    New module: Weather effects
    27 Posts 4 Posters 10.8k Views 5 Watching
      sdetweil @cgillinger
      @cgillinger correct. notifications are not logged
      1 they are in browser
      2 if the sending or receiving module does not console.log() a message there is nothing to see
      you can install MMM-Logging which will capture the browser console and merge it with the npm start output
      or install MMM-Notifications which will display them in a window on the MagicMirror screen
        mmmallday @cgillinger
        @cgillinger Very cool well done
        • uros76U
          uros76 @cgillinger
          @cgillinger duh, why didn’t I think of setting to a city where it rains LOL. I picked a random rainy city and presto, it works! Tnx again for this module.
          @sdetweil thanks. I installed the MMM-Logging and checked the npm start console for any hint of notifications coming through but I can’t see anything related to notifications being broadcasted. I am probably missing something obvious again :(
          And I can’t seem to find the MMM-Notifications location. Do you perhaps have a link to it?
          I did thind this one but it doesn’t show anything https://github.com/glitch452/MMM-ViewNotifications
          S 2 Replies Last reply Reply Quote 1
            sdetweil @uros76
            @uros76 yes, it was https://github.com/glitch452/MMM-ViewNotifications
            it shows for me
            C uros76U 2 Replies Last reply Reply Quote 0
              cgillinger @sdetweil
              And I just want to add here that I’m running it on a Raspberry Pi with a 7-inch screen, so there’s not much screen space to work with. I don’t have room for the weather module with the ‘current’ option as well. However, after testing, it seems to work perfectly fine to keep the module ‘hidden’ by simply omitting a location in the config.js file
              I’m considering making the rain direction controlled by the wind direction from the Weather module. If it’s possible, it would look pretty neat.
                @cgillinger yes, commenting out the psosition still allows the module to work in the background…
                also do this for calendar with Ext3 family of modules
                  sdetweil @uros76
                  @uros76 said in New module: Weather effects:
                  yes, if they don’t print a console message then its not in the the log for logging to forward…
                  • uros76U
                    uros76 @sdetweil
                    @sdetweil said in New module: Weather effects:
                    it shows for me
                    Well that’s interesting. I will keep trying to get this one to work. Not sure why it’s refusing to workfor me
                    uros76U 1 Reply Last reply Reply Quote 0
                    • uros76U
                      uros76 @uros76
                      On my test MM install the weather effects work. This confirms the module is getting the notification broadcast from wethaer after all.
                      But the viewnotifications module doesn’t come up. I will keep it running for a bit longer to see if notifications show up. Even the newsfeed notifications should come up I think…
                      It’s not the end of the world, I am just digging into why I can’t see notifications :)
                        sdetweil @uros76
                        what position is it in?
                        • uros76U
                          uros76 @sdetweil
                          @sdetweil top_left. It should show up under the clock.
                            sdetweil @uros76
                            @uros76 did you use the default config?
                                        module: 'MMM-ViewNotifications',
                                        header: "Notifications",
                                        classes:"page1",  // for MMM-pages
                                            // See below for Configuration Options
                            • uros76U
                              uros76 @sdetweil
                              @sdetweil yes I used the default config. I also added timeout: 0 to see if I perhaps missed them. Default is 8sec timeout before notifications disappear.
                                sdetweil @uros76
                                @uros76 ok… did the header appear?
                                • uros76U
                                  uros76 @sdetweil
                                  @sdetweil nope, cant even see the header of the notifications module. I am running this test enviroment as a server mode and on a windows 10 PC. If that makes any difference.
                                    sdetweil @uros76
                                    @uros76 its only in browser, so thats all that matters…
                                    notifications list can’t last forever as its crazy busy sometimes…
                                    open the developers window, ctrl-shift-i, select the elements tab, and expand the top bar, top left section
                                    (mine is in bottom left)
                                    • uros76U
                                      uros76 @sdetweil
                                      @sdetweil I changed it to top_center location to see if that could help. No difference.
                                      Inspecting the developers window I can’t see anything in top_center region.
                                      This is the config I am using
                                        sdetweil @uros76
                                        @uros76 I changed mine to timeout:0… and they show and stay
                                        what is that stuff on body? I don’t have that
                                        nano ~/MagicMirror/index.html
                                        that is the page definition
                                        unless some other modules is hacking the dom…
                                        • uros76U
                                          uros76 @sdetweil
                                          @sdetweil that must be the Grammarly extension on my chrome browser. I’ll retry with different browser later and report back.
                                          • uros76U
                                            uros76 @uros76
                                            @sdetweil I tried on Edge and Firefox browser and it’s the same, I can’t see the notifications module loading in the selected region position. No clue what could prevent this module from loading.
