MM with dual Monitor on pi5?
7 Posts 3 Posters 447 Views 3 Watching
  • F Offline
    Future.Mirror
    Hello dear Community,
    first of All my Englisch ist very Bad so i am sorry I misswrite something.
    My Question is if its possible to run MM on 2 Displays which are both on the pi 5. And if its Possiblr how i Set it up?
    I want on 1 Display Different Module and on the other Display i want also Show Differenz Module.
    Thanks for your answerhb❤️❤️
    S 1 Reply Last reply Nov 16, 2024, 1:57 PM Reply Quote 0
    • S Away
      sdetweil @Future.Mirror
      @Future-Mirror yes
      see the documentation here
      https://docs.magicmirror.builders/configuration/introduction.html#advanced-configuration-and-frequently-asked-how-to-configure-examples
      F 1 Reply Last reply Nov 19, 2024, 10:46 AM Reply Quote 1
      • F Offline
        Future.Mirror @sdetweil
        @sdetweil Thx I have done it with 2 different mm2 folder an in the one config.js I have write the electronic options now is the problem that when I start both mm2 folder they open on the display I have clicked the last time with the mouse how can I fix that? Or should I just copy the one configq js into the other folder so that both are in the same folder?
        S B 2 Replies Last reply Nov 19, 2024, 12:25 PM Reply Quote 0
        • S Away
          @Future-Mirror you can do it w two folders but you don’t need to
          Probably electron saved it’s config once
          Stop all MagicMirror instances
           cd  ~/.config
          rm -rf Electron
          Note the dot in front of config
          Then restart MagicMirror
          F 1 Reply Last reply Nov 20, 2024, 3:54 PM Reply Quote 0
            BKeyport Module Developer @Future.Mirror
            @Future-Mirror It may be wayland causing that - Try this:
            sudo raspi-config
            then use
            option 6 “Advanced options”,
            option A6, “Wayland”, then
            option W1 “X11”
            and approve the change.
            This will switch you over to the old screen design system, where the instructions in the documentation is known to work.
            If you would like, I’d be happy to share my configuration files up to the modules and how I did it. Let me know.
            • F Offline
              @sdetweil said in MM with dual Monitor on pi5?:
              probably electron saved it’s config once
              S 1 Reply Last reply Nov 20, 2024, 5:09 PM Reply Quote 0
              • S Away
                @Future-Mirror did this help?
