    2.29.0 Weather Module w/api v3.0 works, sort of…
    25 Posts 5 Posters 8.7k Views 5 Watching
      reilley
      Updated MM2 today to v2.29.0. Learned quickly that the api change forces you subscribe to the One Call v3.0 and provide a payment method but no big deal as long as you stay under 1000 calls per day.
      It took some configuration editing to get the current and forecast sections working, specifically adding the apiVersion parameter and of course the new api key. It still didn’t work, so I added weatherEndpoint ‘/onecall’ and this resolved the problem, but now the location header reads “America/New York”. If you use One Call , the location and locationId parameters are ignored. Just not sure why the first shows incorrectly.
      Anyone else having this issue?
      D S 2 Replies Last reply Reply Quote 0
        reilley
        OK, it would appear when /onecall is used, the OpenWeatherMap.js script controls the header and you’re either going to get:
        ${data.timezone}
        or
        ${data.city.name},${data.city.country}
        I’m see the first option, timezone. It’s correct, but I don’t want timezone. I want city/country. Booooo!!!
          dawookie1979 @reilley
          @reilley Hi, i cant get mine to load!!
            sdetweil @reilley
            @reilley for the doc
            note MagicMirror is case sensitive
            locationId is incorrect
              reilley @sdetweil
              @sdetweil - Hi Sam! I’m not even calling locationID in my script.
              Here’s what I have:
              module: “weather”,
              position: “top_center”,
              weatherProvider: “openweathermap”,
              type: “current:,
              weatherEndpoint: ‘/onecall’,
              lat: ‘34.17188’.
              lon: ‘-84.57056’,
              apiVersion: ‘3.0’,
              apiKey: 'nunya”
                reilley @sdetweil
                @sdetweil - Oh okay - I was wondering why you mentioned case. That was just a typo here on my part. When I was using it, it was “locationID”.
                • H Offline
                  HeikoGr
                  forecast need lot / lan set. locationID as in api 2.5 isn’t working anymore (with api 3.0) sorry, didn’t read your post properly…
                  openweather doesn’t add geoname in response. so i guess it’s the timezone.
                    reilley
                    ${data.timezone}
                    or
                      Peter @reilley
                      @reilley did you get it working with city, country?
                      Peter
                        reilley @Peter
                        @Peter - Unfortunately, not yet. I’m wondering if anyone has been able to using the 3.0 API!
                        • H Offline
                          HeikoGr
                          I got it working and think there are a few tricky typos in your config.
                          module: “weather”,
                          type: “current:,
                          lat: ‘34.17188’.
                          lon: ‘-84.57056’,
                          apiVersion: ‘3.0’,
                          apiKey: 'nunya”
                          Line 5: closing quotation marks are missing
                          Line 7: point as line ending instead of comma
                          Line 10: wrong quotation mark
                          Your config entry type is from line 5 - 10.
                          P R 2 Replies Last reply Reply Quote 1
                            Peter @HeikoGr
                            @HeikoGr does it show country and city in the header?
                            Peter
                            • H Offline
                              HeikoGr @Peter
                              @Peter no, unfortunately not
                                Peter @HeikoGr
                                @HeikoGr what does it show in the header?
                                And do you see the right weather for your location?
                                Peter
                                • H Offline
                                  HeikoGr @Peter
                                  @Peter it shows the timezone „EUROPE/BERLIN“, but the weather is correct.
                                  P R 2 Replies Last reply Reply Quote 0
                                    Peter @HeikoGr
                                    @HeikoGr can you share your config?
                                    Without the key and only the weatherpart.
                                    Thanks!
                                    Peter
                                    • H Offline
                                      HeikoGr @Peter
                                      @Peter of course
                                                  disabled: false,
                                                  module: "weather",
                                                  config:
                                                      weatherProvider: 'openweathermap',
                                                      weatherEndpoint: '/onecall',
                                                      apiKey: 'apikey',
                                                      apiVersion: '3.0',
                                                      lat: '50.465',
                                                      lon: '9.481',
                                                      type: 'forecast',
                                                      colored: true,
                                                      fade: false,
                                                      maxNumberOfDays: 3,
                                                      degreeLabel: 'true',
                                                      showWindDirectionAsArrow: 'true',
                                                      decimalSymbol: ','
                                        Peter @HeikoGr
                                        @HeikoGr thanks.
                                        I will try tomorrow.
                                        I will let you know!
                                        Peter
                                          reilley @HeikoGr
                                          @HeikoGr - so as it was said before, we’re not going to see our city the way we did under v2.5 of the API. That’s going to likely need a response from the MM2 dev team because if /open call is used, it’s timezone/city only. It seems api 3.0 broke the location/locationID functionality when using “current” or “forecast”. Or did someone else get it to work?
                                            sdetweil @reilley
                                            @reilley that’s open weather 3.0 is /onecall only
                                            nothing we can do but force you to specify the header yourself
                                            does that work or get overridden by the weather data?
                                            i am not where i can test
                                              reilley @sdetweil
                                              @sdetweil - sure, I’d be happy to force my header if that’s possible. So for example, with forecast I would want it to say:
                                              Forecast - Canton, GA
                                              Or similar, of course. I could test it if you could let me know where to insert that line of code.
