    2.29.0 Weather Module w/api v3.0 works, sort of…
    25 Posts 5 Posters 6.9k Views 5 Watching
      reilley @sdetweil
      @sdetweil - Oh okay - I was wondering why you mentioned case. That was just a typo here on my part. When I was using it, it was “locationID”.
      • H Offline
        HeikoGr
        forecast need lot / lan set. locationID as in api 2.5 isn’t working anymore (with api 3.0) sorry, didn’t read your post properly…
        openweather doesn’t add geoname in response. so i guess it’s the timezone.
          reilley
          OK, it would appear when /onecall is used, the OpenWeatherMap.js script controls the header and you’re either going to get:
          ${data.timezone}
          or
          ${data.city.name},${data.city.country}
          I’m see the first option, timezone. It’s correct, but I don’t want timezone. I want city/country. Booooo!!!
            Peter @reilley
            @reilley did you get it working with city, country?
            Peter
              reilley @Peter
              @Peter - Unfortunately, not yet. I’m wondering if anyone has been able to using the 3.0 API!
              • H Offline
                HeikoGr
                I got it working and think there are a few tricky typos in your config.
                module: “weather”,
                position: “top_center”,
                weatherProvider: “openweathermap”,
                type: “current:,
                weatherEndpoint: ‘/onecall’,
                lat: ‘34.17188’.
                lon: ‘-84.57056’,
                apiVersion: ‘3.0’,
                apiKey: 'nunya”
                Line 5: closing quotation marks are missing
                Line 7: point as line ending instead of comma
                Line 10: wrong quotation mark
                Your config entry type is from line 5 - 10.
                P R 2 Replies Last reply Reply Quote 1
                  Peter @HeikoGr
                  @HeikoGr does it show country and city in the header?
                  Peter
                  • H Offline
                    HeikoGr @Peter
                    @Peter no, unfortunately not
                      Peter @HeikoGr
                      @HeikoGr what does it show in the header?
                      And do you see the right weather for your location?
                      Peter
                      • H Offline
                        HeikoGr @Peter
                        @Peter it shows the timezone „EUROPE/BERLIN“, but the weather is correct.
                        P R 2 Replies Last reply Reply Quote 0
