    Having trouble with screen on and off? Here are some tips that could help
    20 Posts 8 Posters 16.4k Views 8 Watching
      sdetweil @langejos
      @langejos switch back to x11 in raspi-config
      L 1 Reply Last reply Reply Quote -1
      • G Offline
        Gejakem
        For me I needed to use wayland-0 on a RPI5 using the ribbon-display cable.
        From the wlr-randr i got this
        DSI-1 “(null) (null) (DSI-1)”
        Physical size: 154x86 mm
        Enabled: yes
        Modes:
        800x480 px, 60.028999 Hz (preferred, current)
        Position: 368,332
        Transform: 90
        Scale: 1.000000
        So I used DSI-1 instead of HDMI.
        Also I removed the --mode information since i got something like “Mode 800x480 not recognized”, but apparently my display defaults to that.
        • BKeyportB Offline
          BKeyport Module Developer @mumblebaj
          @mumblebaj Course, I just switched back to X11 for now. 🙃
          • mumblebajM Offline
            mumblebaj Module Developer @langejos
            @langejos I am assuming you ran wlr-randr prior to creating the scripts to obtain your mirrors current display settings and then using that as input in the mon.sh?
              reviewsfornerds
              Hello all and thank you for all the suggestions. I apologize as I never got followup notifications of your responses.
              I ended up reverting back to the original desktop as I did not feel like fighting to change everything.
              Again, thank you all for your time and help.
              • L Offline
                langejos @sdetweil
                @sdetweil Yes, I did! I tried switching to x-11 and adjusting all parameters, but ended up switching back to wayland which works fine with a scheduled shut-down in the evening. Thank you once again for taking the time to lead me through this!
                • mumblebajM mumblebaj referenced this topic on
                • karsten13K karsten13 referenced this topic on
                  mumblebaj Module Developer @mumblebaj
                  For users who are having issues with monitor on and monitor off and looking for a cron job to start their wayland setup. See my original post with updates.
                  1 1 Reply Last reply Reply Quote 0
                  • 1 Offline
                    1a2a3a @mumblebaj
                    @mumblebaj hey, do you know why my off job when i triggered it either manually or via the cron job, it turns the monitor off, but after a few seconds it turns it on immediately again…?
                      mumblebaj Module Developer @1a2a3a
                      Hi @1a2a3a . Honestly, no idea. I remember seeing a few posts from people having that exact same issue. Maybe if you search the forum for related content you may find something. I have not had the same issue myself.
                      • 1 Offline
                        1a2a3a @mumblebaj
                        @mumblebaj I found this old thread of mine - https://forum.magicmirror.builders/topic/18318/mm-current-version-on-raspberry-pi-5-cannot-turn-off-monitor/32?page=4
                        Did you input the vc4 hot plug command?
                        mumblebajM 2 Replies Last reply Reply Quote 0
                          @1a2a3a I am a little confused. I am not having any issues after implementing my solution in this post. I thought you were having issues.
                            @1a2a3a For the latest Wayland on off I use the new adjusted scripts.
                            mon.sh
                            #!/bin/bash
                            export WAYLAND_DISPLAY=wayland-0
                            export XDG_RUNTIME_DIR=/run/user/1000
                            /usr/bin/wlr-randr --output HDMI-A-1 --on --mode 1920x1080@60Hz --transform 270
                            mof.sh
                            #!/bin/bash
                            /usr/bin/wlr-randr --output HDMI-A-1 --off
                            This works pretty well for me. The screen eventually times out as there is no input and it turns off.
                            In addition to these I have these cron entries to call the scripts.
                            Turns the screen on at 6am and off at 9pm.
                            00 06 * * * /home/pi/mon.sh >> /home/pi/mon.log 2>&1
                            00 21 * * * /home/pi/mof.sh >> /home/pi/mof.log 2>&1
