    MM with dual Monitor on pi5?
    7 Posts 3 Posters 1.3k Views 3 Watching
      sdetweil @Future.Mirror
      @Future-Mirror yes
      see the documentation here
      https://docs.magicmirror.builders/configuration/introduction.html#advanced-configuration-and-frequently-asked-how-to-configure-examples
      F 1 Reply Last reply Reply Quote 1
      • F Offline
        Future.Mirror @sdetweil
        @sdetweil Thx I have done it with 2 different mm2 folder an in the one config.js I have write the electronic options now is the problem that when I start both mm2 folder they open on the display I have clicked the last time with the mouse how can I fix that? Or should I just copy the one configq js into the other folder so that both are in the same folder?
          @Future-Mirror you can do it w two folders but you don’t need to
          Probably electron saved it’s config once
          Stop all MagicMirror instances
           cd  ~/.config
          rm -rf Electron
          Note the dot in front of config
          Then restart MagicMirror
          • BKeyportB Offline
            BKeyport Module Developer @Future.Mirror
            @Future-Mirror It may be wayland causing that - Try this:
            sudo raspi-config
            then use
            option 6 “Advanced options”,
            option A6, “Wayland”, then
            option W1 “X11”
            and approve the change.
            This will switch you over to the old screen design system, where the instructions in the documentation is known to work.
            If you would like, I’d be happy to share my configuration files up to the modules and how I did it. Let me know.
            • F Offline
              @sdetweil said in MM with dual Monitor on pi5?:
              probably electron saved it’s config once
                @Future-Mirror did this help?
