    MMM-WeatherOrNot - Noob needs help
    9 Posts 4 Posters 1.3k Views 4 Watching
    • AssassinsA Offline
      Assassins @KristjanESPERANTO
      @KristjanESPERANTO the modul work fin here with MM2,29,0
      KristjanESPERANTOK 1 Reply Last reply Reply Quote 1
        Assassins @coertze78
        @coertze78
        When you have make the clone, go to the MMM-WeatherOrNot folder and try this
        npm install
        and is not working try
        npm install request --save
          sdetweil @Assassins
          @Assassins but the api it calls (darksky) has been dead for over a year, after Apple bought it and shut it down
          someone could change it to pirateweather which duplicates the darksky data format
          AssassinsA 1 Reply Last reply Reply Quote 0
          • KristjanESPERANTOK Offline
            KristjanESPERANTO Module Developer @Assassins
            @Assassins said in MMM-WeatherOrNot - Noob needs help:
            Interesting. I’ve just had a look at the code. Contrary to the description in the README of the module, the DarkSky API is not used. I adapted the information about the module in the module list.
              Assassins @sdetweil
              @sdetweil and @KristjanESPERANTO
              my backup from my GitHub
              https://github.com/The-Exterminator/MyMagicMirror/Install/MMM-Github-Install.sh
              And is work from a clean install with MM2.29.0
                sdetweil @Assassins
                @Assassins as @KristjanESPERANTO documented, the module does NOT use the darksky api… so the info I worked from was incorrect
