    Having trouble with screen on and off? Here are some tips that could help
    15 Posts 7 Posters 15.4k Views 7 Watching
    • mumblebajM Offline
      mumblebaj Module Developer
      Hey guys,
      I have updated the scripts below to reflect what works now for wayland. Have also added a crontab ready script to start MM.
      Just a little note for for those who are struggling.
      I have recently upgraded from my RPi 3B+ to RPi 5 4GB. MM has been running fine for a while now and all my modules are running sweet.
      One thing I have been struggling with was getting the Pi to shut off the output at night and then on again in the morning. The old way, vcgencmd display_power 0 and vcgencmd display_power 1 does not work on the RPi5.
      In order to get things working again, and after a lot of research I have managed to get this working now. Below are 2 scripts that I have which are called from crontab at specified times.
      You have to ensure that both of the below scripts are executeable. To do this you need to run the following command. chmod +x mon.sh mof.sh from the command prompt.
      mof.sh - Monitor Off. Works for X11 Compositor.
      Create a file: nano mof.sh and add the below.
      #!/bin/bash
      export WAYLAND_DISPLAY=wayland-1
      export XDG_RUNTIME_DIR=/run/user/1000
      /usr/bin/wlr-randr --output HDMI-A-1 --off
      Since update to 2.35.0 Wayland: The below is now valid for Wayland. Biggest change is that it is now wayland-0.
      #!/bin/bash
      export WAYLAND_DISPLAY=wayland-0
      Explanation
      • Declare a variable for WAYLAND_DISPLAY
      • Declare a variable for XDG_RUNTIME_DISPLAY (I had an issue with this and only found recently that I needed to declare this as well in the script)
      • Execute the wlr-randr command to turn off the display
      mon.sh - Monitor On. Works for X11 Compositor
      Create a file: nano mon.sh and add the below to it.
      #!/bin/bash
      /usr/bin/wlr-randr --output HDMI-A-1 --on --mode 1920x1080@60Hz --transform 270
      And for 2.35.0 update:
      #!/bin/bash
      Explanation
      • Declare a variable for XDG_RUNTIME_DISPLAY (I had an issue with this and only found that I needed to declare this as well in the script)
      • Execute the wlr-randr command to turn on the display
      • lI have to supply options to this command as I needed to ensure that when the monitor is turned on, it has the same pixilation and rotation etc. This is achieved by passing --mode 1929x1080@60Hz and to ensure it is flipped 90 degrees I pass the option --transform 270.
      To obtain your current screen settings you run wlr-randr from the command prompt and you will be shown the current settings for your mirror. You can then use those values and substitute them for the values above if yours is different. This will also confirm if your monitor is HDMI-A-1 or if it is called something else.
      Crontab
      To instantiate a crontab you do crontab -e from the command line.
      Add the following entries at the bottom of the file.
      00 06 * * * /home/pi/mon.sh >> /home/pi/mon.log 2>&1
      00 21 * * * /home/pi/mof.sh >> /home/pi/mof.log 2>&1
      From the above, it will turn the output on at 6am and turn it off at 9pm.
      One added bonus script that could save others. I use this to start MM from the cron. This works for wayland compositor.
      #!/bin/bash
      set -e
      sleep 5
      export PATH=/usr/local/bin:/usr/bin:/bin
      cd /home/pi/MagicMirror
      exec /usr/bin/npm run start:wayland
      Hope this helps somebody.
      R L BKeyportB mumblebajM 4 Replies Last reply Reply Quote 3
        reviewsfornerds @mumblebaj
        @mumblebaj Thank you for this tutorial.
        I have been able to modify the MMM-Remote-Control config to use these commands for monitor on and off, and the command “/usr/bin/wlr-randr --output HDMI-A-1 --off” works in ssh terminal, however the log file shows the error “failed to connect to display” when running this as a cron job.
        Would you have any insight as to what I could do? What would I need to provide in order for you to assist?
        I am on Wayland desktop
        mumblebajM S 2 Replies Last reply Reply Quote 1
          mumblebaj Module Developer @reviewsfornerds
          @reviewsfornerds Hi. Apologies for the late reply. Was away for the weekend.
          Can you share your script that you are calling? Also the output of wlr-randr.
            sdetweil @reviewsfornerds
            @reviewsfornerds said in Having trouble with screen on and off? Here are some tips that could help:
            yes, the command wants to know WHICH ‘display’ you want to control
            and normally would get that from the environment variables of the terminal window you are running the command in
            BUT
            the module is running it in the background, with NO window, no env variable… oops…
            IN addition, ‘specifying’ the window info may not work as the environment running the wlr_randr command was NOT started UNDER the window manager
            how to fix THAT is beyond my knowledge… as each of these depends on different stuff…
            (and you put it in cron, and cron runs as ROOT, not the local user you would be if you had a terminal window… even more fun)
              captsi
              Thank you for the tutorial, it solved my issues of sending the screen to sleep at night. For whatever reasons, I had to use wayland-0 and HDMI-A-2 on my installation.
                mumblebaj Module Developer @captsi
                @captsi HDMI-A-2 is probably because you plugged into 2. Glad it helped you though.
                  sdetweil @captsi
                  @captsi said in Having trouble with screen on and off? Here are some tips that could help:
                  wayland is the software screen interface,
                  HDMI- is the hardware screen interface
                  • L Offline
                    langejos @mumblebaj
                    @mumblebaj
                    Works great, but when the monitor switches back on, chromium does not start maximized and shows the infobar, both of which are managed in the [autostart] section of wayfire.ini. Is there a way to get the MM display back just as when the Pi launches fresh?
                    S mumblebajM 2 Replies Last reply Reply Quote 0
                      sdetweil @langejos
                      @langejos switch back to x11 in raspi-config
                      L 1 Reply Last reply Reply Quote -1
                      • G Offline
                        Gejakem
                        For me I needed to use wayland-0 on a RPI5 using the ribbon-display cable.
                        From the wlr-randr i got this
                        DSI-1 “(null) (null) (DSI-1)”
                        Physical size: 154x86 mm
                        Enabled: yes
                        Modes:
                        800x480 px, 60.028999 Hz (preferred, current)
                        Position: 368,332
                        Transform: 90
                        Scale: 1.000000
                        So I used DSI-1 instead of HDMI.
                        Also I removed the --mode information since i got something like “Mode 800x480 not recognized”, but apparently my display defaults to that.
                        • BKeyportB Offline
                          BKeyport Module Developer @mumblebaj
                          @mumblebaj Course, I just switched back to X11 for now. 🙃
                            mumblebaj Module Developer @langejos
                            @langejos I am assuming you ran wlr-randr prior to creating the scripts to obtain your mirrors current display settings and then using that as input in the mon.sh?
                              reviewsfornerds
                              Hello all and thank you for all the suggestions. I apologize as I never got followup notifications of your responses.
                              I ended up reverting back to the original desktop as I did not feel like fighting to change everything.
                              Again, thank you all for your time and help.
                              • L Offline
                                langejos @sdetweil
                                @sdetweil Yes, I did! I tried switching to x-11 and adjusting all parameters, but ended up switching back to wayland which works fine with a scheduled shut-down in the evening. Thank you once again for taking the time to lead me through this!
                                • mumblebajM mumblebaj referenced this topic on
                                • karsten13K karsten13 referenced this topic on
                                  mumblebaj Module Developer @mumblebaj
                                  For users who are having issues with monitor on and monitor off and looking for a cron job to start their wayland setup. See my original post with updates.
