    MM with dual Monitor on pi5?
    7 Posts 3 Posters 1.5k Views 3 Watching
    • F Offline
      Future.Mirror
      Hello dear Community,
      first of All my Englisch ist very Bad so i am sorry I misswrite something.
      My Question is if its possible to run MM on 2 Displays which are both on the pi 5. And if its Possiblr how i Set it up?
      I want on 1 Display Different Module and on the other Display i want also Show Differenz Module.
      Thanks for your answerhb❤️❤️
        sdetweil @Future.Mirror
        @Future-Mirror yes
        see the documentation here
        https://docs.magicmirror.builders/configuration/introduction.html#advanced-configuration-and-frequently-asked-how-to-configure-examples
        F 1 Reply Last reply Reply Quote 1
        • F Offline
          Future.Mirror @sdetweil
          @sdetweil Thx I have done it with 2 different mm2 folder an in the one config.js I have write the electronic options now is the problem that when I start both mm2 folder they open on the display I have clicked the last time with the mouse how can I fix that? Or should I just copy the one configq js into the other folder so that both are in the same folder?
            @Future-Mirror you can do it w two folders but you don’t need to
            Probably electron saved it’s config once
            Stop all MagicMirror instances
             cd  ~/.config
            rm -rf Electron
            Note the dot in front of config
            Then restart MagicMirror
            • BKeyportB Offline
              BKeyport Module Developer @Future.Mirror
              @Future-Mirror It may be wayland causing that - Try this:
              sudo raspi-config
              then use
              option 6 “Advanced options”,
              option A6, “Wayland”, then
              option W1 “X11”
              and approve the change.
              This will switch you over to the old screen design system, where the instructions in the documentation is known to work.
              If you would like, I’d be happy to share my configuration files up to the modules and how I did it. Let me know.
              • F Offline
                @sdetweil said in MM with dual Monitor on pi5?:
                probably electron saved it’s config once
                  @Future-Mirror did this help?
