    Electron quit periodically
    26 Posts 3 Posters 4.1k Views 4 Watching
      sdetweil @jefftse
      @jefftse pm2 logs --lines=xxx
      where xxx is the number of most recent lines to show
        jefftse @sdetweil
        @sdetweil I’m sorry but i’m not following…
          sdetweil @jefftse
          @jefftse
          pm2 logs --lines=15
          will show the last 15 lines of the captured output
          if your instance has been running for a day
          the LAST 15 lines are not useful, as the info is near the top (AND the log accumulates runs)
          you can also look at the file holding the output
          it is in the
          ~/.pm2/logs folder
          notice the dot in front of pm2
            jefftse @sdetweil
            @sdetweil gotcha. yea. i tried to upload the whole error log but i realized there is no way to do it here.
              sdetweil @jefftse
              @jefftse just need the 4 lines
                jefftse @sdetweil
                @sdetweil waiting for the next crash
                  sdetweil @jefftse
                  @jefftse but the info is there now
                    jefftse @sdetweil
                    @sdetweil > magicmirror@2.29.0 start
                    0|mm | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                    0|mm | [2024-12-18 09:29:44.580] [LOG] Starting MagicMirror: v2.29.0
                    0|mm | [2024-12-18 09:29:44.647] [LOG] Loading config …
                    0|mm | [2024-12-18 09:29:44.654] [LOG] config template file not exists, no envsubst
                    0|mm | [2024-12-18 09:29:46.022] [INFO] Checking config file /home/jeff/MagicMirror/config/config.js …
                    0|mm | [2024-12-18 09:29:46.254] [INFO] Your configuration file doesn’t contain syntax errors :)
                    0|mm | [2024-12-18 09:29:46.257] [INFO] Checking modules structure configuration …
                    0|mm | [2024-12-18 09:29:46.526] [INFO] Your modules structure configuration doesn’t contain errors :)
                    0|mm | [2024-12-18 09:29:46.532] [LOG] Loading module helpers …
                    0|mm | [2024-12-18 09:29:46.536] [LOG] No helper found for module: alert.
                    0|mm | [2024-12-18 09:29:46.555] [LOG] Initializing new module helper …
                    0|mm | [2024-12-18 09:29:46.557] [LOG] Module helper loaded: updatenotification
                    0|mm | [2024-12-18 09:29:46.559] [LOG] No helper found for module: clock.
                    0|mm | [2024-12-18 09:29:46.860] [LOG] Initializing new module helper …
                    0|mm | [2024-12-18 09:29:46.861] [LOG] Module helper loaded: calendar
                    0|mm | [2024-12-18 09:29:47.085] [LOG] Initializing new module helper …
                    0|mm | [2024-12-18 09:29:47.086] [LOG] Module helper loaded: newsfeed
                    0|mm | [2024-12-18 09:29:48.025] [LOG] Initializing new module helper …
                    0|mm | [2024-12-18 09:29:48.026] [LOG] Module helper loaded: MMM-NowPlayingOnSpotify
                    0|mm | [2024-12-18 09:29:48.264] [LOG] Initializing new module helper …
                    0|mm | [2024-12-18 09:29:48.265] [LOG] Module helper loaded: MMM-Screencast
                    0|mm | [2024-12-18 09:29:49.970] [LOG] Initializing new module helper …
                    0|mm | [2024-12-18 09:29:49.972] [LOG] Module helper loaded: MMM-AVStock
                    0|mm | [2024-12-18 09:29:50.472] [LOG] Initializing new module helper …
                    0|mm | [2024-12-18 09:29:50.473] [LOG] Check MagicMirror² version for node helper ‘MMM-CoinMarketCap’ - Minimum version: 2.2.1 - Current version: 2.29.0
                    0|mm | [2024-12-18 09:29:50.475] [LOG] Version is ok!
                    0|mm | [2024-12-18 09:29:50.476] [LOG] Module helper loaded: MMM-CoinMarketCap
                    0|mm | [2024-12-18 09:29:50.709] [LOG] Initializing new module helper …
                    0|mm | [2024-12-18 09:29:50.710] [LOG] Module helper loaded: MMM-BackgroundSlideshow
                    0|mm | [2024-12-18 09:29:50.826] [LOG] Initializing new module helper …
                    0|mm | [2024-12-18 09:29:50.827] [LOG] Module helper loaded: MMM-Pir
                    0|mm | [2024-12-18 09:29:50.869] [LOG] Initializing new module helper …
                    0|mm | [2024-12-18 09:29:50.870] [LOG] Module helper loaded: MMM-OpenWeatherMapForecast
                    0|mm | [2024-12-18 09:29:50.870] [LOG] All module helpers loaded.
                    0|mm | [2024-12-18 09:29:50.889] [LOG] Starting server on port 8080 …
                    0|mm | [2024-12-18 09:29:54.510] [LOG] Server started …
                    0|mm | [2024-12-18 09:29:54.515] [LOG] Connecting socket for: updatenotification
                    0|mm | [2024-12-18 09:29:54.521] [LOG] Starting module helper: updatenotification
                    0|mm | [2024-12-18 09:29:54.527] [LOG] Connecting socket for: calendar
                    0|mm | [2024-12-18 09:29:54.536] [LOG] Starting node helper for: calendar
                    0|mm | [2024-12-18 09:29:54.538] [LOG] Connecting socket for: newsfeed
                    0|mm | [2024-12-18 09:29:54.541] [LOG] Starting node helper for: newsfeed
                    0|mm | [2024-12-18 09:29:54.543] [LOG] Connecting socket for: MMM-NowPlayingOnSpotify
                    0|mm | [2024-12-18 09:29:54.550] [LOG] Connecting socket for: MMM-Screencast
                    0|mm | [2024-12-18 09:29:54.557] [LOG] Connecting socket for: MMM-AVStock
                    0|mm | [2024-12-18 09:29:54.563] [LOG] Connecting socket for: MMM-CoinMarketCap
                    0|mm | [2024-12-18 09:29:54.569] [LOG] MMM-CoinMarketCap: module loaded! Path: /home/jeff/MagicMirror/modules/MMM-CoinMarketCap
                    0|mm | [2024-12-18 09:29:54.574] [LOG] MMM-CoinMarketCap: Path “/logos” configured successfully.
                    0|mm | [2024-12-18 09:29:54.575] [LOG] Connecting socket for: MMM-BackgroundSlideshow
                    0|mm | [2024-12-18 09:29:54.581] [LOG] Connecting socket for: MMM-Pir
                    0|mm | [2024-12-18 09:29:54.584] [LOG] Connecting socket for: MMM-OpenWeatherMapForecast
                    0|mm | [2024-12-18 09:29:54.585] [LOG] Starting node_helper for MMM-OpenWeatherMapForecast
                    0|mm | [2024-12-18 09:29:54.589] [LOG] Sockets connected & modules started …
                    0|mm | [2024-12-18 09:29:55.384] [LOG] Launching application.
                    0|mm | [2024-12-18 09:29:57.817] [INFO] System information:
                    0|mm | ### SYSTEM: manufacturer: ; model: ; virtual: false
                    0|mm | ### OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.62+rpt-rpi-v8
                    0|mm | ### VERSIONS: electron: 31.7.6; used node: 20.18.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.3
                    0|mm | ### OTHER: timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
                    0|mm | [30914:1218/092957.948903:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                    0|mm | [30914:1218/092957.949629:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                    0|mm | [30914:1218/092957.950132:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                    0|mm | [30914:1218/092957.950420:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                    0|mm | [30914:1218/092957.950944:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                    0|mm | [30914:1218/092957.951547:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                    0|mm | [30914:1218/092957.952173:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                    0|mm | [30914:1218/092957.952551:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                    0|mm | [30914:1218/092957.953858:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                    0|mm | [30914:1218/092957.954350:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                    0|mm | [30914:1218/092957.955047:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                    0|mm | [30914:1218/092957.955602:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                    0|mm | [30914:1218/092957.956790:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                    0|mm | [30914:1218/092957.957248:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                    0|mm | [30914:1218/092957.961329:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                    0|mm | [30914:1218/092957.961766:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                    0|mm | [30914:1218/092957.962348:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                    0|mm | [30914:1218/092957.962797:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                    0|mm | [30914:1218/092957.963454:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                    0|mm | [30914:1218/092957.963887:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                    0|mm | [30914:1218/092957.964501:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                    0|mm | [30914:1218/092957.964979:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                    0|mm | [30914:1218/092957.965605:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                    0|mm | [30914:1218/092957.966056:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                    0|mm | [30914:1218/092957.966665:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or director
                      sdetweil @jefftse
                      @jefftse said in Electron quit periodically:
                      that is what I needed
                        @jefftse ok, this is related to the Wayland compositor
                        can you switch back to X11
                        use the raspi-config app
                        sudo raspi-config
                        advanced
                        Wayland
                        X11
                        you will have to reboot after that
                        J 3 Replies Last reply Reply Quote 0
