    MMM-Pir
    34 Posts 5 Posters 8.9k Views 6 Watching
    • htilburgsH
      htilburgs @gonzonia
      @gonzonia Are you using X11 or Wayland?
      Because now you’re using mode 2 and that’s for X11
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
      G 1 Reply Last reply
      • G
        gonzonia @htilburgs
        @htilburgs yes. I was using mode 9 in the old version. When I looked it up I thought that’s what corresponded. Im on Pi OS 11 and Wayland is for 12 according to the read me
        • G
          gonzonia @gonzonia
          I think I had the GPIO correct originally. Went back to that and it’s working.
          htilburgsH 1 Reply Last reply
          • htilburgsH
            htilburgs @gonzonia
            @gonzonia
            Ok 👍 succes.
            • G
              gonzonia
              Okay, sorry to revive this. I saw there was an update available so I went to update.
              I did a git pull and got this
              hint: Pulling without specifying how to reconcile divergent branches is
              hint: discouraged. You can squelch this message by running one of the following
              hint: commands sometime before your next pull:
              hint:
              hint:   git config pull.rebase false  # merge (the default strategy)
              hint:   git config pull.rebase true   # rebase
              hint:   git config pull.ff only       # fast-forward only
              hint:
              hint: You can replace "git config" with "git config --global" to set a default
              hint: preference for all repositories. You can also pass --rebase, --no-rebase,
              hint: or --ff-only on the command line to override the configured default per
              hint: invocation.
              From https://github.com/bugsounet/MMM-Pir
                 3a5bcdb..1fee537  master     -> origin/master
                 fc5b3f6..658a322  dev        -> origin/dev
              Updating 3a5bcdb..1fee537
              error: Your local changes to the following files would be overwritten by merge:
              	MMM-Pir.js
              	components/cronJob.js
              	components/governorLib.js
              	components/motion.js
              	components/motionLib.js
              	components/pirLib.js
              	components/screenDisplayer.js
              	components/screenLib.js
              	components/screenTouch.js
              	node_helper.js
              Please commit your changes or stash them before you merge.
              Aborting
              The thing is, I know I have made NO CHANGES to any of those files.
              Should I run a pull.rebase? Would that fix it ?
              • G
                gonzonia @gonzonia
                I just did a reinstall for now, but I would like to know what I should do to fix this in the future
                  sdetweil @gonzonia
                  @gonzonia the question is what did you do before
                  Sounds like you might have downloaded the zip over the files in the working directory, or copied files from somewhere else
                  In general, the force way to get back to the repo level
                  is
                  git reset --hard HEAD
                  This will restore all the files to the last commit level.
                  IF you made changes for some reason , they will be wiped out, no warnings.
                  git status before git pull will tell you if there are any changed files,
                  and git diff will show you the changes
                  bugsounetB G 2 Replies Last reply
                  • bugsounetB
                    bugsounet Banned @sdetweil
                    Readme says:
                    see there
                    G S 2 Replies Last reply
                    • G
                      gonzonia @bugsounet
                      @bugsounet and that’s what I did wrong! thank you!
                        sdetweil @bugsounet
                        @bugsounet you should make it normal, like the rest of the modules…
                        bugsounetB 1 Reply Last reply
                        • G
                          gonzonia @sdetweil
                          @sdetweil This is helpful, thank you. I guarantee I made no changes though. I think it’s just that it needs to use npm run update
                          • bugsounetB
                            @sdetweil of course not :)
