    MMM-OpenWeatherForecast
    92 Posts 14 Posters 68.3k Views 14 Watching
      sdetweil @Ray
      @Ray yes, a call is a call. 250 is WAY TOO OFTEN for weather that doesn’t changed but every 10-15 minutes
      R 1 Reply Last reply
        Ray @sdetweil
        I just thought I’d throw it out there in case someone else runs into the same problem
          JohnGalt @Ray
          @Ray – Just for the sake of completeness for you or others I will mention here that the provider will count ALL calls, from ALL modules.
          As an example I can have this module running for a comprehensive look at my local weather, plus an instance of the default weather module telling me what’s happening with a friend or relatives, plus I’m running MMM-DynamicWeather.
          The API will count all the calls from all sources. It would be great if the MM system could pull the data and broadcast it to modules as needed, but that’s not how it works.
          S butchkemperB 2 Replies Last reply
            sdetweil @JohnGalt
            @JohnGalt the default weather broadcasts it’s data just like calendar does
            So the othermodules could use it
            wishmaster270W 1 Reply Last reply
            • wishmaster270W
              wishmaster270 Module Developer @sdetweil
              Just to make clear.
              The requestDelay is only used for the time between the start of the mirror and the first fetch of the data.
              For all following the updateInterval in seconds is used.
              The module sends is weather info, too. But I think both modules are not capable of use the info provided by notification at the moment
              • butchkemperB
                butchkemper @JohnGalt
                @JohnGalt
                The api call daily threshold for billing is 1,000. The default setting is to update every 10 minutes and that equals to 144 daily calls.
                Butch
                Resistance is not Futile!
                It is voltage divided by current.
                • H
                  hrjmsh @OldGuyBerlin
                  @OldGuyBerlin Worked for me, thanks.
                  C 1 Reply Last reply
                    chris1971 @hrjmsh
                    I had the same problem with my weather forecast. I made a subscription for an API 3.0 key and modified the config in this way:
                    		module: "MMM-OpenWeatherForecast",
                    		header: "Wetter in Mülheim",
                            apiBaseURL: "https://api.openweathermap.org/data/3.0/onecall?",
                            apikey: "xxxxxxxxxxxxxxxxxxxxxxxx", //only string here
                          latitude: 51.xxxxxxxx,            //number works here
                          longitude: 6.9xxxxxxxx,          //so does a string
                          updateInterval: 45,
                    	iconset: "3c",
                    	maxDailiesToShow: 4,
                    	maxHourliesToShow: 4,
                    	label_hourlyTimeFormat: "k[ Uhr]",
                    	label_sunriseTimeFormat: "k:mm",  // change the format for this one
                    	label_days: ["So", "Mo", "Di", "Mi", "Do", "Fr", "Sa"]
                    In addition I added “https://api.openweathermap.org/data/3.0/onecall?” as mentioned by @Ray in the node_helper.js in the weather module. The update intervall is 45 minutes - which means below 1000 calls per month
                    The module is running again!!!
                    Thx to this community and forum,
                    Chris
                    htilburgsH 1 Reply Last reply
                    • htilburgsH
                      htilburgs @chris1971
                      What if you don’t have a creditcard like me??
                      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
                        sdetweil @htilburgs
                        @htilburgs use pirateweather provider, on the default weather
                        • htilburgsH
                          htilburgs @sdetweil
                          Thanks, now it looks a bit like OpenWeather again ;-)
                          • 5 / 5
