    Having trouble with screen on and off? Here are some tips that could help
    14 Posts 7 Posters 8.2k Views 7 Watching
      sdetweil @reviewsfornerds
      @reviewsfornerds said in Having trouble with screen on and off? Here are some tips that could help:
      the log file shows the error “failed to connect to display”
      yes, the command wants to know WHICH ‘display’ you want to control
      and normally would get that from the environment variables of the terminal window you are running the command in
      BUT
      the module is running it in the background, with NO window, no env variable… oops…
      IN addition, ‘specifying’ the window info may not work as the environment running the wlr_randr command was NOT started UNDER the window manager
      how to fix THAT is beyond my knowledge… as each of these depends on different stuff…
      (and you put it in cron, and cron runs as ROOT, not the local user you would be if you had a terminal window… even more fun)
        captsi
        Thank you for the tutorial, it solved my issues of sending the screen to sleep at night. For whatever reasons, I had to use wayland-0 and HDMI-A-2 on my installation.
        mumblebajM S 2 Replies Last reply Reply Quote 1
        • mumblebajM Offline
          mumblebaj Module Developer @captsi
          @captsi HDMI-A-2 is probably because you plugged into 2. Glad it helped you though.
            sdetweil @captsi
            @captsi said in Having trouble with screen on and off? Here are some tips that could help:
            wayland is the software screen interface,
            HDMI- is the hardware screen interface
            • L Offline
              langejos @mumblebaj
              @mumblebaj
              Works great, but when the monitor switches back on, chromium does not start maximized and shows the infobar, both of which are managed in the [autostart] section of wayfire.ini. Is there a way to get the MM display back just as when the Pi launches fresh?
              S mumblebajM 2 Replies Last reply Reply Quote 0
                sdetweil @langejos
                @langejos switch back to x11 in raspi-config
                L 1 Reply Last reply Reply Quote -1
                • G Offline
                  Gejakem
                  For me I needed to use wayland-0 on a RPI5 using the ribbon-display cable.
                  From the wlr-randr i got this
                  DSI-1 “(null) (null) (DSI-1)”
                  Physical size: 154x86 mm
                  Enabled: yes
                  Modes:
                  800x480 px, 60.028999 Hz (preferred, current)
                  Position: 368,332
                  Transform: 90
                  Scale: 1.000000
                  So I used DSI-1 instead of HDMI.
                  Also I removed the --mode information since i got something like “Mode 800x480 not recognized”, but apparently my display defaults to that.
                  • BKeyportB Offline
                    BKeyport Module Developer @mumblebaj
                    @mumblebaj Course, I just switched back to X11 for now. 🙃
                      mumblebaj Module Developer @langejos
                      @langejos I am assuming you ran wlr-randr prior to creating the scripts to obtain your mirrors current display settings and then using that as input in the mon.sh?
                        reviewsfornerds
                        Hello all and thank you for all the suggestions. I apologize as I never got followup notifications of your responses.
                        I ended up reverting back to the original desktop as I did not feel like fighting to change everything.
                        Again, thank you all for your time and help.
