules/MMM-Remote-Control/node_helper.js:318:30)
                                      at /home/awwbaker/MagicMirror/modules/MMM-Remote-Control/node_helper.js:272:26
                                    sdetweil @awwbaker
                                    @awwbaker remote control is loading the main js from other modules, but in the wrong runtime context.
                                    i don’t know why it is doing that
                                      awwbaker @sdetweil
                                      @sdetweil ,
                                      Hmmm…thanks Sam!!!
                                        ChrisLeduex
                                        Hi guys, I’ve been trying to figure this out too. I think I’m close with these two files using ‘pinctrl’ instead of ‘/sys/class/gpio/’ but I can’t figure out what I’m missing.
                                        Based on the console log it looks like there’s an issue in my node_helper file, possible with the socketNotification functions because I’m not seeing any of my test messages.
                                        And based on the log files there may be something missing from the package.json file because sometimes I get this error “Error: Cannot find module ‘node helper’ MODULE_NOT_FOUND” but other times I don’t. And I tried running this fix but couldn’t get it to work.
                                        [https://forum.magicmirror.builders/user/jorickjuh](link url)
                                        Other than that I’m not seeing any other errors and module does appear to be working but it’s just not processing any button presses. I’ll keep trying but I’ll post my progress so far on here in case someone can see what I’m missing.
                                        test file:
                                        Module.register("MMM-PinToggleTest", {
                                          defaults: {
                                            pin: 19,
                                            modulesToToggle: ["clock", "calendar"],
                                            interval: 1000
                                        //consol.log("MMM-PinToggleTest is starting...");
                                          start: function() {
                                            Log.info("MMM-PinToggleTest is starting, sending CONFIG...");
                                            consol.log("MMM-PinToggleTest is starting, sending CONFIG...");
                                            this.sendSocketNotification("CONFIG", {
                                              interval: this.config.interval,
                                              pin: this.config.pin
                                          start: function() {
                                            console.log("MMM-PinToggleTest started");
                                            this.previousPinState = null;
                                            // Request initial pin check from the helper
                                            this.sendSocketNotification("CONFIG", this.config);
                                            if (notification === "PIN_STATE") {
                                              const pinState = payload;
                                              console.log(`Received pin state: ${pinState}`);  // Log received state
                                              // Toggle modules based on pin state
                                              if (pinState !== this.previousPinState) {
                                                this.previousPinState = pinState;
                                                this.toggleModules(pinState === 1);
                                          toggleModules: function(show) {
                                            console.log(`Toggling modules to ${show ? "show" : "hide"}`);
                                            this.config.modulesToToggle.forEach(moduleName => {
                                              const modules = MM.getModules().withClass(moduleName);
                                              modules.forEach(module => {
                                                if (show) {
                                                  module.show(1000);  // Show module with fade-in effect
                                                } else {
                                                  module.hide(1000);  // Hide module with fade-out effect
                                          getDom: function() {
                                            const wrapper = document.createElement("div");
                                            wrapper.innerHTML = "<small>MMM-PinToggleTest</small>";
                                            return wrapper;
                                        node_helper:
                                        const NodeHelper = require("node_helper");
                                        const exec = require("child_process").exec;
                                        //const rpio = require("rpio");
                                        //const Gpio = require("onoff").Gpio;
                                          start: function() {
                                            console.log("node_helper for MMM-PinToggleTest has started.");  // Confirm helper initialization
                                            this.lastChangeTime = 0;
                                            this.debounceDelay = 200;
                                            if (notification === "CONFIG") {
                                              console.log("Received CONFIG in node_helper:", payload);  // Log receipt of configuration
                                              this.config = payload;
                                              this.schedulePinCheck();
                                          schedulePinCheck: function() {
                                            console.log(`Setting up pin check every ${this.config.interval} ms`); // Confirmation log
                                            setInterval(() => {
                                              this.checkPinState();
                                            }, this.config.interval);
                                          checkPinState: function() {
                                            const pinNumber = this.config.pin;
                                            exec(`pinctrl ${pinNumber}`, (error, stdout, stderr) => {
                                              if (error) {
                                                console.error(`Error reading GPIO pin ${pinNumber}: ${stderr}`);
                                                return;
                                              const pinState = parseInt(stdout.trim(), 10);
                                              const now = Date.now();
                                              console.log(`Current pin state for GPIO ${pinNumber}: ${pinState}`);
                                              if (pinState !== this.previousPinState && (now - this.lastChangeTime > this.debounceDelay)) {
                                                this.lastChangeTime = now;
                                                console.log(`Pin state changed to ${pinState} at ${new Date(now).toISOString()}`);
                                                this.sendSocketNotification("PIN_STATE", pinState);
                                                // Small delay to avoid multiple triggers
                                                //setTimeout(() => {}, 100);
                                          sdetweil @ChrisLeduex
                                          @ChrisLeduex well, you don’t have any source errors. altho you have 2 start: functions in the modulename.js
                                          I see this as output of the pinctrl command on my pi 4
                                           pinctrl
                                           0: ip    pu | hi // ID_SDA/GPIO0 = input
                                           1: ip    pu | hi // ID_SCL/GPIO1 = input
                                           2: ip    pu | hi // GPIO2 = input
                                           3: ip    pu | hi // GPIO3 = input
                                           4: ip    pu | hi // GPIO4 = input
                                           5: ip    pu | hi // GPIO5 = input
                                           6: ip    pu | hi // GPIO6 = input
                                           7: ip    pu | hi // GPIO7 = input
                                           8: ip    pu | hi // GPIO8 = input
                                           9: ip    pd | lo // GPIO9 = input
                                          10: ip    pd | lo // GPIO10 = input
                                          11: ip    pd | lo // GPIO11 = input
                                          12: ip    pd | lo // GPIO12 = input
                                          13: ip    pd | lo // GPIO13 = input
                                          14: ip    pn | hi // GPIO14 = input
                                          15: ip    pu | hi // GPIO15 = input
                                          16: ip    pd | lo // GPIO16 = input
                                          17: ip    pd | lo // GPIO17 = input
                                          18: ip    pd | lo // GPIO18 = input
                                          19: ip    pd | lo // GPIO19 = input
                                          20: ip    pd | lo // GPIO20 = input
                                          21: ip    pd | lo // GPIO21 = input
                                          22: ip    pd | lo // GPIO22 = input
                                          23: ip    pd | lo // GPIO23 = input
                                          24: ip    pd | lo // GPIO24 = input
                                          25: ip    pd | lo // GPIO25 = input
                                          26: ip    pd | lo // GPIO26 = input
                                          27: ip    pd | lo // GPIO27 = input
                                          28: a5    pu | hi // RGMII_MDIO/GPIO28 = RGMII_MDIO
                                          29: a5    pd | lo // RGMIO_MDC/GPIO29 = RGMII_MDC
                                          30: a3    pu | lo // CTS0/GPIO30 = CTS0
                                          31: a3    pn | lo // RTS0/GPIO31 = RTS0
                                          32: a3    pn | hi // TXD0/GPIO32 = TXD0
                                          33: a3    pu | hi // RXD0/GPIO33 = RXD0
                                          34: a3    pn | hi // SD1_CLK/GPIO34 = SD1_CLK
                                          35: a3    pu | hi // SD1_CMD/GPIO35 = SD1_CMD
                                          36: a3    pu | hi // SD1_DATA0/GPIO36 = SD1_DAT0
                                          37: a3    pu | hi // SD1_DATA1/GPIO37 = SD1_DAT1
                                          38: a3    pu | hi // SD1_DATA2/GPIO38 = SD1_DAT2
                                          39: a3    pu | hi // SD1_DATA3/GPIO39 = SD1_DAT3
                                          40: a0    pn | lo // PWM0_MISO/GPIO40 = PWM1_0
                                          41: a0    pn | lo // PWM1_MOSI/GPIO41 = PWM1_1
                                          42: op -- pu | lo // STATUS_LED_G_CLK/GPIO42 = output
                                          43: ip    pu | hi // SPIFLASH_CE_N/GPIO43 = input
                                          44: ip    pu | hi // SDA0/GPIO44 = input
                                          45: ip    pu | hi // SCL0/GPIO45 = input
                                          46: ip    pu | lo // RGMII_RXCLK/GPIO46 = input
                                          47: ip    pu | lo // RGMII_RXCTL/GPIO47 = input
                                          48: ip    pd | lo // RGMII_RXD0/GPIO48 = input
                                          49: ip    pd | lo // RGMII_RXD1/GPIO49 = input
                                          50: ip    pd | lo // RGMII_RXD2/GPIO50 = input
                                          51: ip    pd | lo // RGMII_RXD3/GPIO51 = input
                                          52: ip    pd | lo // RGMII_TXCLK/GPIO52 = input
                                          53and : ip    pd | lo // RGMII_TXCTL/GPIO53 = input
                                          and this for output of pinctrl 19
                                          so the “pinctrl 19” command and parseInt(“19: ip pd | lo // GPIO19 = input”, 10);
                                          will return 19
                                          I think you meant pinctrl get 19, after sometime prior doing pinctrl set
                                          pinctrl help
                                          shows all it can do
                                            ChrisLeduex @sdetweil
                                            @sdetweil Thank you for catching those, too much copying and pasting.
                                            Removed one of the start functions from the module.js file and also updated this line in the node_helper.js file so now it is returning the pin state instead of the pin number.
                                            //const pinState = parseInt(stdout.trim(), 10);
                                            const pinState = stdout.includes(“hi”) ? 1 : 0;
                                            There still seems to be an issue somewhere in my node_helper.js file though because I’m still not seeing anything from that file in the console. Looking through the forum it seems node_helper file issues are common and I’ve tried implementing a few of the solutions I found there but still haven’t found the problem but I will keep trying. I suspect maybe I’m not nesting my socket notifications correctly.
                                            PinToggleTest.js
                                              defaults: {
                                                pin: 19,
                                                interval: 1000
                                              start: function() {
                                            		if (notification === 'STARTED') {
                                                console.log("STARTED notification received from node_helper");
                                                this.config.text = 'Started';
                                                this.updateDom();
                                                    if (show) {
                                                    } else {
                                                return wrapper;
                                            node_helper.js
                                            //module.exports = NodeHelper.create({
                                            //  start: function() {
                                            //    console.log("Starting node_helper for MMM-PinToggleTest");
                                            //    this.previousPinState = null;
                                            //    this.config = null;
                                              start() {
                                                this.started = false;
                                                if (notification === "CONFIG" && !this.started) {
                                                  const self = this;
                                                  console.log("CONFIG notification received");
                                                  this.sendSocketNotification('STARTED', {message: 'test'});
                                                  console.log("STARTED notification sent back to front end");
                                                setInterval(() => {
                                                // Execute pinctrl command
                                                exec(`pinctrl get ${pinNumber}`, (error, stdout, stderr) => {
                                                  if (error) {
                                                    return;
                                                  const pinState = stdout.includes("hi") ? 1 : 0;
                                                  console.log(`Detected pin state for pin ${pinNumber}: ${pinState}`);  // Log the detected state
                                                  // Only send if state has changed
                                                    console.log(`Pin state changed to ${pinState}`);
