    MMM-Pir
    34 Posts 5 Posters 8.5k Views 6 Watching
    • G
      gonzonia @sdetweil
      $ nvm -v
      0.39.7
        sdetweil @gonzonia
        @gonzonia ok, so you have nvm too
        sudo nvm i 20
        • G
          gonzonia @sdetweil
          @sdetweil said in MMM-Pir:
          sudo nvm i 20
          sudo nvm i 20
          sudo: nvm: command not found
            sdetweil @gonzonia
            @gonzonia ok, been a while
            nvm install v20.9.0
            • G
              gonzonia @sdetweil
              nvm install v20.9.0
              That did it!
              As always, THANK YOU!
                Peter @gonzonia
                @gonzonia is your Magic Mirror working now with MMM-PIR?
                My MM stopped turning on after updating MMM-PIR.
                Peter
                • G
                  gonzonia @Peter
                  @Peter So it’ll go off but the PIR doesn’t work to turn it back on? Mine is working. Try re-installing. Here’s the config I’m using.
                    module: 'MMM-Pir',
                  		  position: 'top_left',
                  		  classes: 'SceneFamily SceneSam',
                  			debug: false,
                  			delay: 2 * 60 * 1000,
                  			mode: 9	,
                  			displayCounter: false,
                  			displayBar: false,
                  			displayStyle: "Line",
                  			displayLastPresence: false,
                  			lastPresenceTimeFormat: "LL H:mm",
                  			mode6_gpio: 20,
                  			mode6_clearGpioValue: true,
                  			xrandrForceRotation: "left",
                  			wrandrForceRotation: "normal",
                  			wrandrForceMode: "1920x1080",
                  			touchMode: 3,
                  			pir_gpio: 4,
                  			pir_mode: 0,
                    Peter @gonzonia
                    @gonzonia before installing did you follow all the tips mentioned by sdetweil?
                    Peter
                    bugsounetB G 2 Replies Last reply Reply Quote 0
                    • bugsounetB
                      bugsounet Banned @Peter
                      Can you check new ReadMe
                      I haven’t had time to create a topic for the new release of MMM-Pir v2 yet, sorry
                      • G
                        gonzonia @Peter
                        @Peter Yes. Because I was getting an error when I tried installing.
                        • G
                          gonzonia @bugsounet
                          @bugsounet
                          I installed v 2 successfully. Everything seemed to be working with my old config (posted above). I tried updating based on the new readme, but now it won’t come back on.
                          I did have the wrong GPIO originally, but now it should be correct.
                          		  module: 'MMM-Pir',
                          			debug: false,
                          			Display: {
                          					timeout: 2 * 60 * 1000,
                          					animate: true,
                          					style: 0,
                          					colorFrom: "#FF0000",
                          					colorTo: "#00FF00",
                          					mode: 2,
                          					counter: true,
                          					lastPresence: false,
                          					availability: false,
                          					autoDimmer: false,
                          				Pir: {
                          					mode: 0,
                          					gpio: 20
                          				Cron: {
                          					ON: [],
                          					OFF: []
                          				Touch: {
                          					mode: 0
                          				Governor: {
                          					sleeping: 4,
                          					working: 2
                          				Sounds: {
                          					on: 0,
                          					off: 0
                          htilburgsH 1 Reply Last reply Reply Quote 0
                          • htilburgsH
                            htilburgs @gonzonia
                            @gonzonia Are you using X11 or Wayland?
                            Because now you’re using mode 2 and that’s for X11
                            (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
                            • G
                              gonzonia @htilburgs
                              @htilburgs yes. I was using mode 9 in the old version. When I looked it up I thought that’s what corresponded. Im on Pi OS 11 and Wayland is for 12 according to the read me
                              • G
                                gonzonia @gonzonia
                                I think I had the GPIO correct originally. Went back to that and it’s working.
                                • htilburgsH
                                  htilburgs @gonzonia
                                  @gonzonia
                                  Ok 👍 succes.
                                  • G
                                    gonzonia
                                    Okay, sorry to revive this. I saw there was an update available so I went to update.
                                    I did a git pull and got this
                                    hint: Pulling without specifying how to reconcile divergent branches is
                                    hint: discouraged. You can squelch this message by running one of the following
                                    hint: commands sometime before your next pull:
                                    hint:
                                    hint:   git config pull.rebase false  # merge (the default strategy)
                                    hint:   git config pull.rebase true   # rebase
                                    hint:   git config pull.ff only       # fast-forward only
                                    hint:
                                    hint: You can replace "git config" with "git config --global" to set a default
                                    hint: preference for all repositories. You can also pass --rebase, --no-rebase,
                                    hint: or --ff-only on the command line to override the configured default per
                                    hint: invocation.
                                    From https://github.com/bugsounet/MMM-Pir
                                       3a5bcdb..1fee537  master     -> origin/master
                                       fc5b3f6..658a322  dev        -> origin/dev
                                    Updating 3a5bcdb..1fee537
                                    error: Your local changes to the following files would be overwritten by merge:
                                    	MMM-Pir.js
                                    	components/cronJob.js
                                    	components/governorLib.js
                                    	components/motion.js
                                    	components/motionLib.js
                                    	components/pirLib.js
                                    	components/screenDisplayer.js
                                    	components/screenLib.js
                                    	components/screenTouch.js
                                    	node_helper.js
                                    Please commit your changes or stash them before you merge.
                                    Aborting
                                    The thing is, I know I have made NO CHANGES to any of those files.
                                    Should I run a pull.rebase? Would that fix it ?
                                    • G
                                      gonzonia @gonzonia
                                      I just did a reinstall for now, but I would like to know what I should do to fix this in the future
                                        sdetweil @gonzonia
                                        @gonzonia the question is what did you do before
                                        Sounds like you might have downloaded the zip over the files in the working directory, or copied files from somewhere else
                                        In general, the force way to get back to the repo level
                                        is
                                        git reset --hard HEAD
                                        This will restore all the files to the last commit level.
                                        IF you made changes for some reason , they will be wiped out, no warnings.
                                        git status before git pull will tell you if there are any changed files,
                                        and git diff will show you the changes
                                        • bugsounetB
                                          bugsounet Banned @sdetweil
                                          Readme says:
                                          see there
                                          G S 2 Replies Last reply Reply Quote 0
                                          • G
                                            gonzonia @bugsounet
                                            @bugsounet and that’s what I did wrong! thank you!
