    Electron quit periodically
    26 Posts 3 Posters 3.8k Views 4 Watching
      jefftse
      my MM quits and restarts periodically. When I looked at the logs from pm2 and here is what I get. I wonder if anyone is experiencing the same thing and any solutions?
      0|mm | MEMORY-ERROR: electron[20099]: GSlice: assertion failed: sinfo->n_allocated > 0
      0|mm | /home/jeff/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT
        sdetweil @jefftse
        @jefftse i haven’t seen that reported before
        can you show the startup info from the logs?
        and also output of
        free -m
          jefftse @sdetweil
          total           used        free        shared  buff/cache   available
          Mem:            3791        1127        1276         210        1674        2664
          Swap:            511           0         511
          how do i get you the startup info from the logs? pm2 log? or npm log?
            sdetweil @jefftse
            @jefftse pm2 logs --lines=xxx
            where xxx is the number of most recent lines to show
              jefftse @sdetweil
              @sdetweil I’m sorry but i’m not following…
                sdetweil @jefftse
                @jefftse
                pm2 logs --lines=15
                will show the last 15 lines of the captured output
                if your instance has been running for a day
                the LAST 15 lines are not useful, as the info is near the top (AND the log accumulates runs)
                you can also look at the file holding the output
                it is in the
                ~/.pm2/logs folder
                notice the dot in front of pm2
                  jefftse @sdetweil
                  @sdetweil gotcha. yea. i tried to upload the whole error log but i realized there is no way to do it here.
                    sdetweil @jefftse
                    @jefftse just need the 4 lines
                      jefftse @sdetweil
                      @sdetweil waiting for the next crash
                        sdetweil @jefftse
                        @jefftse but the info is there now
