    Having trouble with screen on and off? Here are some tips that could help
    14 Posts 7 Posters 7.5k Views 7 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @reviewsfornerds
      @reviewsfornerds Hi. Apologies for the late reply. Was away for the weekend.
      Can you share your script that you are calling? Also the output of wlr-randr.
        sdetweil @reviewsfornerds
        @reviewsfornerds said in Having trouble with screen on and off? Here are some tips that could help:
        the log file shows the error “failed to connect to display”
        yes, the command wants to know WHICH ‘display’ you want to control
        and normally would get that from the environment variables of the terminal window you are running the command in
        BUT
        the module is running it in the background, with NO window, no env variable… oops…
        IN addition, ‘specifying’ the window info may not work as the environment running the wlr_randr command was NOT started UNDER the window manager
        how to fix THAT is beyond my knowledge… as each of these depends on different stuff…
        (and you put it in cron, and cron runs as ROOT, not the local user you would be if you had a terminal window… even more fun)
          captsi
          Thank you for the tutorial, it solved my issues of sending the screen to sleep at night. For whatever reasons, I had to use wayland-0 and HDMI-A-2 on my installation.
          mumblebajM S 2 Replies Last reply Reply Quote 1
            mumblebaj Module Developer @captsi
            @captsi HDMI-A-2 is probably because you plugged into 2. Glad it helped you though.
              sdetweil @captsi
              @captsi said in Having trouble with screen on and off? Here are some tips that could help:
              wayland is the software screen interface,
              HDMI- is the hardware screen interface
              • L Offline
                langejos @mumblebaj
                @mumblebaj
                Works great, but when the monitor switches back on, chromium does not start maximized and shows the infobar, both of which are managed in the [autostart] section of wayfire.ini. Is there a way to get the MM display back just as when the Pi launches fresh?
                S mumblebajM 2 Replies Last reply Reply Quote 0
                  sdetweil @langejos
                  @langejos switch back to x11 in raspi-config
                  L 1 Reply Last reply Reply Quote -1
                  • G Offline
                    Gejakem
                    For me I needed to use wayland-0 on a RPI5 using the ribbon-display cable.
                    From the wlr-randr i got this
                    DSI-1 “(null) (null) (DSI-1)”
                    Physical size: 154x86 mm
                    Enabled: yes
                    Modes:
                    800x480 px, 60.028999 Hz (preferred, current)
                    Position: 368,332
                    Transform: 90
                    Scale: 1.000000
                    So I used DSI-1 instead of HDMI.
                    Also I removed the --mode information since i got something like “Mode 800x480 not recognized”, but apparently my display defaults to that.
                    • BKeyportB Offline
                      BKeyport Module Developer @mumblebaj
                      @mumblebaj Course, I just switched back to X11 for now. 🙃
                        mumblebaj Module Developer @langejos
                        @langejos I am assuming you ran wlr-randr prior to creating the scripts to obtain your mirrors current display settings and then using that as input in the mon.sh?
