    New module: Weather effects
    27 Posts 4 Posters 11.4k Views 5 Watching
      sdetweil @uros76
      @uros76 said in New module: Weather effects:
      But the viewnotifications module doesn’t come up. I will keep it running for a bit longer to see if notifications show up
      what position is it in?
      uros76U 1 Reply Last reply
      • uros76U
        uros76 @sdetweil
        @sdetweil top_left. It should show up under the clock.
          sdetweil @uros76
          @uros76 did you use the default config?
                      module: 'MMM-ViewNotifications',
                      header: "Notifications",
                      classes:"page1",  // for MMM-pages
                          // See below for Configuration Options
          • uros76U
            uros76 @sdetweil
            @sdetweil yes I used the default config. I also added timeout: 0 to see if I perhaps missed them. Default is 8sec timeout before notifications disappear.
              sdetweil @uros76
              @uros76 ok… did the header appear?
              • uros76U
                uros76 @sdetweil
                @sdetweil nope, cant even see the header of the notifications module. I am running this test enviroment as a server mode and on a windows 10 PC. If that makes any difference.
                  sdetweil @uros76
                  @uros76 its only in browser, so thats all that matters…
                  notifications list can’t last forever as its crazy busy sometimes…
                  open the developers window, ctrl-shift-i, select the elements tab, and expand the top bar, top left section
                  (mine is in bottom left)
                  • uros76U
                    uros76 @sdetweil
                    @sdetweil I changed it to top_center location to see if that could help. No difference.
                    Inspecting the developers window I can’t see anything in top_center region.
                    This is the config I am using
                      sdetweil @uros76
                      @uros76 I changed mine to timeout:0… and they show and stay
                      what is that stuff on body? I don’t have that
                      nano ~/MagicMirror/index.html
                      that is the page definition
                      unless some other modules is hacking the dom…
                      • uros76U
                        uros76 @sdetweil
                        @sdetweil that must be the Grammarly extension on my chrome browser. I’ll retry with different browser later and report back.
                        • uros76U
                          uros76 @uros76
                          @sdetweil I tried on Edge and Firefox browser and it’s the same, I can’t see the notifications module loading in the selected region position. No clue what could prevent this module from loading.
                          • uros76U
                            uros76 @uros76
                            Okay, I just reinstalled the whole test environment from scratch and now it works. Why the hell it didn’t work earlier I don’t know. Important is that it works.
                            Thanks again @sdetweil for all the assistance and guidance.
                              sdetweil @uros76
                              @uros76 awesome… also no idea why it wouldn’t work before
