    New module: Weather effects
    27 Posts 4 Posters 10.8k Views 5 Watching
      cgillinger @uros76
      I dont think PM2 shows module-specific broadcasts unless explicitly logged, but Im no expert. Maybe @sdetweil knows?
      To test it I just bascially found locations with rain or snow, and set that in config.js.
      S uros76U 2 Replies Last reply Reply Quote 0
        sdetweil @cgillinger
        @cgillinger correct. notifications are not logged
        1 they are in browser
        2 if the sending or receiving module does not console.log() a message there is nothing to see
        you can install MMM-Logging which will capture the browser console and merge it with the npm start output
        or install MMM-Notifications which will display them in a window on the MagicMirror screen
          mmmallday @cgillinger
          @cgillinger Very cool well done
          • uros76U
            uros76 @cgillinger
            @cgillinger duh, why didn’t I think of setting to a city where it rains LOL. I picked a random rainy city and presto, it works! Tnx again for this module.
            @sdetweil thanks. I installed the MMM-Logging and checked the npm start console for any hint of notifications coming through but I can’t see anything related to notifications being broadcasted. I am probably missing something obvious again :(
            And I can’t seem to find the MMM-Notifications location. Do you perhaps have a link to it?
            I did thind this one but it doesn’t show anything https://github.com/glitch452/MMM-ViewNotifications
            S 2 Replies Last reply Reply Quote 1
              sdetweil @uros76
              @uros76 yes, it was https://github.com/glitch452/MMM-ViewNotifications
              it shows for me
              C uros76U 2 Replies Last reply Reply Quote 0
                cgillinger @sdetweil
                And I just want to add here that I’m running it on a Raspberry Pi with a 7-inch screen, so there’s not much screen space to work with. I don’t have room for the weather module with the ‘current’ option as well. However, after testing, it seems to work perfectly fine to keep the module ‘hidden’ by simply omitting a location in the config.js file
                I’m considering making the rain direction controlled by the wind direction from the Weather module. If it’s possible, it would look pretty neat.
                  @cgillinger yes, commenting out the psosition still allows the module to work in the background…
                  also do this for calendar with Ext3 family of modules
                    sdetweil @uros76
                    @uros76 said in New module: Weather effects:
                    yes, if they don’t print a console message then its not in the the log for logging to forward…
                    • uros76U
                      uros76 @sdetweil
                      @sdetweil said in New module: Weather effects:
                      it shows for me
                      Well that’s interesting. I will keep trying to get this one to work. Not sure why it’s refusing to workfor me
                      uros76U 1 Reply Last reply Reply Quote 0
                      • uros76U
                        uros76 @uros76
                        On my test MM install the weather effects work. This confirms the module is getting the notification broadcast from wethaer after all.
                        But the viewnotifications module doesn’t come up. I will keep it running for a bit longer to see if notifications show up. Even the newsfeed notifications should come up I think…
                        It’s not the end of the world, I am just digging into why I can’t see notifications :)
                          sdetweil @uros76
                          what position is it in?
                          • uros76U
                            uros76 @sdetweil
                            @sdetweil top_left. It should show up under the clock.
                              sdetweil @uros76
                              @uros76 did you use the default config?
                                          module: 'MMM-ViewNotifications',
                                          header: "Notifications",
                                          classes:"page1",  // for MMM-pages
                                              // See below for Configuration Options
                              • uros76U
                                uros76 @sdetweil
                                @sdetweil yes I used the default config. I also added timeout: 0 to see if I perhaps missed them. Default is 8sec timeout before notifications disappear.
                                  sdetweil @uros76
                                  @uros76 ok… did the header appear?
                                  • uros76U
                                    uros76 @sdetweil
                                    @sdetweil nope, cant even see the header of the notifications module. I am running this test enviroment as a server mode and on a windows 10 PC. If that makes any difference.
                                      sdetweil @uros76
                                      @uros76 its only in browser, so thats all that matters…
                                      notifications list can’t last forever as its crazy busy sometimes…
                                      open the developers window, ctrl-shift-i, select the elements tab, and expand the top bar, top left section
                                      (mine is in bottom left)
                                      • uros76U
                                        uros76 @sdetweil
                                        @sdetweil I changed it to top_center location to see if that could help. No difference.
                                        Inspecting the developers window I can’t see anything in top_center region.
                                        This is the config I am using
                                          sdetweil @uros76
                                          @uros76 I changed mine to timeout:0… and they show and stay
                                          what is that stuff on body? I don’t have that
                                          nano ~/MagicMirror/index.html
                                          that is the page definition
                                          unless some other modules is hacking the dom…
                                          • uros76U
                                            uros76 @sdetweil
                                            @sdetweil that must be the Grammarly extension on my chrome browser. I’ll retry with different browser later and report back.
