    MMM-Pir
    34 Posts 5 Posters 8.9k Views 6 Watching
      sdetweil @gonzonia
      @gonzonia ok, been a while
      nvm install v20.9.0
      G 1 Reply Last reply
      • G
        gonzonia @sdetweil
        @sdetweil said in MMM-Pir:
        nvm install v20.9.0
        That did it!
        As always, THANK YOU!
        P 1 Reply Last reply
          Peter @gonzonia
          @gonzonia is your Magic Mirror working now with MMM-PIR?
          My MM stopped turning on after updating MMM-PIR.
          Peter
          • G
            gonzonia @Peter
            @Peter So it’ll go off but the PIR doesn’t work to turn it back on? Mine is working. Try re-installing. Here’s the config I’m using.
              module: 'MMM-Pir',
            		  position: 'top_left',
            		  classes: 'SceneFamily SceneSam',
            			debug: false,
            			delay: 2 * 60 * 1000,
            			mode: 9	,
            			displayCounter: false,
            			displayBar: false,
            			displayStyle: "Line",
            			displayLastPresence: false,
            			lastPresenceTimeFormat: "LL H:mm",
            			mode6_gpio: 20,
            			mode6_clearGpioValue: true,
            			xrandrForceRotation: "left",
            			wrandrForceRotation: "normal",
            			wrandrForceMode: "1920x1080",
            			touchMode: 3,
            			pir_gpio: 4,
            			pir_mode: 0,
              Peter @gonzonia
              @gonzonia before installing did you follow all the tips mentioned by sdetweil?
              Peter
              bugsounetB G 2 Replies Last reply
              • bugsounetB
                bugsounet Banned @Peter
                Can you check new ReadMe
                I haven’t had time to create a topic for the new release of MMM-Pir v2 yet, sorry
                • G
                  gonzonia @Peter
                  @Peter Yes. Because I was getting an error when I tried installing.
                  • G
                    gonzonia @bugsounet
                    @bugsounet
                    I installed v 2 successfully. Everything seemed to be working with my old config (posted above). I tried updating based on the new readme, but now it won’t come back on.
                    I did have the wrong GPIO originally, but now it should be correct.
                    		  module: 'MMM-Pir',
                    			debug: false,
                    			Display: {
                    					timeout: 2 * 60 * 1000,
                    					animate: true,
                    					style: 0,
                    					colorFrom: "#FF0000",
                    					colorTo: "#00FF00",
                    					mode: 2,
                    					counter: true,
                    					lastPresence: false,
                    					availability: false,
                    					autoDimmer: false,
                    				Pir: {
                    					mode: 0,
                    					gpio: 20
                    				Cron: {
                    					ON: [],
                    					OFF: []
                    				Touch: {
                    					mode: 0
                    				Governor: {
                    					sleeping: 4,
                    					working: 2
                    				Sounds: {
                    					on: 0,
                    					off: 0
                    htilburgsH 1 Reply Last reply
                    • htilburgsH
                      htilburgs @gonzonia
                      @gonzonia Are you using X11 or Wayland?
                      Because now you’re using mode 2 and that’s for X11
                      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
                      • G
                        gonzonia @htilburgs
                        @htilburgs yes. I was using mode 9 in the old version. When I looked it up I thought that’s what corresponded. Im on Pi OS 11 and Wayland is for 12 according to the read me
                        • G
                          gonzonia @gonzonia
                          I think I had the GPIO correct originally. Went back to that and it’s working.
                          • htilburgsH
                            htilburgs @gonzonia
                            @gonzonia
                            Ok 👍 succes.
                            • G
                              gonzonia
                              Okay, sorry to revive this. I saw there was an update available so I went to update.
                              I did a git pull and got this
                              hint: Pulling without specifying how to reconcile divergent branches is
                              hint: discouraged. You can squelch this message by running one of the following
                              hint: commands sometime before your next pull:
                              hint:
                              hint:   git config pull.rebase false  # merge (the default strategy)
                              hint:   git config pull.rebase true   # rebase
                              hint:   git config pull.ff only       # fast-forward only
                              hint:
                              hint: You can replace "git config" with "git config --global" to set a default
                              hint: preference for all repositories. You can also pass --rebase, --no-rebase,
                              hint: or --ff-only on the command line to override the configured default per
                              hint: invocation.
                              From https://github.com/bugsounet/MMM-Pir
                                 3a5bcdb..1fee537  master     -> origin/master
                                 fc5b3f6..658a322  dev        -> origin/dev
                              Updating 3a5bcdb..1fee537
                              error: Your local changes to the following files would be overwritten by merge:
                              	MMM-Pir.js
                              	components/cronJob.js
                              	components/governorLib.js
                              	components/motion.js
                              	components/motionLib.js
                              	components/pirLib.js
                              	components/screenDisplayer.js
                              	components/screenLib.js
                              	components/screenTouch.js
                              	node_helper.js
                              Please commit your changes or stash them before you merge.
                              Aborting
                              The thing is, I know I have made NO CHANGES to any of those files.
                              Should I run a pull.rebase? Would that fix it ?
                              • G
                                gonzonia @gonzonia
                                I just did a reinstall for now, but I would like to know what I should do to fix this in the future
                                  sdetweil @gonzonia
                                  @gonzonia the question is what did you do before
                                  Sounds like you might have downloaded the zip over the files in the working directory, or copied files from somewhere else
                                  In general, the force way to get back to the repo level
                                  is
                                  git reset --hard HEAD
                                  This will restore all the files to the last commit level.
                                  IF you made changes for some reason , they will be wiped out, no warnings.
                                  git status before git pull will tell you if there are any changed files,
                                  and git diff will show you the changes
                                  • bugsounetB
                                    bugsounet Banned @sdetweil
                                    Readme says:
                                    see there
                                    G S 2 Replies Last reply
                                    • G
                                      gonzonia @bugsounet
                                      @bugsounet and that’s what I did wrong! thank you!
                                        sdetweil @bugsounet
                                        @bugsounet you should make it normal, like the rest of the modules…
                                        bugsounetB 1 Reply Last reply
                                        • G
                                          gonzonia @sdetweil
                                          @sdetweil This is helpful, thank you. I guarantee I made no changes though. I think it’s just that it needs to use npm run update
                                          • bugsounetB
                                            @sdetweil of course not :)
