    MMM-WeatherOrNot - Noob needs help
    9 Posts 4 Posters 1.3k Views 4 Watching
      coertze78
      [2024-12-18 11:33:42.772] [LOG] No helper found for module: MMM-WeatherOrNot.
      S KristjanESPERANTOK AssassinsA 3 Replies Last reply Reply Quote 0
        sdetweil @coertze78
        @coertze78 this module does not use a node_ helper so this info is not helpful
        please don’t double post. all users w reputation below 2 have their posts reviewed before publishing. this stops all the junk. but occasionally i sleep.
        • KristjanESPERANTOK Online
          KristjanESPERANTO Module Developer @coertze78
          @coertze78 How did you come up with the idea of using this module? The module list says about this module: "Deprecated. DarkSky API no longer works since 2023-03-31."
          AssassinsA 1 Reply Last reply Reply Quote 0
          • AssassinsA Offline
            Assassins @KristjanESPERANTO
            @KristjanESPERANTO the modul work fin here with MM2,29,0
            KristjanESPERANTOK 1 Reply Last reply Reply Quote 1
              Assassins @coertze78
              @coertze78
              When you have make the clone, go to the MMM-WeatherOrNot folder and try this
              npm install
              and is not working try
              npm install request --save
                sdetweil @Assassins
                @Assassins but the api it calls (darksky) has been dead for over a year, after Apple bought it and shut it down
                someone could change it to pirateweather which duplicates the darksky data format
                  KristjanESPERANTO Module Developer @Assassins
                  @Assassins said in MMM-WeatherOrNot - Noob needs help:
                  Interesting. I’ve just had a look at the code. Contrary to the description in the README of the module, the DarkSky API is not used. I adapted the information about the module in the module list.
                    Assassins @sdetweil
                    @sdetweil and @KristjanESPERANTO
                    my backup from my GitHub
                    https://github.com/The-Exterminator/MyMagicMirror/Install/MMM-Github-Install.sh
                    And is work from a clean install with MM2.29.0
                      sdetweil @Assassins
                      @Assassins as @KristjanESPERANTO documented, the module does NOT use the darksky api… so the info I worked from was incorrect
