    2.29.0 Weather Module w/api v3.0 works, sort of…
    25 Posts 5 Posters 6.9k Views 5 Watching
      dawookie1979 @reilley
      @reilley Hi, i cant get mine to load!!
        sdetweil @reilley
        @reilley for the doc
        note MagicMirror is case sensitive
        locationId is incorrect
          reilley @sdetweil
          @sdetweil - Hi Sam! I’m not even calling locationID in my script.
          Here’s what I have:
          module: “weather”,
          position: “top_center”,
          weatherProvider: “openweathermap”,
          type: “current:,
          weatherEndpoint: ‘/onecall’,
          lat: ‘34.17188’.
          lon: ‘-84.57056’,
          apiVersion: ‘3.0’,
          apiKey: 'nunya”
            reilley @sdetweil
            @sdetweil - Oh okay - I was wondering why you mentioned case. That was just a typo here on my part. When I was using it, it was “locationID”.
            • H Offline
              HeikoGr
              forecast need lot / lan set. locationID as in api 2.5 isn’t working anymore (with api 3.0) sorry, didn’t read your post properly…
              openweather doesn’t add geoname in response. so i guess it’s the timezone.
                reilley
                OK, it would appear when /onecall is used, the OpenWeatherMap.js script controls the header and you’re either going to get:
                ${data.timezone}
                or
                ${data.city.name},${data.city.country}
                I’m see the first option, timezone. It’s correct, but I don’t want timezone. I want city/country. Booooo!!!
                  Peter @reilley
                  @reilley did you get it working with city, country?
                  Peter
                    reilley @Peter
                    @Peter - Unfortunately, not yet. I’m wondering if anyone has been able to using the 3.0 API!
                    • H Offline
                      HeikoGr
                      I got it working and think there are a few tricky typos in your config.
                      module: “weather”,
                      type: “current:,
                      lat: ‘34.17188’.
                      lon: ‘-84.57056’,
                      apiVersion: ‘3.0’,
                      apiKey: 'nunya”
                      Line 5: closing quotation marks are missing
                      Line 7: point as line ending instead of comma
                      Line 10: wrong quotation mark
                      Your config entry type is from line 5 - 10.
                      P R 2 Replies Last reply Reply Quote 1
                        Peter @HeikoGr
                        @HeikoGr does it show country and city in the header?
                        Peter
