    2.29.0 Weather Module w/api v3.0 works, sort of…
    25 Posts 5 Posters 8.9k Views 5 Watching
      reilley
      OK, it would appear when /onecall is used, the OpenWeatherMap.js script controls the header and you’re either going to get:
      ${data.timezone}
      or
      ${data.city.name},${data.city.country}
      I’m see the first option, timezone. It’s correct, but I don’t want timezone. I want city/country. Booooo!!!
        Peter @reilley
        @reilley did you get it working with city, country?
        Peter
          reilley @Peter
          @Peter - Unfortunately, not yet. I’m wondering if anyone has been able to using the 3.0 API!
          • H
            HeikoGr
            I got it working and think there are a few tricky typos in your config.
            module: “weather”,
            position: “top_center”,
            weatherProvider: “openweathermap”,
            type: “current:,
            weatherEndpoint: ‘/onecall’,
            lat: ‘34.17188’.
            lon: ‘-84.57056’,
            apiVersion: ‘3.0’,
            apiKey: 'nunya”
            Line 5: closing quotation marks are missing
            Line 7: point as line ending instead of comma
            Line 10: wrong quotation mark
            Your config entry type is from line 5 - 10.
            P R 2 Replies Last reply Reply Quote 1
              Peter @HeikoGr
              @HeikoGr does it show country and city in the header?
              Peter
              • H
                HeikoGr @Peter
                @Peter no, unfortunately not
                  Peter @HeikoGr
                  @HeikoGr what does it show in the header?
                  And do you see the right weather for your location?
                  Peter
                  • H
                    HeikoGr @Peter
                    @Peter it shows the timezone „EUROPE/BERLIN“, but the weather is correct.
                    P R 2 Replies Last reply Reply Quote 0
                      Peter @HeikoGr
                      @HeikoGr can you share your config?
                      Without the key and only the weatherpart.
                      Thanks!
                      Peter
                      • H
                        HeikoGr @Peter
                        @Peter of course
                                    disabled: false,
                                    module: "weather",
                                    config:
                                        weatherProvider: 'openweathermap',
                                        weatherEndpoint: '/onecall',
                                        apiKey: 'apikey',
                                        apiVersion: '3.0',
                                        lat: '50.465',
                                        lon: '9.481',
                                        type: 'forecast',
                                        colored: true,
                                        fade: false,
                                        maxNumberOfDays: 3,
                                        degreeLabel: 'true',
                                        showWindDirectionAsArrow: 'true',
                                        decimalSymbol: ','
                          Peter @HeikoGr
                          @HeikoGr thanks.
                          I will try tomorrow.
                          I will let you know!
                          Peter
                            reilley @HeikoGr
                            @HeikoGr - so as it was said before, we’re not going to see our city the way we did under v2.5 of the API. That’s going to likely need a response from the MM2 dev team because if /open call is used, it’s timezone/city only. It seems api 3.0 broke the location/locationID functionality when using “current” or “forecast”. Or did someone else get it to work?
                              sdetweil @reilley
                              @reilley that’s open weather 3.0 is /onecall only
                              nothing we can do but force you to specify the header yourself
                              does that work or get overridden by the weather data?
                              i am not where i can test
                                reilley @sdetweil
                                @sdetweil - sure, I’d be happy to force my header if that’s possible. So for example, with forecast I would want it to say:
                                Forecast - Canton, GA
                                Or similar, of course. I could test it if you could let me know where to insert that line of code.
                                  reilley @HeikoGr
                                  @HeikoGr - sorry, I didn’t copy/paste from the actual editor. I typed all that in and made a few errors! Sorry for the goose chase!
                                    sdetweil @reilley
                                    @reilley header is a property beside module
                                    • H
                                      HeikoGr
                                      I just tested it. You can pass a header by yourself but need to add
                                      appendLocationNameToHeader: false,
                                      Otherwise it will add the timezone again.
                                                  disabled: false,
                                                  module: "weather",
                                                  header: "YOURCITY",
                                                  config:
                                                      apiKey: 'API',
                                                      apiVersion: '3.0',
                                                      lat: '51.5',
                                                      lon: '9.52',
                                                      type: 'forecast',
                                                      colored: true,
                                                      fade: false,
                                                      maxNumberOfDays: 3,
                                                      decimalSymbol: ','
                                        reilley @HeikoGr
                                        @HeikoGr - lol, adjusted my headers and saw that the timezone was concatenated to the header. Snapped a photo to post and saw your comment. That fixed it!!! Thank you and Sam both!!!
                                          Peter @reilley
                                          @reilley here it works also!
                                          Thank you, everyone who helped.
                                          My MM is up and running great!
                                          Peter
