    Problem Adding Buttons & required Remote-Control Modules
    26 Posts 4 Posters 3.9k Views 4 Watching
      sdetweil @MarcLandis
      @MarcLandis its because MagicMirror-remote-control is doing a require() on the module js
      A 2 Replies Last reply Reply Quote 0
        awwbaker @sdetweil
        Mr @sdetweil
        I tested my button press using:
        import RPi.GPIO as GPIO
        import time
        GPIO.setmode(GPIO.BCM)
        GPIO.setup(6, GPIO.IN, pull_up_down=GPIO.PUD_UP)
        while True:
        input_state = GPIO.input(6)
        if input_state == False:
        print(‘Button Pressed’)
        time.sleep(0.2)
        That worked fine. I found the module MMM-ModuleToggleButton which seemed a bit simpler and directly what wanted to do. The demo script used GPIO 6 so used default. Do i need to use a pull_down resister? Thank Thank you again! VR Anthony
        PS: Sam I looked for a link to buy you a cup of coffee, not found, but if you have one, please forward?
          awwbaker @sdetweil
          Mr @sdetweil, I also noted the below error ? Thank you!
          [2024-09-20 16:36:07.413] [LOG] Sockets connected & modules started …
          [2024-09-20 16:36:10.523] [LOG] Launching application.
          [2024-09-20 16:36:15.920] [INFO] System information:
          SYSTEM: manufacturer: ; model: ; raspberry: undefined; virtual: false
          OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.47+rpt-rpi-v8
          VERSIONS: electron: 31.1.0; used node: 20.14.0; installed node: 22.9.0; npm: 10.8.3; pm2: 5.4.1
          OTHER: timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
          [2024-09-20 16:36:20.989] [ERROR] Whoops! There was an uncaught exception…
          [2024-09-20 16:36:21.019] [ERROR] Error: EINVAL: invalid argument, write
          at Object.writeFileSync (node:fs:2346:20)
          at exportGpio (/home/awwbaker/MagicMirror/modules/MMM-ModuleToggleButton/node_modules/onoff/onoff.js:18:8)
          at new Gpio (/home/awwbaker/MagicMirror/modules/MMM-ModuleToggleButton/node_modules/onoff/onoff.js:172:36)
          at Class.socketNotificationReceived (/home/awwbaker/MagicMirror/modules/MMM-ModuleToggleButton/node_helper.js:20:22)
          at Socket. (/home/awwbaker/MagicMirror/js/node_helper.js:98:11)
          at Socket.emit (node:events:519:28)
          at Socket.emitUntyped (/home/awwbaker/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22)
          at /home/awwbaker/MagicMirror/node_modules/socket.io/dist/socket.js:704:39
          at process.processTicksAndRejections (node:internal/process/task_queues:77:11) {
          errno: -22,
          code: ‘EINVAL’,
          syscall: ‘write’
          [2024-09-20 16:36:21.022] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [2024-09-20 16:36:21.027] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
          [2024-09-20 16:36:21.066] [LOG] Create new calendarfetcher for url: http://p134-caldav.icloud.com/published/2/ODY3MDc3ODQxODY3MDc3OIsPCPqyTd7gfFTuhUgnU3E8veSROaMD9lC0bXMqbeTrcdUcRFgL2q0GROkcc6XtdbepSRYxUGbDtoDb3se2UkE - Interval: 604800000
          [2024-09-20 16:36:21.372] [LOG] Create new calendarfetcher for url: http://p134-caldav.icloud.com/published/2/ODY3MDc3ODQxODY3MDc3OIsPCPqyTd7gfFTuhUgnU3HnE0ZEnCaHErJrwvkzJ3o- -
            sdetweil @awwbaker
            @awwbaker ps: i don’t accept coffee etc. i do this because i truly enjoy it.
            i love the challenge, the great people here, and the fascinatingly huge amount of differences among all your designs.
              sdetweil @awwbaker
              @awwbaker on the write
              see second post here
              https://forums.raspberrypi.com/viewtopic.php?t=367431
                awwbaker @sdetweil
                Dear Mr @sdetweil
                I think you are teaching me to fish…Did you see the error message below? Beyond the below, I booted the RPI 3B+, ran the “pinctrl set 6 op dl” command. Started MM and as previously the expected modules were hidden on start up. Pressing pushbutton did not have any affect on the display. I ran the button.py script and the button was sensed as previous. As your time permits I could use another push. Your efforts are VERY appreciated. VR Anthony Baker
                2024-09-21 13:33:31.232] [LOG] Connecting socket for: MMM-MktIndex
                [2024-09-21 13:33:31.234] [LOG] Sockets connected & modules started …
                [1856:0921/133334.081312:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.DBus.StartServiceByName: object_path= /org/freedesktop/DBus: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
                [2024-09-21 13:33:35.622] [LOG] Launching application.
                [2024-09-21 13:33:55.076] [INFO] System information:
                [2024-09-21 13:33:58.321] [ERROR] Whoops! There was an uncaught exception…
                [2024-09-21 13:33:58.343] [ERROR] Error: EINVAL: invalid argument, write
                errno: -22,
                code: ‘EINVAL’,
                syscall: ‘write’
                [2024-09-21 13:33:58.345] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                [2024-09-21 13:33:58.347] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                [1976:0921/133401.533219:ERROR:gl_utils.cc(424)] [.WebGL-0x34004b5b00]GL Driver Message (OpenGL, Performance, GL_CLOSE_PATH_NV, High): GPU stall due to ReadPixels
                [2024-09-21 13:34:01.636] [LOG] Create new calendarfetcher for url: http://p134-caldav.icloud.com/published/2/ODY3MDc3ODQxODY3MDc3OIsPCPqyTd7gfFTuhUgnU3E8veSROaMD9lC0bXMqbeTrcdUcRFgL2q0GROkcc6XtdbepSRYxUGbDtoDb3se2UkE - Interval: 604800000
                  sdetweil @awwbaker
                  @awwbaker i am on my phone, i can’t edit, and it wants to quote whole thing .
                  the os has changed the rules
                  i posted a response the other day to a topic that had some workarounds without coding changes
                    awwbaker @sdetweil
                    Dear Mr @sdetweil
                    Please see above, it seems “on-off” is throwing errors. It seems it is used by Remote-Control-Modules as well as Buttons. I wnet back and tried buttons. The error is below: Thank you very much. Anthony
                    [2024-09-22 11:34:50.557] [LOG] Launching application.
                    [2024-09-22 11:35:05.029] [ERROR] ERROR! Could not validate main module js file.
                    [2024-09-22 11:35:05.037] [ERROR] ReferenceError: Log is not defined
                    at Object. (/home/awwbaker/MagicMirror/modules/MMM-RAIN-MAP/MMM-RAIN-MAP.js:28:158622)
                    at Module._compile (node:internal/modules/cjs/loader:1373:14)
                    at Module._extensions…js (node:internal/modules/cjs/loader:1432:10)
                    at Module.load (node:internal/modules/cjs/loader:1215:32)
                    at Module._load (node:internal/modules/cjs/loader:1031:12)
                    at c._load (node:electron/js2c/node_init:2:17025)
                    at Module.require (node:internal/modules/cjs/loader:1240:19)
                    at require (node:internal/modules/helpers:179:18)
                    at Class.loadModuleDefaultConfig (/home/awwbaker/MagicMirror/modules/MMM-Remote-Control/node_helper.js:314:30)
                    at /home/awwbaker/MagicMirror/modules/MMM-Remote-Control/node_helper.js:268:26
                    at FSReqCallback.oncomplete (node:fs:198:5)
                    [2024-09-22 11:35:05.689] [INFO] System information:
                    [2024-09-22 11:35:13.286] [LOG] Initialize button monitor_control on PIN 6
                    [2024-09-22 11:35:13.293] [ERROR] Whoops! There was an uncaught exception…
                    [2024-09-22 11:35:13.318] [ERROR] Error: EINVAL: invalid argument, write
                    at exportGpio (/home/awwbaker/MagicMirror/modules/MMM-Buttons/node_modules/onoff/onoff.js:18:8)
                    at new Gpio (/home/awwbaker/MagicMirror/modules/MMM-Buttons/node_modules/onoff/onoff.js:172:36)
                    at Class.intializeButton (/home/awwbaker/MagicMirror/modules/MMM-Buttons/node_helper.js:74:19)
                    at Class.intializeButtons (/home/awwbaker/MagicMirror/modules/MMM-Buttons/node_helper.js:90:18)
                    at Class.socketNotificationReceived (/home/awwbaker/MagicMirror/modules/MMM-Buttons/node_helper.js:26:18)
                    errno: -22,
                    code: ‘EINVAL’,
                    syscall: ‘write’
                    [2024-09-22 11:35:13.335]
                      sdetweil @awwbaker
                      @awwbaker yes as i posted before
                      errno: -22,
                      code: ‘EINVAL’,
                      syscall: ‘write’
                      the os has changed how this needs to be done
                      i posted a link to suggestions on how to resolve it without code changes
                      the Log not found is caused by the remotecontrol module
                        awwbaker @sdetweil
                        Thank you, I tried the pinctrl to no avail. Thank you though! Anthony
